Question about Exercise & Fitness
What is a si3 error on a discovery 415 treadmill
Get si3 error when we try to power up
2 Suggested Answers
SOURCE: I have a Discovery 560HR
http://www.treadmilldoctor.com/SI3-Error-Code-kf
Posted on Jan 05, 2011
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
My treadmill is stuck on one speed... HIGH! Can this be repaired and how..
Motor drive circuit is faulty.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Mar 31, 2016 | Proform Crosswalk 415 Treadmill Walking...
I need help to unfold my pro-form 415 CT treadmill
new? User manual? try MFG website, or email their customer service or try manualslib.com
Jun 08, 2015 | Exercise & Fitness
Incline does not work but incline motor runs for 3 to5 seconds proform415ct
if the motor tries to work but incline does not go up something is jammed on the treadmill or the incline motor is bad
Oct 17, 2014 | Proform 415 CT - Treadmills
I have a Proform 415 CT. When I put the key in place i get a FF code. I've tried unplugging overnight but still doesnt work. How do I fix this problem?
iFit card had scrambled the computer memory. Their solution to replace in the iFit card slot and it would reset the computer memory on the machine.God bless you
Mar 23, 2013 | Proform Exercise & Fitness
I have a discovery 415 treadmill. When I plug it in, I get a clicking in the chest high display. The noise is not coming from the motor but from the control panel.
see the block diagram attached. Unplugeed the machine, and tight every connector going to the display panel. Starting by ribbon cable inside from display board.
2) Reset the machine see your instr. manual for to see where is located the r. button.
3) Test the fuse inside the machine and replace if necessary.
4) Test the REED switch, see the diagram attached, test if for open or defective, clean it, and tight very well the connector, and Try again.
God bless you
Dec 11, 2012 | Exercise & Fitness
Discovery treadmill won't start
1) adjust the speed sensor, see the diagram, clean it and tight the wires connector very well.
2) test the main motor, see the input voltage motor, if there are the motor need repair.
3) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diag. God bless you
Jun 22, 2012 | Exercise & Fitness
ProForm Crosswalk 415 assembly manual
Dear Sir :
Thank you by your request, I hope everything is fine.
I will help you inmediately.
Please go to the next web:
www.fitnessrepairparts.com
They are specialize in Parts for everything, and Every Manual for Fitness Equipment, only that you must paid some fee.
Do not waste your time go ahead.
Thank you in advance, sincerely. Blesssing.
E.CUADRA
MANAGUA, NICARAGUA.C.A.
Sep 28, 2011 | Proform Crosswalk 500 Treadmill
SI3 error on a very old Keys Milestone 1200. Error is shown immediately after unit is plugged in.
I have the same problem. I just bought the 4200 used. I ran on it in the persons home and it worked fine. I got it home, plugged it in and now it throws up SI3 and SI1 codes and won't run!
Jan 17, 2010 | Keys Fitness Exercise & Fitness
Exercise & Fitness Logo
59 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
