Dell Alienware M14x Notebook Logo
Posted on Feb 16, 2012
M14x system restore
Monitor is black
Anonymous
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Feb 16, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
28
Questions
Helped
6587
Points
81
Disconnect ac power and remove your battery for 5 min and then reinstall it. This happened to me once and that's what fixed it.
File 5391ada02 can't be found....monitor is black
Pick up a second hand monitor, test your system to see if a signal comes through i.e. you have image on screen. before you do a recovery, perform a back up and restore, to a previous date & time. You may just have a bad monitor.
Alienware M14x stuck on windows starting scren, the video card driver seems to have been disabled
Try going in to Safe mode. This loads the basic drivers and if you have a problem with hardware, it will still open up Windows.
Turn on computer and immediately press F8.
Any hardware issues will show up in device manager.
Is it possible to connect PS3 to Alienware m14x?
I know people who have tried but haven't had much luck. They use a USB capture device in review mode instead but you may get a slight delay on some cheap models but a good quality one is pretty instant.
Hope this helps
Barry
2answers
Alienware m14x battery won't charge
Remove main battery, get a stiff toothbrush and clean battery terminal in laptop and prongs on batteries. Install battery and charge, if no change! rechargeable battery needs to be replaced.
My husband just called me at work and said that our computer monitor is black. He shut it down and got the Gateway logo but then it went black again. Any suggestions?
Please press the f8 key on restarting the system on the gateway logo and see if you are able to reach the windows advanced menu screen that shows the safe mode option.
if yes please selct safe mode and then please restore the system to the earliest back date maybe 2-3 days back.
lick Start click allprograms select accessories click system tools and then system restore, use the option restore my computer to an earlier time and you need to clik on the date which is bold in color i mean a back date then hit next to proceed.
wait till it restart and completes the system restore
Display settings are out of range
you going to go to safe mode and try to restore you system to the date that you not change the video settings of computer just go to start button goto accessories click system tools and click system restore
Acer AL1914 black screen, green light
it sounds like a deleted driver? try getting the driver for the monitor, did you loose the Operating system at some point, if so try a system restore to a date when the computer was working properlly prior to the malfunction. It sounds like it restored you to a time before the driver for that monitor was installed.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
