Question about Kenmore Dryers
Kenmore dryer model no. 66514692 won't heat - Kenmore Dryers
  • 4088 Answers
SOURCE: kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Posted on Aug 24, 2009
  • 108 Answers
SOURCE: Kenmore Elite dryer won't heat
if no heat at all unplug the dryer take off the vent take out the screws holding the back on there is a long oval shaped tube with two wires going into it there is a holding bracket holding it in place take out the screw unhook the wires take out a screw holds the heating coil in take out that screw inspect the heating coil for breaks it sounds like it is burned out if so replace if not it is probably the oval shaped thermostat on the tube i do hope that this was helpful then reverse the procedure, thank you.
Posted on Dec 31, 2009
  • 2266 Answers
SOURCE: electric dryer won"t heat. Kenmore Heavy Duty 70
are you getting power down to the heater?why did you change all those other parts?you need to unplug the dryer,with a meter read out all the parts you changed out again but first make sure you have 240 volts coming to the machine,you can check it at the cord in the back,touch the white to the red,you should have 110 volts or 120,then go from the white to the black and you should have the same thing,if not the problem is in the house,if it's correct make sure you have power coming down to the heater,you could have a bad timer or a burnt wire,when you check the other parts unplug the dryer and whatever part you check at least one wire has to be removed,do this and you'll find your problem,if you did this first you wouldn't of bought all those parts.let me know what you find
Posted on Nov 05, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Kenmore dryer model # 110.63102100
Hi Ludwig11711...
Here is a few more things to check...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Posted on Jun 04, 2011
heatman101
  • 43501 Answers
SOURCE: My series 80 Kenmore dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 05, 2011
I have a Kenmore dryer model # 96580110 and the heat won't come on when it is operating
Your Heating element may have burned out. Repair clinic has some good repair videos, and a parts department. Sears parts direct is also another source for parts.
Nov 20, 2012 | Whirlpool LEB6200 Electric Dryer
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
Kenmore 70 series dryer won't heat
Post the model number for clarity. These tests should only be attempted by competent service personnel. Do you actually have 220 power? Are both legs of circuit hot...at 120v? While dryer is unplugged from power, check the heating coil for continuity. Also check continuity to ground from each end of heater (should not have continuity to ground at both ends). Also there should be power to the heating element when activated.
Mar 14, 2012 | Kenmore Dryers
Kenmore gas dryoer model #11073912100 not getting hot, all vents cleaned out, still won't work. could it be pilot light?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Sep 11, 2011 | Kenmore 74112 Gas Dryer
I have A kenmore elite gas dryer model # 110.75062501 it won't heat please help
heatman101;'
Jul 18, 2011 | Kenmore Dryers
Kenmore Gas Dryer 11072212101 won't heat. we
heatman101.,/
Jun 30, 2011 | Kenmore 73102 Gas Dryer
Dryers Logo
29 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
