Question about Whirlpool Dryers
My Whirlpool Gas Dryer (MDL # LGR7648KQ1) is not drying properly. The unit will heat up initially but after a while it will not ignite. I've taken it apart and run it without the drum. It ignited properly 3 times. With the unit reassembled the dryer will ignite on startup but not reignite through the cycle. I've pulled the schematics http://www.partselect.com/ModelFrames.aspx?ModelID=699153&ModelNum=LGR7648KQ1&mfgModelNum=&ManufactureID=3&Selected=CDJISWIB&Position=0&mfg=Whirlpool&Type=&Mark=0 and just don't know what part I need. Thank you for your help.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Be sure the vent is totaly clear.if the t-stat(s) heat up from lack of air flow the heat will not return until the t-stat is cool enough.Running without the drum in place will also heat up the sensor(s).This is a very common problem.
Posted on Oct 25, 2008
The unit just stopped heating and drying the clothes.The burner on my LP Kenmore dryer won't light, otherwise everything else works just fine. I've have taken everything apart and cleaned out all...
Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty
Jul 28, 2011 | Kenmore Dryers
I have a whirlppol gas dryer Mod-LGR7648KQ1 which runs but does not heat up. I dont know if it's a sensor, the ignitor or heating unit or even the thermostat. It's old and I'm not looking to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 18, 2011 | Whirlpool Dryers
Dryer is not drying igniter coming on but wont stay lit lites once in awhile
heatman101
May 24, 2011 | Whirlpool Dryers
My gas dryer will heat up during initial use. You could hear the gas ignition ocurring. It will heat up and no more heat after a couple of minutes. Checked and cleaned all lints. Please help.
heatman101=-][
Apr 18, 2011 | Whirlpool LGB6300 Gas Dryer
My lgr7648kq1 will not heat up,i see no flame.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 08, 2010 | Dryers
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
I have a Whirlpool LGR4634JQ2 gas dryer, I have checked all the venting from the dryer and nothing is blocked. However, the dryer still does not dry my clother properly. Sometime the heat comes on and...
This free video will walk you thru troubleshooting the problem. Could be a few different things Igniter,coils,heat sensor,thermal fuse, thermostat
Feb 26, 2010 | Whirlpool LGR4634J Gas Dryer
Whirlpool dryer model number lgr7648kq1 won't get
Sounds like one of the cavity switches is bad. Open back of dryer, you will see wires that attach to little clip next to each other. Try jumping wire from one side to the other, do one switch at a time and try dryer to see if heats, if you get heat replace that switch. These switches burn out if dryer gets to hot, usually from to much lint in duct work. Also vacuum out duct work in wall and on back of dryer.
Jun 14, 2009 | Whirlpool Dryers
Initial gas burn does not reignite
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE;
Jul 26, 2008 | Whirlpool LGR7646E Dryer
Need advice!
Okay...here's what you need to do to check out a gas dryer:
This advice is for problems associated with GAS DRYERS that RUN, but DO NOT HEAT. Ensure your dryer ducting is clear and **t clogged, first. ALL dryers require proper air flow in order to dry efficiently. If you do **t have any obvious vent duct obstructions you can follow these simple steps in identifying WHICH dryer heating circuit component may be defective BEFORE you have to disassemble anything. With the dryer plugged in and the gas supply turned on, follow these steps:
PUSH START – Listen for a “click”. You have to listen carefully to hear it. If ** “click” is heard when you push the start button, this is usually an indication of a bad RADIANT HEAT SENSOR.
PUSH START – “Clicking” sound is present, but dryer still does **t ignite. This is usually an indication of a bad IGNITER.
PUSH START – Dryer ignites, but heating circuits shut off after a short period of time. You attempt to restart, but the dryer makes a “buzzing” sound. This is usually an indication of a bad GAS VALVE SOLENOID.
Now, these initial symptom analyses will give you a rough idea of where to begin troubleshooting. These tips are NOT all inclusive, but suited for the more common problems encountered with dryer ignition problems. In theory the dryer ignition works like this – You push the start button and the igniter begins to glow. This igniter will produce a certain current potential (roughly 2.5 to 3.7 amps, depending on type of igniter) and the gas valve will open. Once the gas valve opens, you have ignition. This is a built in safety feature of the unit that prevents free flowing gas inside your home or garage without ignition. If you suspect a bad gas valve sole**id, the dryer usually has two of them. It is recommended that you replace BOTH of them at the same time. If you suspect the igniter to be bad, open the dryer e**ugh to see the burner assembly. There should be a visible glow from the igniter after you push start. If the igniter does NOT glow, replace it. If the igniter DOES glow, take a current reading to see if it is producing e**ugh current. Here are the two types of igniters are their specifications:
Carborundum – cylindrical in shape (2.5 to 3.0 amps)
Norton – Rectangular in shape (3.2 to 3.7 amps)
I hope this information is helpful. Post back if you have any questions/concerns.
PS From the initial indications you gave, it sounds like you may have a bad igniter.
Mar 09, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dryers Logo
228 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
