Question about Husqvarna Sewing Machines
My viking husqvarna topaz 30 does not recognize my endless embroidery hoop
It says to attach hoop when I try to use my endless embroidery hoop (170x100) It recognizes all my other hoops just fine
  • 192 Answers
SOURCE: Embroidery Hoop
Any authorized Husqvarna Viking dealer will be able to get the hoop for you. Replacing the screw is much more economical and that same dealer will have access to the part number so that they can order it for you. This will take longer but will cost about 1/10 as much.
To find your nearest dealer, or one a little farther away, check the dealer locator at:
http://webservices.us.vsmgroup.com/DealerLocator.aspx?Brand=Viking
Posted on Sep 29, 2008
  • 371 Answers
SOURCE: HUSQVARNA TOPAZ 20 SAYS TO ENTER CORRECT HOOP. THE
Your embroidery unit needs to be re-calibrated. Check your user manual to determine if that's something you can do. Otherwise, you'll need to have an authorized Husqvarna Viking dealer do the calibration and make sure the hoop sensor is working via the service menu. You can find authorized dealers close to you at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck.
Posted on Sep 25, 2009
  • 201 Answers
SOURCE: I have a 170x100 hoop. My machine does not give
If it is not highlighted at the machine that means that the design you want to sew will not fit that hoop. You do not need a download for that hoop, just need to use designs that fit the embroidery field.
Sometimes you think a design will fit but the machine thinks otherwise. Trust the machine - it knows where the stitches are going and knows when it can't do it. I just loaded a design whose longest dimension was 97cm, other side was a lot smaller, but it would not let me sew it in the 100cm x 100cm hoop.
I was able to use my 150 x 150 hoop instead but if you do not have a choice of hoop, try downsizing the design in the Adjust menu. Try only one click each for height and width and then check if the hoop is available. If not, downsize one more click each dimension. Don't downsize a huge design using this technique - you won't like the result!
Posted on Nov 28, 2009
  • 201 Answers
SOURCE: Husqvarna Viking Designer I breaking needles
Dls8864's suggestion was a very good suggestion - make sure the metal stitch plate is pushed all the way to the back. Also make sure that the thread is feeding freely - if it is catching on something it can cause the needle to be pulled aside and make it break. Does the design fit properly inside the hoop you are using? If the foot and/or needle strike against the side of the hoop, that will cause a breakage. Is the bobbin thread okay - not making a bird's nest underneath?
Posted on Feb 01, 2010
  • 201 Answers
SOURCE: I have a Do All Quilter's Hoop which I can't use
I'm a bit amazed that a Husqvarna technician was unable to do the minor adjustment to the embroidery arm - he needs to contact Husqvarna headquarters and ask for instructions. Meantime, you can still use your hoop (which by the way is my favourite hoop - it's a little beauty!). Tell your machine you are going to use the Large Hoop (6" x 9.5" or 150mm x 240mm) even though you are really using the 6" x 6" or 150mm x 150mm Do It All Hoop. Provided you have centred your design before loading it on your USb stick or floppy drive, it should work. However, just to reassure yourself, use the Check Size button on your touch screen to test the outside size of the embroidery and be sure it is not going to foul on the hoop borders. (It is the one on the second screen (press More to access this) once your have loaded your design - looks like little double arrows pointing to the corners of a square. Each time you press this button, the needle will zoom to each outer corner of your design in turn.
Posted on Jul 17, 2010
Testimonial: "Thanks so much for your feedback on the Quilter's Hoop problem. I did as you suggested putting the Large Hoop 240x150 in the preferences and darn if it didn't work. I have since learned that my technician wants $50.00 for a part he says Husqvarna says my machine needs because it was built before the Quilter's Hoop came on the market. What do you think of that? Thanks again for the solution."
I have a topaz 25 viking embroidery machine my screen keeps telling me to attach the correct hoop and I already have and he keeps telling me the same thing and won't embroider
Try removing the hoop, then replace it. When you replace it be sure to push hard so it snaps into place. If you don't hear or feel the snap, it is not in all the way.
Feb 24, 2015 | Sewing Machines
What is the symptom of a broken hoop
Sounds like you might be having problems with the machine not wanting to start sewing an embroidery pattern or not recognizing the hoop size. If the former, and the embroidery is full size (say 100x100mm), try reducing the embroidery slightly (say 98x98mm). If the latter, your embroidery unit may need slight adjustment to correctly identify the hoop. Its not an elaborate adjustment but you will probably need a profession to accomplish it.
Mar 23, 2014 | Husqvarna Viking 1
My Husqvarna designer SE embroidery unit keeps giving an error message "install hoop correctly". I've checked everything but can't get around the message. can anybody help ,?
You have probably got the machine set to use a different size hoop. Click on the hoop icon and change it to the size you are using. Hope this helps you.
Aug 04, 2013 | Husqvarna Sewing Machines
Make sure that the metal plate is locked into position- Hope that helps!
Jan 20, 2010 | Husqvarna Designer I
HUSQVARNA TOPAZ 20 SAYS TO ENTER CORRECT HOOP. THE CORRECT HOOP IS IN THE MACHINE.
Sep 18, 2009 | Husqvarna Viking 1
Screen is frozen
Remove the embroidery unit and see will come on then. If not, it is probably the PC board. If it does come back on, it may be the embroidery unit or the connection. Take to authorized Husqvarna Viking dealer for service or have them send it to Husqvarna Viking (SVP) Technical Service Department for repair. A list of authorized Husqvarna Viking dealers can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Feb 26, 2009 | Husqvarna Designer I
Husqvarna/Viking #1+ embroidery unit disengages when attempting to sew.
Suggest that it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Oct 28, 2008 | Husqvarna Viking 1
Embroidery Hoop
Aug 27, 2008 | Husqvarna Viking 1
Husqvarna Des 1.. won't recognize hoops
The embroidery unit needs to be calibrated. Can only been done by a trained dealer. you can relax, it is not a major issue and shuold not cost you a arm and a leg. Ask the dealer to also calibrate your touch screen and download the working hours on your machine.
Regards
dupina
Dec 11, 2007 | Husqvarna Designer I
Sewing Machines Logo
802 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
