Question about Gateway FPD1975W 19" LCD Monitor
Gateway 900w monitor
My screen is dark but the monitor still works, if i hold a flashlight up to the screen i can see what is there but barely. any suggestions on how to fix that problem. i have already tried to adjust the dimness on the screen but that didnt work.
  • cajunroux Apr 25, 2009
    I have the same problem. But if you press the input button on the side of the Gateway 900w, it show no rgb input but then it switches back to vga it momentarily shows the desktop in full clarity. Any suggestions?
  • Steve Bowman Oct 19, 2009
    I have the Gateway 900W Monitor, and it does not power on. What could be the problem?
  • 849 Answers
The back light must be gone bad, need replacement, contact to sevice center
Posted on Oct 27, 2008
    Novelist:
  • 65 Answers
Could be a bad backlight or a bad power board. The power board most likely has just blown some capacitors. If you are adventurous and know what you are doing, open it up and check the board for any problems.
WARNING: the Gateway 900w has a bunch of quircks with regards to opening it up. Be patient and careful while doing it. You will find after removing the front cover and the LCD panel that the power board is mounted upside down on the mainboard. Check the cluster of 25V capacitors. Mine were all bulged up.
Posted on Aug 14, 2009
Gateway m280 notebook black screen.
Why did you replace the lcd inverter? Were you able to barely see icons on the desktop which is an indication that the lcd inverter is bad? If not, then you need to replace the lcd screen. If you could barely see the icons and you replaced the lcd inverter, then the inverter is bad. Just because the inverter is new does not mean it works. If the video shows on the external monitor, but you can't see anything on the laptop's screen even when you shine a flashlight on it then the lcd screen is bad.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad.
If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 24, 2012 | Gateway Computers & Internet
Gateway laptop powers up but screen does not come up.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your ideo card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 24, 2012 | Computers & Internet
Monitor does not light up at all.
Did she spill something on it? Have you tried to make sure it's not an issue with your bright and dark buttons or keys on the keyboard?
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 08, 2012 | Gateway 400SD4 Notebook
My screen is black on my gateway w340ui what needs to b repaired n how much?
Screen is black? Does it look like the computer booted up all the way, if so maybe your icons are on the desktop.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 16, 2012 | Gateway Computers & Internet
Gateway 5150 - computer screen stays black, screen works fine, just very very dark - can't seem to adjust luminosity?
Apr 09, 2012 | Computers & Internet
WHEN A SYSTEM IS ON BUT NOT BOTHING ON THE SCREEN
If it's a desktop try another monitor. If the other monitor works, then the original one you were using is bad. If the other monitor does not work then most likely your video card is bad.
if it's a laptop take a flashlight and shine it on the dark screen. If you look real hard you might barely see the icons on the desktop. If, so then your LCD Inverter is bad. If you don't see the desktop with a flashlight, try using a external monitor. If the external monitor displays your desktop, then the video card is good, but more than likely the screen will need to be replaced.
Mar 26, 2012 | IBM Computers & Internet
Gateway ZX4000 all in one - the screen is black
Sounds like the Video Card is bad. Try plugging an external monitor into the laptop and see if it works. Any monitor will do, even the big fat old crt monitors. Look at your keyboard and normally there will be a sequence of keys you will have to hit to get the video on the external monitor. Normally you would bress the FN (Function Key) and hold it while pressing some other key such as F4 or F8. The key to press will probably have a picture of a monitor display on it or the wording crt/lcd
If it displays on the external monitor that means your video card is ok and your screen on the laptop is the problem and either needs to be replaced or it could be that the cables have come loose in which case the lcd monitor needs to be disassembled and the cables reseated.
One other thing, take a flashlight and shine it on the lcd screen to make sure that the icons are not there but are too dark to see. If you can barely see the icons with the flashlight that means the LCD Inverter is bad and needs to be replaced. The guys at: http://www.generalsystemsconsulting.com can help and they are very reasonable. They will fix it and ship it back to you by Fedex or UPS. Get a quote from a local source then try them.
Mar 10, 2012 | Computers & Internet
My laptop screen went very dark, I can barely make out whats on the screen but I know its working. What can I do to fix this situation on my gateway p-6860fx pc notebook?
Hi josue fernan...
You need to see if your laptop lcd screen is faulty and/or the lcd inverer is faulty.
1....Test the lcd screen:
Hook your laptop to an outside monitor and then start your laptop normally...if the picture on the external monitor is good, then your lcd screen is bad.
2....Backlight Faulty: If the monitor is still as dark like your lcd screen on the laptop then it could be the backlight that is faulty.
Please take time to rate me thumbs up
LCD Backlight and Screen Replacements:
http://www.laptopsman.info/0-Gateway-lcd-1.html
LCD Screen replacement:
http://www.screentekinc.com/Gateway_P-6860FX--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Sep 11, 2011 | Gateway P-6860FX Notebook
Gateway model # CX 2618
First test if it works on an external monitor. If it does you will need to clear the CMOS. To clear it:
remove the battery, unplug the cord, and hold the ON button down for 30-60 seconds. Then turn it on. Thats how you clear it on most laptops.
If it does not work on the external monitor, you probally have a bad video card and need to replace the old one
May 26, 2009 | Gateway CX2618 Notebook
When I turn on my monitor I can see the Gateway letters come on the screen but then it just goes dark again. It comes on for a split second and then goes dark again.
joel_herrera, Yes, this is a very common symptom of a failing Switch-Mode-Power-Supply and/or Inverter circuit! Very common in 2-4 year old lcd/fpd's. How old is your's? Do you have warranty? Have you tried the Flashlight test? DO THIS! Reconnect lcd monitor to your fully booted PC with a known good WIN desktop screen. Then power "on" the HD2201 and tell me what happens and what you see or don't see after the screen goes BLACK! Shine a bright flashlight onto the screen at different angles and let me know the results. I'm louie12fix on fixya or lmistyrel @aol.com BYE
Apr 07, 2009 | Gateway HD2201 22" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
2,958 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
