Question about Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
Motor very loud and not sucking
It has been performing poorly and now the motor is making a loud noise.
  • Official Brand Answer
  • 2,572 Answers
I am sorry to hear you are having difficulty with the performance of your DC05. Based on your description of the problem your machine may have an obstruction.
Please visit http://support.dyson.co.uk/support/dc05/dc05-standard/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-the-floor-tool for step by step instructions on how to locate and remove an obstruction.
We also recommend washing your filter every 3-6 months. Instructions for washing the filter can also be found on the support section of our website. Please visit http://support.dyson.co.uk/Support/dc05/DC05-Standard/My-machine-is-not-working/Machine-not-sucking-picking-up-as-well-as-usual/Filter-Washing-Video to view the video.
If you need further assistance please call our Helpline free at 0800 298 0298.
Best wishes,
Jessica
Posted on Feb 16, 2012
Have a bagged Biss ll Powerforce vacuum that has started making a loud rattling noise under the base of the motor compartment. Noise is louder when using the hose. Suggestions? Thank you!
Something broke or got sucked in and is trapped in there. Put it up on a table and take the bottom apart, it's time to clean the roller anyway :)
Nov 02, 2016 | Vacuums
Makes loud sucking sound from the side hole
It probably has a clog or restriction somewhere. The sucking noise you hear is likely the suction release valve. You will need to trace the airflow path from Motor to floor to locate the obstruction.
Mar 10, 2015 | Shark Vacuums
Vacuum motor noise and smell
If the ball was stuck and you sucked water into the motor it could cause it to smell like it's burning if it ruined the motor
Jan 10, 2014 | Shop Vac Vacuums
Dyson vacuum, Vacuuming when I sucked up some wires. I pulled them out and the vacuum started making a loud noise. Now when I use it that happens and now it sparks.. What should I do?
quit using it and take it to a repair shop sounds like your motor is shorting out. However i would suggest buying a new vac since dyson motor replacement can be quite pricey.
Mar 06, 2013 | Vacuums
Motor on Eureka vaccum is suddenly very loud. I've changed all the filters and the belt.
The likeliest causes would be a large item sucked up and into the fan, causing a loud rattling noise, or a piece of the fan broke, resulting in the same noise. This means replacing the fan assembly.
The armature brushes could also be worn down to the point of causing the brush holders to contact the armature, which will, and probably has, ruin the motor. A replacement of the motor is necessary.
Cost of repair/replacement would probably be higher than the vacuum is worth.
Jan 03, 2011 | Vacuums
My vacuum makes a loud noise like a soccer horn going off, and neighbors are yelling at me for it! how do i make it quiet? its a bissel.
If you haven't changed the belt recently I would try that. Worn belts can cause funny noises sometimes. You can get Bissell replacement belts here:
www.bissellbelts.com
Oct 28, 2009 | Vacuums
Eureka whirlwing vacumn- upright
You may have a clog in the hose or the inlet by the brush roll. If they are clear, then the nosie may be coming from your motor and will have to be replaced.
Feb 13, 2008 | Vacuums
Loud noise
When the motor bearings start to go bad, they will make a loud noise. Some motors if a piece broke off of the fan, then it also will make a loud noise. You may have to replace the motor.
Dec 25, 2007 | Westinghouse WST1500 Wired Special Edition...
Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum Logo
125 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
