Question about HP LP3065 TV
Hp lp3065 grays too dark - HP LP3065 TV
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
1999 dodge truck speaker wire coler picture diagrame
2010 Dodge Ram 2500 Car Audio Installation Guide
Left Front Speaker Positive Wire (+): Gray/Violet
Left Front Speaker Negative Wire (-): Gray/Yellow
Right Front Speaker Positive Wire (+): Dark Green/Violet
Right Front Speaker Negative Wire (-): Dark Green/Yellow
Left Rear Speaker Positive Wire (+): Gray/Dark Green
Left Rear Speaker Negative Wire (-): Gray/Light Green
Right Rear Speaker Positive Wire (+): Dark Green/Gray
Right Rear Speaker Negative Wire (-): Dark Green/Light Green
Jun 29, 2012 | Cars & Trucks
Screen goes black for a second or two every few minutes
This indicates the inverter transformer is going or a capacitor issue.
May 08, 2012 | HP LP3065 Monitor
LP3065 White Screen. Possible to repair?
Please check on the link below for location of the nearest center:
http://www8.hp.com/uk/en/home.html
Dec 06, 2011 | HP LP3065 LCD Monitor
Monitor grays too dark
That means that the inverter board is faulty and myst be replaced.
The inverter board is an high voltage board that supplies AC power to backlight system. when inverter is faulty, you will get an extremely dark picture.
Parts must be tested before replacement.
Sep 11, 2009 | HP W2338h 23 in. LCD TV
Prints dark page
Try to change toner cartridge, I had this happen with my old laserjet 5, and it was a faulty cartridge on mine.
Aug 16, 2008 | HP LaserJet 2550L Printer
HP 2420dn printing gray and shadows
maybe the scan unit need to clean first you most sure that the toner cartridge is original and new then start clean th scan unit reflector d9b88f3.jpg
Mar 12, 2008 | HP LaserJet 2420dn Printer
HP 2600N dark gray line down the left side
Maybe your transfer belt is damaged. If u have an spare belt replace it for a test. Answer me if it dont work. Maybe i can get an support manual for u. I work in a HP partner company.
Good luck
Dec 15, 2007 | HP Color LaserJet 2600n Printer
HP LP3065 TV Logo
Top HP Televison & Video Experts
Tony
Computer Links
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
