Question about Toshiba SD-6915 Multi-disc DVD Player
Remote codes for toshiba sd-6915 - Toshiba SD-6915 Multi-disc DVD Player
Need codes for he universal remote to program to Toshiba DVD player SD-1800
Use the code search provision of your universal remote to seek a suitable code. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Jun 03, 2016 | Toshiba SD-1800 DVD Player
Remote menu button not working
Sometimes you can enter a code that will work nearly all the buttons, but is not the correct code for your DVD player. You should try other codes. But sometimes a universal remote will NOT work every function.
Dec 22, 2012 | Toshiba SD-V392 DVD Player/VCR
I need remote control codes for toshiba sd-k620
Checkout http://manualfox.com/remote.htm - just send them the model numbers of remote and player and they will come back with a solution.
Jul 23, 2009 | Televison & Video
Trying to program comcast remote to work with my toshiba SD-V290. Need the remote code???
http://www.comcast.com/corporate/customers/customer_support/remotes.html go there and click the remote your using and then find the brand and get the code
Jul 12, 2009 | Toshiba SD-V296 DVD Player/VCR
I need to program a universal remote for a Toshiba SD-K510.
it is 1110 the code for Toshiba SD-K510 it works on mine Toshiba SD-K510 the code on mine universal remote
Jun 07, 2009 | Toshiba SD-K510 DVD Player
No color
Make sure your av channel say`s av2 not av2s as this can give b/w pic.hope this is of some help
Mar 31, 2009 | Toshiba SD-6915 Multi-disc DVD Player
NEED TV CODE TO REPROGRAM MY REMOTE
Hi
Had the same problem but found a similar looking remote for the SDV593SU online and the codes work!
http://tv.manualsonline.com/manuals/mfg/toshiba/sdv593su.html
Cheers!
Michele
Nov 08, 2007 | Toshiba SD-V392 DVD Player/VCR
Region free?Toshiba SD-140E
Put DVD into player - wait for regional code violation screen to appear. Once this happens press the M (Memory) button on your remote control. Then press 1 for Title 1 and press play on the remote. This will over-ride the regional code violation detection menu and you can watch the movie etc by entering the fwd on the remote control and change chapters etc by using the T (Title/Chapter) button on the remote control)
I found this for other Toshiba SD dvd players, yours was not listed but might be worth a go.
Oct 25, 2007 | Toshiba SD-140E DVD Player
Toshiba 5 disc DVD changer SD-6915SU (no audio)
I had a simular model with almost same problem several years ago. I use a high quality CD/DVD cleaning kit at first. That helped but didn't slove the issue completely. Then I opened it, saw how simple its put together. I blew it out really well with an "air can duster". Especiallly around the "read head" being carefull not to get the head too cold, it will crack. Then I re-soldered a few of the solder joints I could get to easily. What ever I did, did the trick. Soldering may have been excessive. Ended up giving it away when I got a new one. If you know how to solder its worth the try but try other steps one first.
Jul 16, 2007 | Toshiba SD-6915 Multi-disc DVD Player
Toshiba SD-6915 Multi-disc DVD Player Logo
41 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
