Question about Kenmore 16622 Mechanical Sewing Machine
Reverse not working on Kenmore 385. 1884180
The reverse function on our Kenmore 385. 1884180 is not working. Everything appears to be intact. Any suggestions? Thanks!
  • bygodwv Jan 10, 2009
    I have the same problem -- help!
    everything works fine except the reverse stitch
  • 19 Answers
SOURCE: My kenmore 385 won't feed fabric
hi there check feed dogs are up not down mary h
e
Posted on Dec 30, 2008
  • 69 Answers
SOURCE: My old Kenmore sewing machine makes a loud squealing noise.
It sounds as if your machine needs a little oiling. If you have a clear machine oil (not 3 in 1). place a drop in the bobbin case area and if you will notice, you will see small holes on the bed and on the top of the machine. place a drop of oil into each of these holes. If you can take the top and bottom covers off, you can put a drop of oil every where you see a hole..some of the machines actually have the oil holes painted a red color. Also place a drop at the handwheel as well. Just remember when oiling, less is better. After oiling, run for a few minutes, if you feel it still needs a litte more, do the same, one drop at a time. After this, if you machine sets for a while, oil just before starting to sew, that way when you put the machine away the oil has been worked through and it should help prevent the squeaking when starting up again.
Posted on Mar 01, 2009
kent581
  • 87 Answers
SOURCE: Kenmore 15516 It only goes reverse both ways.
Does it have an automatic buttonhole? If so, is the pattern selector set on part of the buttonhole? set it to straight stitch or Zig Zag
Posted on Mar 18, 2009
SOURCE: Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
Posted on Oct 07, 2009
  • 1564 Answers
SOURCE: 30 stitch kenmore....model # 385
It really depends on the type of material you are sewing. But most machines are set at around 4 from the factory. remember right to tighten, left to loosen.
Posted on Mar 12, 2011
Kenmore 385.1500 sews only in reverse. it is stuck in reverse sewing.
The reverse mechanism lube us going bad. It is accessed from under the machine under the free arm. Usually indicates that the machine is due for a service and oiling. It shouldn't be a problem to get it done at a good sewing machine dealer/store.
Nov 15, 2016 | Kenmore Sewing Machines
Will not sew in reverse when reverse button pushed
my kenmore 385.17526 will not go in reverse when I push ...
www.shopyourway.com > Manage My Life > Questions
my kenmore 385.17526 will not go in reverse when I push the button ... Having asewing machine that doesn't reverse can be a bit disappointing, especially ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home_and_Garden/.../Sewing.../index.html
Sewing Machine Won't Sew in Reverse. My Elna 3007 became temperamental atsewing in reverse some years ago. On occasion, I will need to push the button ...
Bernina 1230 Reverse Button Fix ' Temecula Valley Sewing ...
https://tv-sewingcenter.com/bernina/bernina-1230-reverse-button-fix
Aug 30, 2010 - The reverse button of the 1230 had been pulled or popped out of ... All I had to do to fix the button was to hold the button in, and then push the cap forward. ... My 1120 Bernina reverse button will not work and the person who ...
Dec 28, 2015 | Sewing Machines
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
My Sears Kenmore Model #385.17822 will not reverse...
the machine may need to be checked at a sewing machine shop to find out why the reverse is not working.
Apr 15, 2012 | Kenmore Sewing Machines
My kenmore sewing machine will not go in reverse
Well when you push on the reverse button you should feel some resistance from the internal mechanism? If not, then the lever on inside is either broken or stuck. If you want to look at some of the reverse mechanism you may remove the bottom covers both for the base and the free area and locate the link lever that works the reverse. Then remove the top cover for more light so you can see better. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Jan 16, 2011 | Kenmore Sewing Machines
My reverse stitch doesn't work?
There is a rocker inside the machine the rocks back and forth with the operation of the reverse button. It will stick if it is not serviced regularly. If you have the machine serviced every 2 to 3 years, by someone who knows the machine, everything should work fine for many years to come. Not servicing a sewing machine is something like not servicing an automobile. It will run fine well beyond the recommended service time but when it stops, you will need to spend a lot more money than what you would for a standard oil change.
Feb 13, 2010 | Husqvarna Sewing Machines
My reverse doesn't work either :(
Check the spring inside of the sewing machine. You have to take it apart and look at the spring where the reverse lever is located.
Jul 11, 2009 | Kenmore 16622 Mechanical Sewing Machine
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Machine will only sew in reverse
Hi
Questions.
Does the machine only feed in reverse?
Will the machine feed as normal(forward).
If the machine will only work in reverse, then it is highly likely it is stuck in reverse and needs a good service to free it off.
It is very difficult trying to diagnose the problem without looking at the machine. A reasonable sewing machine tech should be able to sort the problem in no time at all.
Rob
Mar 27, 2008 | Kenmore 16622 Mechanical Sewing Machine
Janome JD1818 Automatic Buttonhole Not Working
If everything appears to be working correctly for the first side and stops and bunches up when it should reverse - Make sure you have pulled down the stopper arm (this is not clear in the manual) when the button hole foot contacts the stopper arm gently push the foot against the stopper arm and the direction will reverse and finish the button hole. **Stopper arm pulls down from above - Check the pictures in you manual carefully.**
Mar 16, 2008 | Sewing Machines
Sewing Machines Logo
219 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
