Question about Nintendo Wii Console
Nintendo wii remotes
When you press a button on the wii remotes they just flash for a couple of seconds and nothing happens what do you think i should do to solve this problem i hope you can help me thank you
Av you tried changing the batteries?
Posted on Oct 25, 2008
My wii remote wont turn on. when I push the on button the four lights at the bottom flash a couple of times then nothing happens and it wont recognise it on our tv...?
Try syncing the wiimote to the wii itself. Underneath the SD card cover on the front of the Wii and inside the battery compartment on the wiimote are red buttons. Hold both of these at the same time for 5-10 seconds and then try again
Apr 13, 2013 | Nintendo Wii Wireless Remote Controller...
Connecting a second wii remote to Madagascar kartz
ress the red button inside the battery cover of the wii remote, then press the red button inside the cover at the front of the wii. do this at the wii menu to register remote 2
Apr 29, 2010 | Nintendo Madagascar Kartz Uk Pal Release...
My sonic riders won't recongnize my wii remote.
Try pressing the home button then press the wii remote settings then re sync your remote.
Feb 13, 2010 | Sega Sonic Riders: Zero Gravity for...
When I turn on WII it says ''press A to continue''ut nothing happens. I have changed the batteries in the remotes but they do not respond. I have checked the sensor is plugged in.
If you have more than one remote, you may have to "sync" the remotes to your Wii system.
1. Open the battery cover on your remote and press the red "SYNC" button. The lights on the remote should begin flashing.
2. Open the cover on SD Card slot on the console and press the "SYNC" button.
3. The lights on the remote should stop flashing after a few seconds. Your remote is now ready for use.
This process must be repeated for each new remote.
Feb 09, 2010 | Nintendo Wii Console
My wii remote doesn't work!!!
Do you play with the second controller before? If you not the second controller must "bind" to the console. Open the cover in front of the Wii and press the red button there and then press the red button on the controller.
Sep 26, 2009 | Nintendo Harvest Moon: Magical Melody for ...
Wii Remote A/ B problem
I know this sounds silly, but be sure that you have fresh batteries in each Wiimote and that you have them in the right way.
Whenever you start up your Wii, the first Wiimote that you press a button on becomes controller number 1 and then subsequent Wiimotes are added in the order a button is pushed on them. SO, if you are thinking that you have remote 1 because that was the one that was remote 1 last night, it doesn't necessarily mean that it is so. Be sure that whenever you activate a Wiimote, the lights flash - 4 lights flashing mean strong battery, 1 light flashing means replace; when flashing stops, the number LED that is lit from the left denotes which remote you have. Make sure that is the same Wiimote that you select a game with, and make sure that is the one you press A&B together with to start the game.
If it doesn't work, shut everything down and start up using the other Wiimote. If that DOES work, then it could mean that your other Wiimote is not syncronized with the console. See the directions in your Wii manual on syncronizing additional Wiimotes (they're called Wii Remote by Nintendo) to your console.
Good luck. If all the above fails, you may want to go to www.nintendo.com and request customer service.
Mar 25, 2009 | Nintendo Wii Remote Controller
Wii Remote stopped working for no reason.
Well, pressing 1 and 2 doesn't work if your Wii remote came desynched. Press the Red Synch buttons on both the Wii console (located under the SD card flap) and the one on the back of the Wii remote, and hold one then the other for about 5 seconds. Should help.
Jan 19, 2009 | Nintendo Wii Console
Wii remote not working
it sounds like it could be faulty but I got this info from nintendo's website and at the bottom there is a customer service phone number that will help with any other problems relating to remotes for the wii
Still having problems? If the basic guidelines above did not solve your problem, the more specific information below may help.
  • Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
    Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
      Try these steps!
    1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
    2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
    3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
      1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
      2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
      3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
      4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
      5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
    If you are still unable to get the Wii console to recognize your Wii Remote(s) after carefully following the steps above, please call 1-800-255-3700 for further assistance.
I know this says if your console does not recognise your remote, but they should be able to help you with your problem too
Dec 28, 2008 | Nintendo Wii Console
Mario cart will not recognize my second remote.
Another possibility is that the original poster did not push the "+" button on the main remote when on the screen in Mario Kart to register additional remotes.
This happened to me. I was holding down the 1 and 2 buttons over and over on the second remote, watching the blue lights flash, but the remote wouldn't register. Eventually someone noticed the instructions on the screen to push the "+" button. When you push the "+" button, another screen appears to let you really register additional remotes.
In Wii Sports, there is no pushing of the "+" button to register new remotes... I had incorrectly assumed it worked the same way in Mario Kart and didn't bother reading the on-screen instructions.
Dec 24, 2008 | Nintendo Mario Kart (Wii) for Wii
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
