Amana PTC123B35AMBP Digi smart Display Doesn't light up . Board has 220volt and 24volt. Is the board Bad are the push button controller. Also there is a transmitter connected to digismart Board. would this interfer with the control and operation.
  • 86 Answers
SOURCE: Amana PTC153A50AD Electric Heater
1. copressure not working.
2 check spare parts of a/c.
3 wiring
Posted on Mar 17, 2008
  • 3422 Answers
SOURCE: I have a Maytag QuietSeries
HI,
Just visit this link HERE and your problem will be solved.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 04, 2008
  • 9 Answers
SOURCE: Lights are on, but wont start
The water pump can hum and still have a defective coil.
Posted on Aug 31, 2008
  • 5 Answers
SOURCE: The controller board for my Duo-Therm has a bad
Radio shack should have a transformer that will work bring the board in with you. Also try R.V. junk yards they have a lot of good used parts off of wrecked rv there is one on lincoln in Phoenix a many more go online and look up used rv parts.
Posted on Jul 08, 2009
t1m130
  • 86 Answers
SOURCE: Rheem Criterion II - blower works OK w heat or AC, not by itself
does the blower do anything? turn the power off and take the lead that comes off of the "cool" ( wire from the blower motor) and hook it up to the outlet side of the door switch ( the wire that comes off the door switch and goes to the board) turn the power back on and push the door switch in this will allow 110v to the blower if the blower runs the blower is good
reatach all door switch wire and blower wire to "cool"
disconnect all low voltage terminal wires at control board from thermostat make a jumper with a seperate wire from R to G if it runs it is your Thermostat or the wires inbetween the two
if it doesnt you probably have a burnt solder spot on the back of the control board and will need to replace the board
hope this helps
Posted on Jul 12, 2009
How to fix key pad on ge convection oven jvm1790bk. Pad stopped working
The control panel is actually 2 different parts and either could be bad. Do you have the display still lighting up or is it completely dead? If it is out it could the main smart board. If it still lights but no buttons work then it could still be the smart board or just the key pads which are a separate part. Neither part can be fixed just replaced.
Feb 26, 2015 | GE JVM1790 Convection / Microwave Oven
I have removed front cover on amana model ptc153b35am unit says it has got a manaul reset for heater cannot locate it can you help
The manual reset is a small switch on the computer control board. If that doesn't fix the problem, while you are there, you will see 2 small black boxes wired into the computer board marked "heater 1" and "heater 2". These are relays, one of which has probably gone bad. You can either order a computer board for about $100 or replace the relays yourself with a soldering gun. You can order the relays for $4.02 apiece from Digi-key Corp. Part # is JTN1aS-PA-F-DC5V for the relay.
Dec 10, 2014 | Amana Heating & Cooling
Where is the Manual Heater Reset Switch on an Amana A/C and Heater Unit Model number PTH093B35AJ? The unit has several stickers that state it has a "Manual Heater Reset Switch".
Almost certainly it is a bad relay on the circuit board. Sometimes you can slap the side of the unit by the control box to temporarily unstick the relay, after which the heat will come on for a cycle or two. There are two relays on the circuit board marked "heater 1" and "heater 2". You can order a new circuit board for about $100 or replace the relays at $4 apiece (order online from Digi-Key, requires solder connections). Part number JTN1a-PA-F-DC5V.
Jul 18, 2014 | Amana PTH093B35AJ 9100 BTU ThruWallWindow...
Stop button doesn't work on Amana NED7200TW Electric Dryer.
Check the door switch to see if it "clicks" when you push and release it. If it clicks, then the control board will need to be replaced. Here is the part you will need to order.
Nov 01, 2012 | Dryers
No power, no display
check breaker then check plug
May 04, 2011 | Washing Machines
Menu stays on screen all the time and wont go off even when pressing buttons .Off On button doesn,t work either.Could cig smoke gum up buttons
Cig smoke wouldnt effect the buttons, the control board on the monitor is probably bad, this is what tells the monitor to display the menu, make changes, etc... If that has gone bad, pushing buttons would have no effect. Youre probably better off buying a new monitor.
Jan 20, 2010 | Computers & Internet
Kemore elite 21082
It certainly does sound like the main control, this is the most common part (electronically speaking) also there is the display board(s) directly behind the control panel. This PC relays user inputs to CCU (located on top of washer ---middle rear). I havent replaced a faulty display board yet out of the 50+ ive serviced. Doesnt mean its not bad. If you have any questions feel free....
Nov 13, 2007 | Kenmore Elite 21082
Heating & Cooling Logo
259 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
