Question about Gateway Computers & Internet
No sound. Have checked mute button, speaker connections on computer and control buttons on keyboard. Control panel indicates everything is working - still no sound
Have you accidently installed another sound driver my friend had same problen i rolled back the driver and it worked fine
Posted on Oct 25, 2008
Check the BIOS Setting.. some mainboards have HD Audio set as default, but only have ac97 hardware.
Where is mute button on model 5189 keyboard. sound does not come on. speakers wires seem to be installed correctly. Trouble shooting guide said mute button may have activated.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 24, 2011 | Audio Players & Recorders
Tip
How to diagnose and fix sound problem for a desktop or a laptop
Check the Speaker Connections and Volume Control Settings
Step 1
Verify that the lack of sound is not due to faulty speaker connections. A simple way to test it is to substitute the speaker connection with headphones and see if you get any sound.
Step 2
Open the volume control window by clicking your "Start" button and then "All Programs." Click "Accessories," then "Entertainment," then "Volume Control." Alternatively, just click on the speaker icon that's in your System Tray.
Step 3
Check the volume and mute settings. If any of the mute check boxes have been checked, uncheck them. If this doesn't work, read on.
Perform a System Restore If Necessary
Step 1
If the sound has been audible from your computer's speakers and is suddenly lost, you may need to perform a System Restore. Click on the " Start" button and then "All Programs."
Step 2
Click on "Accessories," then "System Tools," then "System Restore."
Step 3
Complete the System Restore Wizard. If this doesn't work, read on.
Delete and Reinstall the Original Sound Drivers
Step 1
Deleting and reinstalling your sound driver may resolve the problem. Your sound driver may have been corrupted or may be missing. The result of this is that the restore utility menu won't be available. For Windows XP, follow these steps.
Step 2
Click on your "Start" button. Click on "Control Panel" and then "System." Next, click on "Hardware," then "Device Manager, then "Sound, Video and Game Controllers."
Step 3
Click on a sound device named in the Device Manager, and then press the Delete key on the keyboard. Click "OK" in the window that appears. Remove all the listed sound devices i this way EXCEPT Audio Codec and Legacy Audio Drivers.
Step 4
Restart your computer. Reinstall the deleted drivers using the Driver and Application Recovery CDs that came with your Windows XP system.
Step 5
Visit your computer manufacturer's official website. Check for any updated sound driver software for your sound card. If any, download them along with the installation instructions.
on Jul 19, 2010 | Audio Players & Recorders
Pc sound is not working right now hepl me
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 20, 2011 | Computers & Internet
THERE IS NO AUDIO SOUND IN MY MACHINE. WHAT TO DO
1 Verify that the lack of sound is not due to faulty speaker connections. A simple way to test it is to substitute the speaker connection with headphones and see if you get any sound. 2 Open the volume control window by clicking your "Start" button and then "All Programs." Click "Accessories," then "Entertainment," then "Volume Control." Alternatively, just click on the speaker icon that's in your System Tray. 3 Check the volume and mute settings. If any of the mute check boxes have been checked, uncheck them. If this doesn't work, read on.
1 If the sound has been audible from your computer's speakers and is suddenly lost, you may need to perform a System Restore. Click on the " Start" button and then "All Programs." 2 Click on "Accessories," then "System Tools," then "System Restore." 3 Complete the System Restore Wizard. If this doesn't work, read on.
1 Deleting and reinstalling your sound driver may resolve the problem. Your sound driver may have been corrupted or may be missing. The result of this is that the restore utility menu won't be available. For Windows XP, follow these steps. 2 Click on your "Start" button. Click on "Control Panel" and then "System." Next, click on "Hardware," then "Device Manager, then "Sound, Video and Game Controllers." 3 Click on a sound device named in the Device Manager, and then press the Delete key on the keyboard. Click "OK" in the window that appears. Remove all the listed sound devices i this way EXCEPT Audio Codec and Legacy Audio Drivers. 4 Restart your computer. Reinstall the deleted drivers using the Driver and Application Recovery CDs that came with your Windows XP system.
Dec 31, 2010 | Intel Computers & Internet
I can not get a sound in my computer
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 31, 2010 | Computers & Internet
No sound
No-Sound Problem?
Instructions!
Things You'll Need:
  • Driver and Application Recovery Cd's
  • Updated sound driver software
Open the volume control window by clicking your "Start" button and then "All Programs." Click "Accessories," then "Entertainment," then "Volume Control." Alternatively, just click on the speaker icon that's in your System Tray.Check the volume and mute settings. If any of the mute check boxes have been checked, un-check them. If this doesn't work, read on.
Restart your computer. Reinstall the deleted drivers using the Driver and Application Recovery Cd's that came with your Windows XP system.
Oct 17, 2010 | Systemax AOL Optimized PC (100607) PC...
No audio
No info on model etc
Oct 15, 2010 | Computers & Internet
Have no sound and all speaker are on
There are a number of different reasons why your computer may no longer give sound. If you have this problem, read on to learn how to diagnose the problem and resolve your PC's loss of sound
  1. Step 1 Verify that the lack of sound is not due to faulty speaker connections. A simple way to test it is to substitute the speaker connection with headphones and see if you get any sound.
  2. Step 2 Open the volume control window by clicking your "Start" button and then "All Programs." Click "Accessories," then "Entertainment," then "Volume Control." Alternatively, just click on the speaker icon that's in your System Tray.
  3. Step 3 Check the volume and mute settings. If any of the mute check boxes have been checked, uncheck them. If this doesn't work, read on.
  4. Perform a System Restore If Necessary
  5. Step 1 If the sound has been audible from your computer's speakers and is suddenly lost, you may need to perform a System Restore. Click on the " Start" button and then "All Programs."
  6. Step 2 Click on "Accessories," then "System Tools," then "System Restore."
  7. Step 3 Complete the System Restore Wizard. If this doesn't work, read on.
  8. Delete and Reinstall the Original Sound Drivers
  9. Step 1 Deleting and reinstalling your sound driver may resolve the problem. Your sound driver may have been corrupted or may be missing. The result of this is that the restore utility menu won't be available. For Windows XPmag-glass_10x10.gif, follow these steps.
  10. Step 2 Click on your "Start" button. Click on "Control Panel" and then "System." Next, click on "Hardware," then "Device Manager, then "Sound, Video and Game Controllers."
  11. Step 3 Click on a sound device named in the Device Manager, and then press the Delete key on the keyboard. Click "OK" in the window that appears. Remove all the listed sound devices i this way EXCEPT Audio Codec and Legacy Audio Drivers.
  12. Step 4 Restart your computer. Reinstall the deleted drivers using the Driver and Application Recovery CDs that came with your Windows XP system.
  13. Step 5 Visit your computer manufacturer's official website. Check for any updated sound driver software for your sound card. If any, download them along with the installation instructions.
May 18, 2010 | Computers & Internet
Hp pavilion dv9005us NO sound problem
you may want to check to see if the speaker wire is connected to the audio board. You'll need to remove the Keyboard, palm rest, etc. It should be located toward the front of the LT.
Jan 06, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
62 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
