Question about Brother Office Equipment & Supplies
Please fix my printer Brother HL-2040
Paper got stuck in my printer & it started blinking Red Light. To remove the stuck paper, I had to dis-assemble the printer & I remove the stuck paper. I then re-assembled the printer. Now the printer is showing Blinking Red Light, and won't print. Maybe Ireassembled the printer improperly. Please help. I shall be be highly Thankful to you. Krish
Soulvisitor
  • 1113 Answers
SOURCE: Paper Curling with Brother HL-2040
Replace fuser assembly/have fuser unit replaced if you have tried fresh quality paper from a unopened ream. The first versions of these had the fuser and exit assembly modified by brother to help eliminate excessive curl last 9 digits of serial number are higher than D5J760210 have already been modified, if lower ie D4Z99999 need to get mod. fitted.
Posted on Jan 10, 2008
JohnSc
  • 21 Answers
SOURCE: Re: paper jam in brother laser printer hl 2040 : paper red ligh continue to flash
Try shutting the printer completely down & unplug power. then plug power back in and while holding down all buttons on the printer control panel, turn it back on. this should put it into a self diagnostic mode that prints out just about everything the printer can do, including a sample page. Also, be sure all rollers are clean & trays are completely closed before restarting. If the printer works when you do this, you should most liely check all settings in the software package (driver) or perhaps reinstall the drivers. If this is necessary, be sure to download the latest drivers from the Brother website.
Posted on Feb 11, 2008
iqbal_del
  • 655 Answers
SOURCE: free software installation program for HL-2040 multifunction brother printer
here is a link for you
  • Goto above link
  • Select your printer/model
  • Make sign up and download
If any problem, just Ask me.
Please post your feed-back.
Thanks
Iqbal
Posted on Apr 29, 2008
  • 4 Answers
SOURCE: Lost Installation CD for my Brother HL-2040 printer
Go tor HP printer drivers on the net.
Posted on Sep 27, 2008
rscheutz
  • 54 Answers
SOURCE: won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Posted on Mar 25, 2009
Brother HL 20 printer paper jam light keeps blinking after jam removed
Please check paper sensor may e damage, need to relpace it on prior basis
Mar 30, 2013 | Brother HL-2040 Laser Printer
Brand: Brother Model: HL-2040 Problem: cannot print, paper error, red light blink, did not feed paper. What should i do? thanks.
pull tray out load a couple sheets look underneath and see if paper is lifted up when closing paper drawer. If the paper is not raised to the up position you have broken the tray lift mechanism and it is not worth fixing. You can jam an eraser underneath the tray to manually raise the tray to do a dodgy fix.
Feb 28, 2011 | Brother HL-2040 Laser Printer
How to stop red blinking "paper"? couldn't stop
There is probably a paper jam since you shut it off as it was printing. Turn off the printer. Remove the tray and look inside. Remove any sheets of paper you see. Open the back of the printer (the pass-thru door) and remove any paper you see. Turn on the printer. If that fails, check the blink status against the manual's troubleshooting guide to locate a different solution.
Aug 27, 2010 | Brother HL-2040 Laser Printer
I have a Brother HL-2040. The "paper light is on & won't print.
Sounds like a paper jam. There's a flap at the back of the printer-once open you should be able to see if the paper is stuck there. (Exactly the problem I had yesterday-I didn't spot it at first and it nearly drove me mad! :)
Good luck,
Raf
Nov 13, 2009 | Brother HL-2040 Laser Printer
Won't print. blinking red paper light flashing
Mar 25, 2009 | Brother HL-2040 Laser Printer
Suddenly won't print
found paper fanfolded in back, over the drum. Removed paper, still not consistently feeding through but at least I know where the hang up is.
May 12, 2008 | Brother HL-2040 Laser Printer
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
15 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
