Question about Kitchen Appliances - Others
Blown element...I think?
Dualit combi 2+1
I am not a techy but I think the element has blown. Is there somewhere in or near SW18 where I can take my toaster to be fixed?
If there is, what should the cost be?
Thanks, in advance,
Mike
Mike Roberts
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 185 Answers
Where is SW18 located? What country? I would make an estimate that repairs would cost more than a new toaster
Loringh
Posted on Oct 26, 2008
My dualit toasters element has blown, can i repair it myself
if you have a litle experience with screws and wires you can buy the elements from ebay and here is the instructions
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
Aug 03, 2011 | Dualit Vario 2 Slices Toaster
RH end element was not heating to same temperature as middle element. Bought and fitted new end element but still same problem ie this new element still not heating to correct temperature high causing...
the new version has a plastic cover over element wires its best just to change all elements to solve this if you have had this toaster a wile the old elements dont have it,,,make sure its correct ones fitted as they are all different watts ..
Feb 23, 2011 | Dualit Vario Combi 2+1 65-Slice Toaster
Combi 2 plus one, bought in 2006. i need a new timer element type HI7 made by faucigny instruments. Where can i get hold of one of these spare parts?
I think the MI7 timer is equivalent. The best prices are on ebay. You can also check in with appliance repair shops. Electra-Craft lists Dualit timers, but again, I am not sure if these are what you need: http://www.mcssl.com/store/electra-craft/catalog/search?keyword=dualit+timer
Jan 25, 2011 | Dualit Vario 3 Slices Toaster
The side element in the toatie side of the toaster has failed.
Replacement elements are available on ebay. you can get to the element to replace by removing the bottom of the toaster. not a hard job.
Dec 22, 2010 | Dualit Vario Combi 2+1 65-Slice Toaster
How do you replace a centre element of a Dualit 3 slice toaster?
You can buy the elements from ebay uk and for 110 v also, they are so slim and light that they ship them in normal envelope and arrived in no time.
You can follow the instruction in the link what to order and how to replace.
We have the procedure here in this link
Good luck
Jun 07, 2010 | Dualit 31213 3Slice Toaster
Dualit 4-slot toaster - is this how it's supposed to work?
your toaster is working correctly if both are off you are in BAGEL/BUN mode ( did i spell that wrong ? ) in that mode it will only toast the cut side .... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Dualit Vario Combi 2x2 65-Slice Toaster
Dualit combi heating element 12/95
All the element's are available on e-bay u.k. for about 6.00 gbp. Alternativley you may be able to repair it. Put the toaster on it's side with the bottom facing towards you and the knobs on the top. Remove the crumb tray and then remove the bottom (usually the screws are located in the feet). There may be one more visible screw remove that too, then you will see a rail at the bottom that secures the element's in place. Loosen off the nuts at each end and slide the rail down, undo the two bolt's feeding the power to the element's and slide the element out.Go over it with a continuity meter and see where it's broken then move the element wire about to bridge the circuit.Test it again and reassemble. I repaired mine this way.Or, simply replace the element using the instructions above.Easy!
Sep 18, 2008 | Dualit Vario 3 Slices Toaster
Kitchen Appliances - Others Logo
98 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
