Media AW 52-9906 wont drain water out or spin just happened and a alerm is going off and i get E4 help
E 4 is coming up
  • 262 Answers
SOURCE: washer wont drain
check the pump for socks or anything that dont belong but put your hand on it while its in spin/drain and see if pump is even running
Posted on Dec 21, 2007
  • 1314 Answers
SOURCE: whirlpool wont spin or drain...
something is jamming your drain pump Well I'm going to do my best to fix your washer. First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub.Rmove the spring clamp pull the hose now you may or may not have to replace the pump depending on if you can remove the object.
Posted on Jan 17, 2008
  • 110 Answers
SOURCE: whirlpool calypso washing machine
WP HAS HAD A ON GOING ISSUE WITH THIS THAT IS THE REASON WHY THEY REDIGNED THE DRAIN PUMP. YOU NEED TO 1ST DRAIN OUT AS MUCH WATER MANUALLY AS YOU CAN THEN DISCONNECT ALL YOUR HOSES FROM WALL TAKE THE WM OUTSIDE TO DRAIN THE OTHER 3 GALLONS OF WATER YOU CANNOT SEE. TURN THE MACHINE ON ITS BACK THEN USING A 5/16 NUT DRIVER REMOVE 4 SCREWS ON THE BOTTOM PANEL. REMOVE PANEL AND YOUR DRAIN MTR IN ASSESSIBLE. THE PART CAN BE ORDERED AT WWW.REPAIRCLINIC.COM
Posted on May 30, 2008
  • 148 Answers
SOURCE: washer wont drain water
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Posted on Jul 13, 2008
SOURCE: NEW SAMSUNG WASHER WONT DRAIN.
Same thing Happened to me I found that there was a small coin caught up in the filter..
Posted on Aug 31, 2008
Magic chef error E4
E4 indicates the washer failed to drain out after 4 minutes, after that time the code is set. Check and clean the drain filter first.
Jan 19, 2017 | Magic Chef Washing Machines
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
What are the Lyrics to the song "Just as I am"
1.Just as I am, without one plea, but that thy blood was shed for me, and that thou bidst me come to thee, O Lamb of God, I come, I come. 2.Just as I am, and waiting not to rid my soul of one dark blot, to thee whose blood can cleanse each spot, O Lamb of God, I come, I come. 3.Just as I am, though tossed about with many a conflict, many a doubt, fightings and fears within, without, O Lamb of God, I come, I come. 4.Just as I am, poor, wretched, blind; sight, riches, healing of the mind, yea, all I need in thee to find, O Lamb of God, I come, I come. 5.Just as I am, thou wilt receive, wilt welcome, pardon, cleanse, relieve; because thy promise I believe, O Lamb of God, I come, I come. 6.Just as I am, thy love unknown hath broken every barrier down; now, to be thine, yea thine alone, O Lamb of God, I come, I come.
Sep 30, 2014 | every-song-lyrics.com Computers & Internet
Brake light not working
Well, either it comes on or it does not come on, you say it comes on then you say it does not come on, which is it. If the brake light does not come on at all check the bulb first.
Apr 15, 2014 | Harley Davidson FLHX Street Glide...
1999 chevy venture won't come out of park
Check if the brake light come on when pressing the brake paddle?, IF brake lights do not come on then replace the brake light switch and the shifter will come out of park.
Jun 20, 2012 | 1999 Chevrolet Venture
Aftermarket stereo for 2008 malibu ltz comes on but no sound coming out
did you check speaker wires if you have got them wired up right ???
Mar 25, 2012 | Cars & Trucks
My conia washing machine model cwm5003t wont empty or spin and comes up with e4 on display whats wrong
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Aug 20, 2011 | Washing Machines
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
A E4 comes up water seems to be in bottom and there does not seem to be a drying mode...
E4 is overfill protection error . If that happens on drain, then it is a drain problem.
Try first tripping circuit breaker and dry water in the tub using a sponge.
Check the drain well and the filter.
Ensure drain hose at the back is not kinked.
Access pump hose , undo it and look for blockage.
Check the water level device. This is usually a float switch, on some model you also have a pressure switch.
Dec 02, 2009 | EuroTech Dishwashers
Washing Machines Logo
542 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
