Question about Home
Pfister kamato toilet bowl not rising how ajust it
4 Suggested Answers
  • 35 Answers
SOURCE: toilet flushes weakly and two times
After working for ROTO-ROOTER for 20 + years, I have come across this problem more than twice. There are many problems that can be included, but let's start with the most simple and go from there. Step 1... Check your roof vent to see if it is obstructed with debris, such as birds nest, frozen ice, dead animal...etc..... To check this you must go onto the roof and find the sewer vent(it is not hard to find as it smells like sewer). Visually look into the vent even using a flashlight to make sure there is nothing obstructing the vent pipe. certain things can clog your vent such as Debris,Birbs Nest, Ice, dead animal,Etc..A drain line needs a air vent so water can flow....If nothing is visually seen , have someone flush the stool. If you cannot see any obstructions and HEAR THE FLUSH, Your Vent is okay. Check out plumbing and venting on the internet for more reference. If this is not your problem then you must pull the stool and see if there is an object stuck in the toilet......Comb, toothbrush, Etc... The best way is to pull the stool from the floor and look from the bottom of the toilet to see if there is an object stuck inside the stool.Turn off the water supply and disconnect it from the tank. Go to your local hardware store and buy 2 wax rings with plastic flanges and a set of flange bolts(these are cheap and can be returned if not used).Turn off the water supply to the toilet tank and flush it to drain all the water from the tank and the stool. You can use a shop vac or an old towel to remove the water. After removing the stool, lay it on its side and look from the bottom to see if there are any obstructions. You may need a mirror and flashlight to see inside the gooseneck of the stool. If you cannot see any obstructions, you can try to dump a 5 gallon bucket of water through the bottom of the stool to push the object out the way it entered. NOTE: When reinstalli8ng the stool, be careful not to over-tighten the floor flange bolts as you might crack the toilet......Joe
Posted on Jan 02, 2009
  • 6 Answers
SOURCE: Our Kohler K3402 suddenly stopped flushing. When
If there is a shower in the same bath is it also draining slowly?
If so check that drain systems air vent, (on the roof).
Find the pipe coming out of the roof nearest the bathroom with the problem and when a second person flushes the toilet you should be able to feel
air moving in and out of the pipe with your hand covering the end. If not the vent could be blocked by leaves or animals etc., this vent has to be clear in order for water to drain properly.
Posted on May 20, 2010
  • 34821 Answers
SOURCE: pfister kamato How do we adjust the water level in the bowl.It is too low...email at ...d.iogna@gmail.com...thank you
Increase the bowl level by adjusting the fill valve
Posted on Feb 26, 2013
Can the pfister kamato e70w toilet be refitted with an old style flapper valve to control excessive water wastage ?
Go to an ACE hardware and talk to the plumbing dept sales representative. They will know.
Dec 16, 2016 | Home
Water leaking into bowl
I have the exact same problem with the pfister toilet.Anybody with ananswer??
Mar 14, 2014 | Pfister VTP-E70W Kamato One-Piece Dual...
Toilet bowl will not drain when flushed
if your flapper is held open and the toilet rises to the rim and does not flush then you need a closet auger and clean out the toilet as it has debris restricting the flush
Mar 02, 2014 | Plumb Craft Perfect Flush Toilet Kit
When we flush the toilet there is never enought water left in the bowel after...do i get more water
Make sure the small toilet fill tube in the tank is still running into the tank overflow tube.
Jan 12, 2014 | Pfister VTP-E70W Kamato One-Piece Dual...
Needs two flushes to empty bowel
might be that the water level in the tank is to low. if both buttons release the same amount of water then you have to increase the water level in the tank by adjusting the height of the floater on the inlet valve. look inside the tank and there should be a WL mark meaning water level should be set to this level minimum.
Nov 30, 2013 | Pfister VTP-E70W Kamato One-Piece Dual...
Toilet runs water in the bowl, replaced the flapper and ballcock, it still runs in bowl.
hi ur chian could be to short or u have to ajust the flue screw at the end of the ballcock arm wher the water flues into the bowl hope it helps u
Nov 01, 2010 | Eljer Toilet Onepiece Canterbury ...
After cistern refill outflow into toilet bowl continues to dribble in - and you can see a slight flow into the bowl and every so often we hear the cistern refilling a small amount to compensate.
hi i would suggest your ball valve in the cistern needs ajusting remove the top of the cistern you will see the ajustment screw at the end fo the ball **** arm hope this helps
Nov 15, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
When i flush the toilet, the bowl doesn't fill
there is an ajustment on top of float assembly
to adjust level of water in tank
Oct 31, 2009 | Home
Home Logo
469 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
