Question about Casio Sea Pathfinder SPF70-2V Wrist Watch
Bracelet casio spf 70s - Casio Sea Pathfinder SPF70-2V Wrist Watch
SOURCE: Changing links for a Casio watch bracelet
solutions already mentioned(casio wristband) worked for me. However the first link took me forever to remove as I found it hard to envisage what I what attempting. Attached is a pic of a disassembled link which hopefully might help someone....BPB547b9a0.jpg
Posted on Dec 30, 2007
escapement
  • 2334 Answers
SOURCE: how to adjust metal bracelet on casio A168 watch
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 05, 2009
  • 183 Answers
SOURCE: Casio wva-210 bracelet adjustment
This watch has cotter pins. The end that comes out looks like a screw head but it is not. It is a split pin and the end with the split is the large end and needs to come out first. The arrows tell you which way to take the pins out. Use a small punch and push from the side that has no split. This should also be the same direction the arrows are pointing.
Posted on Sep 22, 2009
  • 52 Answers
SOURCE: I have a stainless watch bracelet for the Casio
yes you can shorten the bracelet of your watch. for that you must take your watch to the shop from where you bought it. over there they will remove the extra pieces & give it to you.
Posted on Dec 08, 2009
gemineye61
  • 831 Answers
SOURCE: How do I adjust the
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Posted on Aug 21, 2010
    Raccourcir bracelet casio
    I don't know the answer to this one, but if it helps - Pierre wants to know how to shorten a Casio watch bracelet.
    Jun 04, 2016 | Casio Watches
    Is it possible to convert the resin band strap of casio GS1001 to metal bracelet? If yes, where can I get the metal bracelet?
    I have just found this site, it has all sorts of watch straps for all casio watches.
    I am sure that you will find it useful
    www.casiosalesandservice.com/starasp/a=3&dept=cwband&class=gshock.
    Feb 20, 2012 | Casio GShock Giez watch #GS10011A Watch...
    How do you remove a link off the Casio Men's Edifice 10-Year-Battery Analog Bracelet Watch #EF106D-2AV?
    Have a look at the links nearest the clasp.
    These should have markings on to say which are removable. An arrow or some other indication.
    Not sure if this watch has press pins that go through the whole bracelet or flip up catches on each band.
    Please dont forget to vote this answer was helpful.
    Many thanks
    Mar 01, 2011 | Casio Edifice 10YearBattery Bracelet...
    Recently purchased a casio dbc-32d-1a, the band(metal) is way to big. How do I adjust it?
    For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
    You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
    Feb 25, 2011 | Casio Watches
    Bracelet pin rusted off
    You should be able to poke it out with a pin. Is it the pin in the bracelet itself or the one holding the bracelet onto the watch?
    Jul 24, 2010 | Casio PRG60T-7 Wrist Watch
    Sep 22, 2009 | Casio Watches
    How to adjust expandable bracelet pleaseI would like to remove links to make it smaller.
    If you are ready to take that risk, here is how you can do that.
    First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
    Check the sides of a bracelet. You will notice that the upper band metal is flipped over the bracelet side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
    When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
    So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
    Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
    When links are out, take the staples and drive them back into the bracelet joining two ends together. You have to do that exactly the same way and position as you took them out.
    When all staples are in place, bend the metal back over the bracelet sides.
    BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
    Good luck.
    Jul 29, 2009 | Casio Watches
    How to adjust metal bracelet on casio A168 watch
    Job done!
    Apr 05, 2009 | Casio A168W Wrist Watch
    Hi, where can i get a new casio mtg-900 watch strap/ bracelet? thanks Nathan
    good eafter noon ! you can buy a bracelet of your watch on casio center near you,thanks!
    Aug 28, 2008 | Casio Watches
    Remove few pieces in my Casio AW-SD bracelet
    What u can do is call casio tech support and give them ur email address and they can send you the instructions to adjust your band.
    Jun 07, 2007 | Casio AWS90D-2AV Wrist Watch
    Casio Sea Pathfinder SPF70-2V Wrist Watch Logo
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
