Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool LSR8233EQ0 Hot water (only) trickles
When selecting hot water to wash, the hot water only trickles into the tub of the washer, taking almost 20+ minutes to fill. The other temps choices work OK. Please advise.
  • mgull3 Oct 25, 2008
    Thanks for your help addressing the hot/cold water inlet valve, however, when I went to the sears website as you suggested, I received two messages: "no exact or partial matches were found" and "sorry, no parts available for this product. Is this machine far beyond its time? What might be my next recourse. Whirlpool model LSR8233EQ0
    I think I found the part sears calls it "Valve- water mixing" (#285805). It looks relatively easy to install. Is it something I can do myself or would I need to call an expert.
  • 1,122 Answers
You need to replace the hot cold inlet water valve on the back of washer,the solinard for the hot water is not opening all the way,this is a common problem on all washer,if you go to sears .com click on parts put in your model number you can get the part and it shows you where it goes,hope this helped you-mike
Posted on Oct 25, 2008
  • MIKE major Oct 26, 2008
    cross check the part you need at repair clinic .com.and you can do it yourself just look at the sears pictures and it will show you the break down,let me know now you do,please try to do it youself as sears charges $85 just to knock on your door-mike
    i went to sears and got the break down,oh guess your right it is called the water mixing valve,this is what you do,remove the 2 screws on the top console one on each end,flip the console up,unplug the jack on the washer cabinet side this will give you just enough room to pull the back panel out alittle to get to the valve remove the screws from the valve on back of cabinet,now use a pair of pliers and remove the 2 hose clamps from the valve,now install the new valve in reverse and your done,i hope this helped you-mike
Cold water trickles into the tub while it is being filled up
The hot and cold water supply hoses that connect the washer from the water supply faucets on the wall to the water connections on the back of the clothes washer usually have filter / sediment screens within there connection fittings at the end of the hoses, these will collect dirt,sand, calcium deposits, etc.,when they trap enough of these materials they will plug up and restrict the flow of water into the clothes washer. Turn off the water faucets at the wall, and you should do this for both hot and cold hoses, disconnect the hoses from the washer and the water faucets, look into the hose ends and pull out the screens and clean them out by running water and what ever you can use to clean them completely!!!!!
Now look inside the water connections on the back of the clothes washer,where you screw the hoses on the washer, and check to see if there are filter screens in there, if there is, remove them and clean out completely also, then reverse the removal process and reconnect the hoses, makeing sure to connect the hot and cold hoses to the right connection on the back of the clothes washer!!
Try filling the washer with water to see if you have corrected the problem.
Make sure hot and cold hoses are correct on the back of the washer!!!!
GOOD LUCK !!!!!!
Aug 03, 2010 | Whirlpool Washing Machines
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
The cold water trickles in to fill the tub
sounds like you have checked the water coming out of the cold water so the fill valve requires replacement
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer wont allow cold water
Mixing valve should lock out the hot water when on the cold water setting. Either your hoses are crossed, or the mixing valve is flipped. To see if one of these is true, try it on a hot water setting to see if cold water comes in, or try just swapping the water hoses.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't aggitate or spin.
your water pressure tube is clogged at the tub. Take the back of the control panel off and blow or a small balst of compressed air down this tube and try the washer again. Powder detergent clogs this tube at the bottom of the tub and does not tell your pressure switch to shut the water off at the proper level thus overflowing your tub.
Feb 01, 2009 | Whirlpool LSR5132PQ Top Load Washer
Hot Water won't fill
I like to put the hose over in the tub and run some water just to eliminate plumbing problems from that point back. Then, I check the inside of the water valve where the hose connects which you have done. If all this is ok the only thing left is to replace the water valve. I have had some success taking the water valve apart and cleaning it out. About 2 out of 10 will start working but most require replacing.
Jan 24, 2009 | Maytag Washing Machines
Hot water trickles into the tub
if screen inside fill valve is clean and plenty of hot water to valve replace valve
Nov 15, 2008 | Speed Queen AWS52NW Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
255 people viewed this question
Dan Webster
Dan Webster
Sal De
