Question about Singer 7462 Mechanical Sewing Machine
Bobbin won't wind, beeps w flashing lights
I'm trying to wind the bobbin. It barely starts, about 3-4 revolutions, then stops, the machine starts beeping, and all the red lights flash. I can turn it off and start again... same thing happens. The machine's not new, but hardly used.
  • irig Feb 13, 2009
    i have exactly the same problem!
  • 192 Answers
SOURCE: Needle & Bobbin out of sync
This description sounds like the machine is out of time. The needle should match up with a cut out section in the bottom of the bobbin area. If it is hitting, the timing has slipped, probably from sewing on a fabric that was too heavy for the machine.
Posted on Nov 14, 2007
textile
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
dupina
  • 110 Answers
SOURCE: Bobbin won't wind Singer 7422
Your problem lies with the main shaft that is to tight to release the bobbin winder mechanism, because of old grease and oil becoming sticky. A short term solution will be to remove the needle, in order not to hurt you, and then hold on to the needle bar with your left hand, while engaging the bobbin lever with your left hand. This will prevent the main shaft to rotate and your winder should work. In the long term, take it to your dealer to clean the oil and grease. You will not be able to open the machine casing yourselve, as you might damage the casing and or electronics.
Posted on Nov 11, 2008
  • 3 Answers
SOURCE: Bobbin is not winding correctly
slide plate may be worn - i had the same problem. try holding down the center of the bobbin with a pin while slide plate is in the winding position.
Posted on Mar 03, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
Trying to rewind bobbin machine starts beeping and stops
Is the bobbin pushed over to engage the stop
Oct 01, 2017 | Sewing Machines
Bobbin winder is engaged and shows up on screen correctly, but sewing mode is still engaged and bobbin winding keeps stopping.
check the drive knob on the end of the machine
it should be loose when winding a bobbin
if it is tight or seized then that will drive the needle
Sep 20, 2015 | Janome Sewing Machines
Why won't my bobbin winder work
It could be the belt has snapped, or something else it out of adjustment. You can either get it fixed, or purchased an inexpensive bobbin winder for under $25 from WalMart online.
Oct 18, 2014 | Singer Advance 7422 Electronic Sewing...
My singer curvy starts beeping and lights flashing and won't sew
I just got mine to stop flashing lights and function again when I unplugged the cords from the machine and let it sit for a minute. You can always give that a try.
Dec 20, 2012 | Singer 8763 Curvy
Needle is moving when bobbin is winding & lights are flashing
Check the clutch at the knob on the right side of the machine, where you tighten it to sew & loosen it to wind a bobbin. It could be very loose and when you start to wind a bobbin, it tightens itself up.
Apr 06, 2009 | Singer 7436 - INGENUITY
Singer 7444 won't wind the bobbin... please help...
I guess the machine was defective, i trade it to the new one, and the bobbin worked fine...
Dec 26, 2008 | Singer 7444 Mechanical Sewing Machine
How can I get the bobbin to wind on my singer 7422?
Your machine could be defective. Take it back where it was purchased.
Apr 18, 2017 | Singer 7422
Singer 7462 Mechanical Sewing Machine Logo
395 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
