Un simbolo de Z led solo prende
SOURCE: SD card capacity
Yes, the hardware is SDHC-compatible. You just need to apply Microsoft hotfix KB934428 for Windows XP (http://www.microsoft.com/downloads/details.aspx?displaylang=de&FamilyID=6edfb30f-b1ab-42a8-a330-acd6762961bc) and you are set. 16GB SDHC working like a charm.
Stefan
SOURCE: need to reset user name & password for lenovo thinkpad x41 tablet
google ophcrack and download a live cd for the specific OS you have, burn the ISO file to a cd(with a program like nero or roxio) put disk into the thinkpad and turn on the lappy, follow the steps and you will within 5 min have your password and username ;)
SOURCE: can i use a bamboo fun stylus on a x41 ibm tablet
Yes you can. You will not be able to use the tablet pen however while the stylus is plugged in
SOURCE: IBM Thinkpad X41 wont turn on.
I have the same problem. I have swapped the memory, hard drive, keypad, network card and modem with the same components of another tablet. I did each component seperately into the known good machine. this machine boots with each of these components and the bad machine still will not boot with known good components. I believe that it is either the motherboard or processor. Not worth the cost. ebay has some machines for 200-300 dollars.
SOURCE: I have IBM thinkpad x41
Sounds like a bad invertor (the high voltage device that powers the small fluorescent bulbs in the display) You can buy them online but require disassembly to repair and sometims they are integral to the motherboard so they cant be repaired. Make sure the power saving settings dont turn off display.
