Question about Nintendo DS Lite Console
MY TOUCHSCREEN!!! MY TOUCHSCREEN WONT CALIBRATE WHENEVER I PRESS A DOT IT JUST GOES IN A LOOP AND THE CALIBRATION NEVER ENDS!!SOMEONE PLEASE COME UP WITH A SOLUTION!!!!
  • Concorde65 Oct 26, 2008
    thank you very much, ill do that!
Mine was doing the same thing i replaced the touch screen and now it works fine.
Posted on Oct 26, 2008
Can not calibrate the screen
Here is the procedure to calibrate the screen if you can not reach the calibration screen through the GPS menus.
Nuvi 2xx/2xxW Series: Turn the Nuvi off. Place your finger on the upper left-hand corner of the screen and then slide the on/off power switch to the left and hold until you see the calibration screen. Note: Some 2xxW models require the procedure below for the 7xx.
Nuvi 7xx Series: Turn the Nuvi off. Touch the screen anywhere and keep your finger there while moving the on/off switch to left (don't wait for Garmin logo to come up) and then quickly moving the switch the right (lock position). After a short while, you will reach the calibration screen. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Now if you go through and press the dots and it keeps looping without saying "calibration complete" then the touchscreen has drifted out of specification and must be replaced.
Please see this link for more information about touchscreens and how to get it replaced.
http://www.sharc.net/gps_LCD_repair.htm
May 11, 2016 | Garmin nuvi 205 GPS Receiver
Touch screen calibration
To calibrate the StreetPilot c-Series touchscreen, follow these steps: Begin with the device turned off and unplugged from a power source Power the device on and continue to hold the power button for 1 minute Release the power button when the screen displays "Press Dot" Accurately touch the dots as they appear The dots will change location A stylus or pencil eraser may be used to accurately touch the dots Touch OK when the "Calibration Complete" appears The touchscreen is now calibrated.
Oct 16, 2013 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 205w gps black dot problem
Please be more specific. There is a calibration screen where black dots are shown and you press them to calibrate the touchscreen. Is this what you mean? If you press them and nothing happens, your touchscreen may have failed and needs to be replaced.
May 27, 2013 | Garmin nuvi 255W GPS Receiver
Touch screen not responsive after speaker replacement It worked before speaker replacement.
To calibrate the touchscreen on a nuvi 300 or 600 series:
1. Power the unit On.
2. From the Where to? / View map screen, touch Settings (wrench icon).
3. Touch Display.
4. Touch Recalibrate.
5. A new screen will display that says Press Dot.
6. Touch the center of the dot.
7. Keep touching the center of the dot as it moves around the screen.
8. When Calibration Complete appears on the screen, please touch OK.
The touch-screen will now be recalibrated.
Nov 04, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
My garmin nuvi 660 touch screen dosen't work
  3. Touch Display.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
When I turn on my nuvi 200 it says press dot. When I press the dot it just moves around the screen to different location.
To calibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position. Once unit powers on release the power button.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 09/30/2010
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Friend has a problem with his Garmin nuvi: when typing the letter to the left appears. what can be done?
It needs to be calibrated
To calibrate the touchscreen on your nuvi 200W follow the steps below:
Aug 14, 2010 | Garmin nuvi 200W GPS Receiver
The screen on my Garmin Nuvi 200W won't respond. I tried the recalibration but the screen doesn't respond when I touch the dot. I also tried a hard reset and that didn't help either. Help please!
There is more than one calibration procedure, but for the 200 it is:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 follow the steps below:
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
If this doesn't work you have two choices
Buy a new one
Or
Send your in for repair. Go here for this option
http://www8.garmin.com/support/outofwarranty.html
Aug 23, 2009 | Garmin nuvi 200W GPS Receiver
I'm getting inaccurate letter entry on the letters I type. For example, when I type a B an M appears - I'm noticing it on the bottom row of letters at this time. Solution?
Are you sure you pressed the correct location on your screen???
If so, you may need to calibrate the screen.
Do this:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Nintendo DS Lite Console Logo
245 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
