Question about McCulloch Garden
Mcculloch electric chainsaw em 235
Motor runs. Chain works for a few minutes and then goes slowly or stops
  • 35 Answers
SOURCE: Chainsaw chain won't move on 16" Homelite bar
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
Posted on Dec 31, 2008
revskank
  • 203 Answers
SOURCE: McCulloch chain saw pro Mac 10-10
if you are using McCulloch oil 40:1
Posted on Mar 02, 2009
dontbother10
  • 2220 Answers
SOURCE: how to remove clutch. McCulloch 438 chainsaw.
I think its an outboard clutch, use this as a guide. A YouTube video shows the procedure using a Husqvarna 350 here:
http://www.youtube.com/watch?v=cdqkIuVNUQc
1. I cannot find an IPL for your saw, it may require special tools.
2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and be cut when the piston rises.
3. It is probably a left handed thread (tighten it to loosen it).
Let us know how it worked for you. GL
Lou
Posted on Sep 10, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a McCulloch Electramac 416 electric
She is English? You can download a manual here:
http://weborder.husqvarna.com/order_static/doc/MIPL/MIPL2003/MIPL2003_VP0303014.pdf
There are 3 please ensure this is your saw.
McCulloch International
http://www.mcculloch.biz/
Using this IPL as a guide it appears reasonably simple.
I'd ensure it is unplugged, the chain brake disengaged, and try to move the chain by hand (gloves are a good idea). If you can't move the chain or the clutch cover seems stuck use the "Service Locater". If you can move the chain; remove the clutch cover, loosen the bar and remove the chain. I see no reason the saw cannot be operated for short periods without the clutch cover to aid in isolating the problem. She will oil your mate won't be happy if you oil the table. GL
Lou
Please let us know the outcome. It helps us help others.
Posted on Sep 17, 2009
  • 583 Answers
SOURCE: my ryobi chainsaw rcs 2040 keeps stopping but
RYOBI----- with the motor running at high revs the chain stops indicates that the sprocket behind the centrifugal clutch is worn out or the centrifugal clutch itself ,or the clutch shoes are worn out the way to tell is to remove the bar and chain and have alook where the chain was conected to the saw, i think you will see the sprocket is buggered and as that is attatched to the clutch drum that will have to be replaced along with clutch springs and shoes, i think you have been running the chain a bit too loose or not running it at realy high revs ,which is what they are designed to do ,cme back to me if you feel the need
Posted on Sep 21, 2009
Mcculloch MS 1415 electric chain saw throws chains
I had a saw that did that and found my blade the chain runs in was bent. Another problem was the groove the chain goes in had a gouge that did not look like much but was just enough to throw the chain. Also check the drive sprocket and make sure it lines up with the groove in the blade the chain runs in.I replaced the blade and its ok now.
Sep 15, 2015 | McCulloch Ms1415, 14" Chainsaw Chain 49dl...
I need to know which oil type goes into the oil chamber for the chain on a mac 3200 gas chainsaw, not the mixture...thanks
There really is no exact type of oil that goes into the chain and bar oiler. Each manufacturer usually makes their own, but any chain and bar oil will work. It is a thicker type of oil unlike a motor oil. Just ensure that the bottle says "bar and chain" oil
May 02, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I have a Mcculloch electric chain saw model 235 for which is not pumping oil onto the chain. Can you please advise where I can purchase a new oil pump Regards Darryl.
This is a full strip, and split side covers to get to the pump, this may well be a job for the local repair agent, having been apart it should then be PAT tested to ensure the double insulation it still good.
Mar 20, 2011 | McCulloch 14" Electric Chain Saw Mcc1514
Mcculloch EM250-14 RPM Slowed suddenly
The chain must be properly sharpened to cut efficiently and the oil pump must be feeding oil to the chain/bar. Check the oiling by running the saw with the bar tip near some cardboard for a few moments--it should throw off a thin line of oil on to the cardboard. If not, remove the bar and chain and run the motor for a few moments--it should ooze oil out of a side port that exits near the drive end of the bar. If still nothing, check the oil tank filter for plugging, then the oil pump itself--it may have a plastic gear that has stripped it's teeth. Once you get oil from the side port, clean the oil passages in the drive end of the bar, and reinstall the bar and chain. Hope this helps!
May 26, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Just got MCC4516F chainsaw.Used it for 30 mins. Stopped working. Chain brake does not engage or release. Chain does not move. Motor runs but will not engage to make blade move. Seems like chain brake...
You have obviously jammed or broken the chain on the inside of the motor. Take it to be repaired, or try reparing yourself by opening up the engine casing yourself.
Nov 19, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Need an owners manual for cs 38 em 38cc chain saw from mcculloch
Contact Us
All McCulloch Products
1 (800) 521-8559
Good luck with an Owner's Manual
Please have your saw within easy reach.
Oct 24, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Runs for few minutes, then stops.
Try replacing the fuel fiter... may be blocked
Sep 08, 2009 | McCulloch Garden
My McCulloch Electric Chainsaw model 450s_15 runs for a few minutes then quits. Does this saw have some type of thermal protector? If not is there any idea what may be causing this malfunction
Remove the bar and chain. Does the motor run and not quit? If not, inspect the motor for sawdust plugging the vents and check the brushes for condition and length. If runs ok, check the side port for oil coming out. If ok, clean all of the holes in the drive end of the bar including the two small holes that pass oil to the chain slot. Use compressed air if available. Also, clean the chain slot all around. Oil the sprocket tip if the bar has one. Adjust the chain so that it moves freely, but doesn't droop from the bar.
Aug 06, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Unit works but chain stops when pressure applyed, what oil goes resevior.
Does the motor continue to run when chain stops? Electric saws usually don't have a clutch, so I would look for badly-worn chain sprocket, or a possible sheared key in the sprocket hub, or a loose mounting nut. Remove the chain and bar, try to turn the sprocket by hand (wear good gloves). There may be some type of overload clutch built into the sprocket.
May 09, 2009 | McCulloch 10" Electric Pole / Chain Saw
How can I get a manual for a McCulloch 235 chain saw?
Call 1-800-521-8559 and ask for parts, then ask for a PDF user manual to be emailed to you.
Nov 03, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
26 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
