Question about Galaxy Radios DX-959 40-Channels Base CB Radio
Need a wiring diagram for the stock mic to a galaxy dx 959 color code if possible
Have an astatic mic echo max power mic on it need to put stock mic on for my vehicle
    Genius:
  • Galaxy Radios Master
  • 1,795 Answers
Get a mic for a cobra 29 it works.
Posted on Jan 12, 2015
  • 40 Answers
SOURCE: Galaxy DX 959
1. Remove bottom cover from radio. 2. On the main PCB, locate J33. (See diagram above) 3. Locate wires on pins marked "P5" (yellow) & "P6" (grey). 4. Cut wire on "P5" (yellow) and install a SPST switch in line. 5. Cut wire on "P6" (grey) and install a SPST switch in line. NOTE: By using two of the function switches available on the radio will eliminate the need for two new switches to be installed and mounted.
Posted on Mar 11, 2009
localwonder
  • 6784 Answers
SOURCE: how can i boost my galaxy dx 959
You will have to take this radio to a tune and peak shop for this upgrade. most audio store tech can do this upgrade or, just locate a truck stop near your location and im sure there is a radio guy on the premises that will assist in this upgrade as well. great radio by the way:)
Posted on Jan 28, 2009
  • 773 Answers
SOURCE: I do not have enough audio on my dx 959 galaxy 40 channel radio
You can turn the modulation up by turning VR16 to the left.
This should give you some big audio.
Posted on May 03, 2009
  • 773 Answers
SOURCE: refurbished dx 959 from galaxy no modulation? no transmitt?
If there is no transmit at all, it sounds like it wasn't fully refurbished. If it is just low modulation then just turn VR16 and VR14 all the way to the left.
If its not working at all, send it back. It hasn't been refurbished.
  • 22 Answers
SOURCE: i have a galaxy dx 959 it keys up has no soundor receive
Try a different mic, they CAN cause no sound (receive), and no talking. If that isn't the issue, I'd go to my coax cable, even though they don't look broken doesn't mean that they aren't. I've seen quite a few brand new ones that are bad right out of the box. If all of that checks out I'd grab an SWR/power meter and do a check to see if the radio was registering on the inline meter. I'd say use the one on the radio, but I'd like to see it on the inline so you can really tell whats going on with the radio. I think I'd also get a spare radio, or a friends, and put it in my vehicle and see if it gets out. That would be the best way to check your coax and antenna setup. Aside from that, which is just simple cb logic, I'd say you may possibly have to bring the radio to a tech and have them check it out. I have a DX-959 and a DX-99V and I gotta say, knock on wood, no issues with either one. I really hoped that helped and let me know how things turn out. Its always good to hear from people after they figure out what was wrong, that way we all learn...
Posted on May 14, 2009
My radio squeals with echo when my amps on
adjust your talkback to just open then set your echo to where you want it. Now turn your amp on and re-adjust both the talkback and the echo . If you have a speaker nearby the radio may be feeding back through it so move it away from your radio . Now start talking with the mic and adjust your echo because you should be able to hear yourself talk through your talkback.
Dec 21, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Wiring code by number and color for turner mic road king 56 to galaxy dx 959
same pin out as if you were connecting it to a cobra 29.
Jul 19, 2012 | Radio Communications
How to wire a HG M73 mike to a galaxy DX 959
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Cobra
Stock
1- Audio
2- Transmit
3- N/C
4- Shield
5- Receive
Dec 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy DX 98VHP meter stopped moving . There is no swr reading, nothing. Even with a seperatye meter atached or a dummy load, the meter on the galxy is not working. Did I lose all power?
You appear to be aware of you antenna system with the separate meter attached so the tells me you dont punish a radio with an high swr. I am just guessing red wire/solder in mic cord at plug given that it is a side mic mic jack.
Stock mic
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Jul 02, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
I have a galaxy dx 959 I had a connex board put in it sometimes it sounds great then the next time it sounds destoreded or a loud sweel
did they put both the power ground and the audio ground together when they installed it? some echo's can only have the one ground , not both.. either the power wires ground or the coax ground on the audio wires.
also check the swr's..
Feb 19, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
I have no swing in my galaxy 959 mobil radio PLEASE HELP
we would be glad to take a look at it for you. has there been any modifications done to it? and are you using a rk56 astatic 636l type of mic? if so there will be less modulation from those style compared to a stock mic.
Nov 08, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Im trying to wire a astatic d104 m6b to a galaxy 949 mobile can you give a color code for what color wire goes were?i have black white red blue and a bare wire thank you.
This works for any mic.
dont worry about color codes. look at the switches.. there will be a common on both poles of the d104.. those need to be tied together to grnd. pin 1 on mic . the others d104 on n/c side is your rx. pin 4... the n/o one will be your tx pin 3 the other n/o will be audio and will have a wire from the mic element also on that pole of the switch. pin 2..
Sep 25, 2010 | Galaxy Radios DX-949 40-Channels Base CB...
I have a Galaxy 959 cb radio. I have extended the
its normal its only cause your useung more power from the deck
Jul 09, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy Radios DX-959 40-Channels Base CB Radio Logo
258 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
