Bonair manual thermostat manual
Product no : 5430052
Fault code five on bonaire evaporative air con
To less information, minimum Modell Number needed.
Following link you'll find a manual, this can help you to fix your problem.
http://www.bonaire.com.au/lib/pdf/OM/RAC_Owners_Manual_6602201B.pdf
Oct 19, 2014 | Heating & Cooling
Vulcan Ducted Heater has gone into reset a couple of times in the past fortnight. This morning not in reset not functioning. Tried reset. no go, held reset on Bonaire wireless remote code F1 11 displayed??
Hello
You are experiencing a thermostat problem,what you simply need to do is to call up an experienced repairman and have the thermostat of your heater replaced
Apr 22, 2011 | Heating & Cooling
I have the Bonaire Inflation Machine Model NRC12S,I've had it for quite a while and can't find the manual. I can never get it to work on high pressor setting. I've charged it for 3 days,makes noise when...
Manual says:
Turn Power Supply switch to DC12V or Battery position
Turn Inflator to High Pressure position
Turn off when you reach the correct pressure according to the gauge
and
Charge battery up to 13 hours, do not completely run down the battery.
Sep 15, 2010 | Bonaire Cordless Inflation Machine
VULCAN BONAIRE Users manual.
Try here http://www.bonaire.com.au/support/documentation/owner/default.aspx
Dec 31, 2009 | Heating & Cooling
Where can I download an owners manual for a Vulcan Summer Breeze Evaporative Airconditioning system
I have downloaded it myself from here:
http://www.bonaire.com.au/evaporativecooling/ownersmanuals.aspx
Oct 29, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
