Question about Car Audio & Video
Remove rear speakers 1999 dodge stratus
Removing the factory rear speakers from the 1999 dodge stratus
zapco
  • 30 Answers
SOURCE: I need to replace the
okay u can down load that info from crutchfieid..website they great pics to show u how
Posted on May 05, 2008
nick_helpap
  • 334 Answers
SOURCE: How do you change the battery on a 2006 dodge stratus?
is it unde rthe tire ? front my my serbing or can u get to it under hood ? if its tire one u hav eto remove fornt left tire take out platsi stuff then thers batter behind wall k thx nick
Posted on Oct 06, 2008
  • 46 Answers
SOURCE: 2007 dodge stratus battery
If you haven't already located the battery, it is in the fenderwell, in front of the drivers side front wheel. There are a few retainers on a plastic shield in that area, remove those. Then disconnect the negative (black) cable first, and then the positive. You will also notice that there is a hold down bracket for the battery. Remove the bracket and the battery will slide out.
NOTE: It is easiest to remove the battery with the left front wheel off. Make sure to have the car on jack stands before you remove the wheel.
Posted on Jan 05, 2009
  • 217 Answers
SOURCE: getting rear gears out of the difential case 1999 dodge durango
  1. Raise and support vehicle. Ensure that the transmission is in neutral.
  2. Remove wheel and tire assembly.
  3. Remove brake drum. Refer toBrakes, for proper procedure.
  4. Clean all foreign material from housing cover area.
  5. Loosen housing cover bolts. Drain lubricant from the housing and axle shaft tubes. Remove housing cover.
  6. Rotate differential case so that pinion mate gear shaft lock screw is accessible. Remove lock screw and pinion mate gear shaft from differential case
  7. Push axle shaft inward and remove axle shaft C - clip lock from the axle shaft
  8. Remove axle shaft. Use care to prevent damage to axle shaft bearing and seal, which will remain in axle shaft tube.
  9. Inspect axle shaft seal for leakage or damage.
  10. Inspect roller bearing contact surface on axle shaft for signs of brinelling, galling and pitting. If any of these conditions exist, the axle shaft and/or bearing and seal must be replaced
Posted on Feb 11, 2009
  • 50 Answers
SOURCE: 2000 Dodge/Chrysler neon Removing rear speakers
I don't know of any websites with pics or vids, but i can walk you through it. First, remove the trim panels between the rear door glass and rear windshield. They're just held in by little clips and should pull right off. Then grab the rear seat cushion at the front about midway to the middle on each side and yank it up sharply. Take the bolts out that hold the rear seat back in place, I think you have to lift it from the bottom to disengage clips at the top. Remove the rear seatbelt trim bezels. Slide the seatbelts through the slots and pull the shelf trim forward to remove it. The speakers are held in by 4 phillips head scews.
Posted on Apr 12, 2009
Rear brake sticks on 1999 dodge stratus
If there is traces of brake fluid on the new shoes or drum, that will make them bind as they heat up.
Nov 16, 2017 | 1999 Dodge Stratus
Trouble re-installing original radio to my 2005 Dodge Stratus, how many connections are there?
Here is a list.
2005 Dodge Stratus with Infinity Radio Wire Harness Colors
Car Radio Constant 12V+ Wire: Pink
Car Radio Switched 12V+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Dimmer Wire: Orange/Brown
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: Dark Green/Red
Car Radio Amplifier Location: Amplifier is Mounted Under the Front Passenger Seat
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Dark Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Violet
Right Front Speaker Wire (-): Dark Blue/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Dark Blue/White
Right Rear Speaker Wire (-): Dark Blue/Orange
Sep 18, 2012 | 2005 Dodge Stratus
Wanted to know how to remove thefuel pump lid on a 99 dodge stratus
If I recall correctly you may be able to access the fuel pump by removing the rear seat. There should be a hatch door in the floor board with screws in it. If not you'll have to empty and drop the fuel tank.
Sep 18, 2011 | 1999 Dodge Stratus
Remove starter on 1999 dodge stratus
un hook battery remove wiring from starter, unbolt starter and remove ,to install reverse directions good luck.
Oct 31, 2009 | 1999 Dodge Stratus
REMOVAL OF REAR BUMPER COVER ON 1997 DODGE STRATUS
See under the bumper its strap with clips,you must take it out from it,
Sep 10, 2009 | 1997 Dodge Stratus
Open the cd changer on the factory stereo in 99 dodge stratus
gently slide the door to the right. then push turquiose button on lower left side of changer to eject magazine. Hope this helps
Mar 08, 2009 | 1999 Dodge Stratus
2004 Stratus Rear Speaker Removal
Yep, you have to take the side panels on each side off, then the rear cover lifts off. You need to use a stubby screwdriver to get them out, a normal one will hit the glass.
Jan 06, 2009 | 2004 Dodge Stratus
Headlight assembly removal
you have to flex and wiggle the light it will come out.
Dec 12, 2008 | 1999 Dodge Stratus
Replace a catalytic converter for a 1999 dodge stratus
The cat is located just off of the exhaust manifold. You have to remove things to get out of the way. Loosen down pipe to converter and unclamp the converter and it should pull right out. Use a good penetrating oil to help loosen the down pipe bolts.
Jun 10, 2008 | 1999 Dodge Stratus
Car Audio & Video Logo
130 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
