Question about Bosch Axxis WTA 3510 Electric Dryer
Bosch WTM C3300 Dryer
Dryer "lint filter" blinks and when you push the start button, it will not start. I pull the power supply and leave it for an hour or so. I plug it back in and then it will start. The next time I try to use it, it won't start. I pull the power, wait, plug it back in and then it starts. There is no lint in the filter and the exhaust is clean. We've cleaned the moisture sensor with vinigar. Any help would be appreciated. Thank you.
    Problem Solver:
  • 7 Answers
I don't own this model of the Bosch dryer, but my guess is that your hot air flow path is partially blocked with lint or something else. Our heating/air flow element was blocked with a errant latex club hit the elements. I cleaned the flow path and removed the heater obstruction with good results for nearly a year to date.
Posted on Feb 25, 2009
I own a Bosch Nexxt Series Electric Dryer, the clothes come out with a petrolium smell, grease or something. I have cleaned the trap, duct work, bearing shield to no avial. It is not the washer, the
Instructions
Dryer Does Not Turn On
Ensure that the dryer's power supply cord is firmly plugged into an electrical outlet.
Inspect the structure's fuse box for a tripped fuse. Each fuse is assigned a single "On/Off" switch. If any fuse switch is in the "Off" position, flip that switch to the "On" position. If the problem persists, contact a professional electrician.
Press the "Start/Stop" button on the left side of the dryer's control panel.
Close the dryer door firmly so that the door clicks into place. The dryer will not operate if the door is not shut.
Lint Filter
5
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull the lint filter out of the dryer. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then reinsert the filter and close the door.
6
Turn the dryer off and allow at least 30 minutes for the dryer to cool, as excessive heat can cause a drying program malfunction.
7
Increase the ventilation of the room the dryer is located in, such as by opening a door or window. Excessive heat will cause the dryer to automatically turn off until it cools as a safety measure. Increasing the ventilation will help keep the dryer cool.
Clothing Not Fully Dry
8
Clean the moisture sensor. Open the dryer door to access the moisture sensor. The black-colored sensor consists of two bars, and is located at the front of the dryer's tumbler, to the left of the lint filter. The sensor should be cleaned with a clean cloth and white vinegar once per month.
9
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull out the lint filter. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then insert the filter back into the dryer and close the door.
10
Spin the laundry at a higher spin speed in the washing machine before placing the laundry into the dryer to reduce the moisture content.
11
Turn the dryer off and allow at least 30 minutes to pass for the dryer to cool, as excessive heat can cause a drying program malfunction.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Dryer will not start. lint filter flashes 5 times and then goes
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 11, 2010 | Bosch Nexxt WTMC 6500 Gas Dryer
The Bosch dryer will light up but will not start when I push the flashing light button to start. I have reset the breaker and I have rubbed the sensors with a damp cloth. I have cleaned the lint filter.
The start button wears out on these. This is what happened to me. If you take a screw driver to make conneciton of the top of the start button, it should kick on. May take a second or two holding it there before it starts.
Jun 23, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt 800 series dryer E01 error
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
Jun 14, 2009 | Bosch Nexxt 500 Plus Dryer
Bosch Axxis Starts and stops
The lint light keeps coming on and shuts the dryer off so clothes are not dry. I checked the filter and it is clear. Now the bottom of filter is cracked (plastic part) so I need to replace. But why does the lint light come on now after 5 years of use? It never came on before even when the lint filter was full?
Apr 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch dryer lint light flashes
My Bosch Nexxt electric dryer had the same problem with the lint filter light blinking and the dryer not running. It turned out that the door switch was not engaging. The service technician informed me that there is a plastic tab (available only by opening the top access panel) that was not fully snapped in place. When he snapped the tab back in place and then secured it with a screw, the door switch fully engaged, the lint filter light went out, and the dryer ran perfectly! I hope that helps you!
Feb 28, 2008 | Bosch Dryers
Bosch Dryer lint filer warning
The Bosch Dryer has a temperature probe in the heater exit and in the exhaust area visible when you open the door. If the temperature difference between the two gets to high, the lint filter is assumed to be plugged and the alarm goes off.
It seems that the temperature probe at the heater, can end up with a faulty connection to the control panel over time due to corroded contacts or lint build up. When this happens the control panel thinks the filter is clogged and it may also not turn on the heating elements properly. Remove the back cover over the heating element (12 screws) and then remove the one screw holding the red wiring connection to the dryer body. You can then wiggle out the wiring connection and clean / unplug and replug in the connector for the sensor. (plug with two small wires only). A little hard feeding the connector back through the hole so take your time and don't damage the wires). Should all work again. May want to inspect inside the heater at same time and make sure the overheating switch is not tripped. ( press in the red button).
May 21, 2007 | Bosch WTMC3510UC Gas Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
190 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
