Tv guide will not update on digibox - Televison & Video
    Sergeant:
  • 291 Answers
Check if you have the right time on your tv, that causes a lot of problems. [Daylight savings or whatever]
Posted on Oct 25, 2008
Sky box green light on permanent
Sounds as if the software is corrupt. Try a forced software update...
1) Switch the digibox off at the mains power, so no lights are displayed on the unit
2) Press and hold the BACK UP button on the digibox (not the remote control)
3) Whilst holding, switch the digibox back on at the mains power so the red standby light is displayed
4) Wait approximate. 10-20 seconds for the remaining 3 lights to display, at which point you can release the BACK UP button
5) Allow the digibox to download the latest software, which can take 10 minutes before returning to standby
6) Leave 60 seconds then power up as usual
A software update/refresh will leave your recordings intact. You won't lose anything.
If this doesn't solve your problem, then the next step is more drastic. It's a Full System Reset and Planner Rebuild. Be advised though: Your recordings are at risk!
1) Switch your digibox on
2) In sequence, press on your remote 'SERVICES > 4 > 0 > 1 > SELECT' (this will access the hidden menu)
3) Select the relevant option (usually the bottom two) and follow the on-screen prompts (note that it's likely your digibox will reboot between processes)
Applies to Sky+HD Digiboxes only, running latest EPG
1) Press Services on your remote control. 'Options' in the Top Menu will be highlighted in orange.
2) Press the Right arrow once to highlight 'Settings' in the Top Menu.
3) Now press the Down arrow once to highlight the 'settings' tab in the Middle Menu.
4) Press 0, 0,1, Select on your remote in quick succession. The 'Setup' tab will then be highlighted within a hidden menu.
5) Select the relevant option and follow the on-screen prompts (note that its likely your digibox will reboot between processes)
Sky Digibox Planner Rebuild / Full System Reset (if stuck in standby)
Applies to Sky+ and Sky+HD Digiboxes only
Same as above, but applies if your digibox is stuck in standby and you cannot get to the hidden menu:
2) Press and hold the 'right and left arrow' buttons on the digibox (not the remote control)
4) Wait approximate. 30 seconds for the blue Sky+ ring of lights to display, at which point you can release the 'right and left arrow' buttons
5) Press 'SELECT' on the digibox (not the remote control)
6) Now the system will format the hard drive, the blue Sky+ ring of lights should spin backwards
7) Allow the system to format, which can take 10 minutes before returning to standby
8) Try to power up!
Sep 02, 2014 | Televison & Video
How do you fit a two way booster to a digibox and a tv?
Hello. When you boost the signal to the digibox it will also boost it to the tv. So just install it in the incoming line before the digibox. 10412402.jpg
Jan 25, 2010 | Televison & Video
Picture jerks like robotic .its ok on arial only the prob occurs when digibox turned on?
is electrical problems on digibox or tv, use the same power source (plug), and use good top quality cables bettween tv and digibox.
Jan 17, 2010 | Televison & Video
Sony KV-28DX30U. my tv wont re-tune!? I had digital channels before the switchover!? Do i need to buy a digital box? It has intergrated digital tv!?
It's probably curtains I'm afraid. The software in this TV is only compatible with the old standard (2k) and not the new standard (8k). Sony aren't releasing any updates so you'll need a digibox (or a skip!)
Dec 02, 2009 | Philips TV Tuner Video Capture PCI Card -...
We receive satelite tv through dish and digibox. We have suddenly
Try unpluging from the mains for about 2 mins,if still a problem then the LNB on the dish may be at fault
Oct 27, 2009 | Televison & Video
My digibox will only play radio channels
I grew some more brain cells and realised there is a button on the remote control called "radio" and when I press it, it toggles between tv channels and radio channels.....
Oct 25, 2009 | Philips Televison & Video
Panasonic digibox tu-ct20 has all stations mixed up since the retune . worked perfectly well untill then.even tried the shipping reset .no luck.
Just had the same problem with a Panasonic digibox whilst trying to fix a customers tv. The only way I can see to unmix them is to use Profile menu to create a new Profile and manually add the channels one-by-one to the new profile, or replace the digibox. I suggested to the customer best solution - replace digibox as they are cheap enough now.
Oct 20, 2009 | Panasonic Televison & Video
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Philips digibox
I tried another digibox and got BW only. So it had to be the JCV TV. I rooted around and found that my s-video setting had changed. I don't know how, because it's an obscure menu item. I changed it back and all is well.
Andrew
Sep 30, 2008 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
