Question about RCA P60921 60" Rear Projection Television
60 in RCA rear projection making a chirping noise no picture no sound
  • RCA Master
  • 8,617 Answers
Chirping is almost always caused by the HOT transistor and Flyback transformer. You can get the Flyback with HOT repair kit for your model from www.tvrepairworld.com they are listed under the RCA Repair kits.
Posted on Feb 16, 2012
techman
  • 3130 Answers
SOURCE: Please Help!
A chirping sound from a TV set is the switch mode power supply trying to start up, but gets shut down because of a major short inside the set or in one of the circuits.. Most likly in this set, the horizontal output transistor is shorted because of a defective flyback transformer. Thats whats the common problem is with this set. A repair like this, if this is the only parts that are bad, will run you about 300 to 400 bucks or so. In some cases, not many but a few times, I have seen poor solder connections on L401 cause the horizontal output transistor to go bad. There are no user replacable parts inside this set, so please play it safe and seek out a pro to assist you in this repair. Good luck PS Please do not forget to rate this thread.
Posted on Dec 11, 2006
SOURCE: No picture or sound - TV makes chirping noise
The chirping sound is the power supply trying to come up, but can't due to a short or other condition. Open up the set and see if there is any obviously bad (burned) components.
Posted on Jun 27, 2007
  • 185 Answers
SOURCE: RCA P60921 60 in. Rear Projection not working
could be the flyback as some eat them depends on how old it is, and what model it is be more specific. also possible high voltage divider box
Posted on Nov 11, 2008
ladywinn
  • 5138 Answers
SOURCE: RCA Rear projection had a 3-d like picture. one red one blue and
Go to menu then setup if you do not see convergence on menu then FL231 is open replace it then do auto convergence.
Posted on Feb 13, 2009
  • 18 Answers
SOURCE: 52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
Posted on Feb 25, 2009
Turn the TV on and it just make a chirping sound no picture
Without examing the set. IN general as a techs when they hear chirping noise is an indication of what is know as a Bad Flyback transformer; You may possibly have a shorted Horizontal Output Transistor or both that will need replaceing.
Apr 24, 2009 | Philips 60PP9352 60" Rear Projection...
No picture/ chirping noise
Common problem with this model. Goto www.TvRepairKits.com for a kit with instuctions.
Jan 30, 2009 | Philips 60PP9401 60" Rear Projection...
Black screen and chirping sound
Typically, the driver circuit is affected when the flyback transformer "dies". The most common device that fails with it is the deflection transistor/driver and associated components. Hope this helps...accordianman
Dec 06, 2008 | RCA P60920BL 60" Rear Projection...
I just purchased a used RCA P60920BL 60 in. Rear Projection Television. It worked for the first 3 days and then just went black and started making a chirping sound. I read a bit online and seemed to be the...
Right in front of the flyback, on a metal heatsink, you will see a transistor. This is the Horizontal out transistor ans is probably shorted. Look at number on the front of the transistor for ordering. It will be 2SC5148, 2SD1878, or something like that.
Make sure the unit is unplugged while working on it
No picture, no sound, just chirping noise coming from back
NO - - signal did nothing to the set... Sounds like a shorted HOT (horizontal output transistor) and the feedback your hearing (chirp) is on the horz. transformer as it tries repeatedly to startup... Don't allow it to do that for too long...
Bill
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
The chirping sound is the power supply coming up then breaking down because there is a short somwhere in the high voltage. The most common fail in this area is the horizontal output is shorted ( 237470 ) but what cause this short could be simple cold solder joints or the High voltage transformer ( 239111 ) If you have noway to "ring" the flyback change both parts
Feb 13, 2008 | RCA Scenium D40W20 40" Rear Projection...
RCA 52 rear projector tv makes chirpping noise wont turn on
You have a bad high voltage transformer. It is the white square device about 3inch square with large red wire coming out. Must be replaced with RCA original NO GENERIC. Also the horizontal output transistor must be checked to see if it is good. Recommend honest qualified tv repairman
Dec 30, 2007 | RCA P60921 60" Rear Projection Television
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rich that chirpin noise is somthing over loding it try checking your horzotal output for short and diodes around the transformer...
May 20, 2007 | RCA P60921 60" Rear Projection Television
Clicking noise,but not power
Replace the H.O.T. (Horizontal Output Transistor)
Feb 18, 2007 | RCA P60921 60" Rear Projection Television
RCA P60921 60" Rear Projection Television Logo
75 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
