Question about Dell Computers & Internet
My latitude D505 the screen is blank with a cerser on the top left corner of the screen. I tried turning on/off but the same. Any ideas?
When system was working did you have a pop up saying you have a virus and if so did you click it.if you did you now have a nasty virus took out my daughters computer the virus got on the motherbaoard then you have to call dell if this happened.if not take ram out blow out connecters.it might be shorting out.or your hard drive is out
Posted on Feb 16, 2012
Geekman
  • 32281 Answers
SOURCE: Dell Latitude D800 Boot Problem
Did the diagnostics pass the RAM and the hard drive.
You should check the BIOS settings to see if the hard disk is detected, if possible reset the BIOS back to the default settings and see if the computer boots up.
If not :-
Then it appears that the operating system is either corrupted or system files were deleted or infected with viruses.
Your only option is to do a operating system repair or a complete new install of Windows.
I recommend you do a new install.
Posted on Nov 23, 2008
SOURCE: dell latitude d505
mine did the same thing cleaned and blow out the battery connector on the battery and laptop....fixed
Posted on Feb 21, 2009
jilpeshpatel
  • 259 Answers
SOURCE: install dell latitude D600 keyboard on dell Latitude D500
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?c=us&l=en&s=gen
you have click this link and after Service Tag numberm add and collect your manul for your laptop
Posted on Mar 27, 2009
  • 202 Answers
SOURCE: Latitude d505 won't display image through
Dell laptops normally have a 3-way toggle for the display destination: 1=screen 2= external display and 3=Both. To toggle from one mode to the next press hold the 'FN' key (lower left corner of the Key board), and the briefly press the 'F8' key. Wait a few seconds for the hardware to catch up and you should see a display through the projector. If not, repeat the 'Fn' + 'F8' combo again.
You could also try running diagnostics to verify that teh video card is working properly. To do that, sthar with the laptop off. Hold the 'Fn' key down while you press the power button. Release both as the machine begins to boot up. It should start in diagnostics mode. Run the quick test and watch for the color bars. If you see then, the video card so=huold be OK.
Good luck, And please let me know how it turns out for you.
~ Spoem
Posted on Oct 01, 2009
Testimonial: "Thank you! Actually the Fn - F8 trick had been tried but we were too impatient. Will keep the diagnostic mode info for future use."
bahratt
  • 561 Answers
SOURCE: Need to get password removal for an dell latitude
If you have forgotten your BIOS or Hard Drive Password for this model, there is a master code that you can obtain from Dell Support. Simply call, Email, or use Online Chat from http://support.dell.com and give them your Service Tag, and they can help you out from there. If it is a Windows profile password you have forgotton, try accessing the Administrator account from Safe Mode (Press F8 at startup), and remove the password for the user account from Control Panel, User Accounts.
Posted on Jan 08, 2010
Dell Latitude D505 half of screen is black with colored vertical lines.
Sounds like you have a section of dead pixels. This can happen if the laptop has been dropped a lot or stepped on or some type of impact on the laptop. This is a hardware issue. You will need to have the screen replaced. In my opinion, by the age of the laptop, its better off getting a new one.
Oct 01, 2014 | Dell Latitude D505 Notebook
My Dell D505 Latitude will not power up. The 3 green lights flash for less than a second and then it switches off. It was working fine until a few days ago. Any ideas of how to fix this as all my work is...
Sounds like ether a blown power supply. That happens when the laptop battery has alittle juice left.
Try to take out the battery from the bottom and plug the laptop in the wall. If the laptop powers up you battery needs to be replaced. If it doesn't power up, you need to replace the power supply.
Good Luck,
jsgrepair@co.nr
Aug 23, 2011 | Dell Latitude D505 Notebook
When i power up my dell latitude d505 i get the 3 lights next to the power switch then it turns off any ideas how i can fix this
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Sep 16, 2010 | Dell Latitude D505 Notebook
When i turn on my dell latitude D505 the backlight
Either the video cable has been damaged or unplugged or the video processor is malfunctioning. Check this by connecting an external monitor. If the video is all there then press the Fn(function) and F4 key. This should switch the video from the external monitor to the internal screen. If this doesn't happen or if the external monitor shows no video then the laptop needs to see a reputable repair perso or check my website www.micromendllc.com
Feb 25, 2010 | Dell Latitude D505 Notebook
Latitude d505 won't display image through projector. Being used with Sanyo plc XU41 and Promethean board. Board is interactive but no help if there is no image to see! Other Dell laptops work with this...
~ Spoem
Oct 01, 2009 | Dell Latitude D505 Notebook
Computers & Internet Logo
27 people viewed this question
Alun Cox
