Question about Kitchen Ranges
Cancelled self-clean, F9 code came up, door lock light flashing, can't use oven
I set the self-cleaning option. I had to cancel it. When I pushed the cancel button, the F9 error code came up. Then it started beeping. Door lock light began flashing. There was a noise like the door lock mechanism was trying to engage or disengage. Continued beeping. Beeping finally stopped. Door lick light still flashing. Unable to use oven.
  • 3 more comments
  • pete1956 Oct 28, 2008
    It is a Sears Kenmore Electric Range Model # 790.95661103. If possible I would like to know how to repair problem myself without having to call Sears to come in and repair at huge expense.
    Thanks.
  • Anonymous Nov 23, 2008
    stuck on clean cycle and makes a light buzzing sound like the lock is trying to close. F9Code comes up
  • joegitz Feb 09, 2009
    f9 door is locked how do I unlock it manually
  • philzee May 11, 2010
    what make/model of range is it?
  • Anonymous Mar 23, 2014
    oven door will not open & keeps beeping with errors E-1 and F-5 appears
  • 38 Answers
HI,
your model number confirms that your range was manufactured by WCI (Frigidaire). although this doesn't help you now, it may help if parts are needed.
now, there is an indepth guide online to fixing this common problem and I would like you to go through it and see if it helps you solve your problem.
http://www.applianceaid.com/clean-lock.html
If you have found this site previously then I apologise, if you still need help, by all means post again and someone more qualified may help.
Hope this is of use to you ;)
Phil
Posted on Oct 28, 2008
Kenmore Electric Range model 790 has F9 & F1 code error
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 20, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Pushed the clean button, the oven locked, and the screen started beeping and flashing f9 or f7. I hit cancel, and the oven is still locked and the clean button is sill flashing.... It has been 10 hrs!
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%^%$
Jun 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self clean oven door wouldn't unlock!
Try a trick that was given by an expert :-
All I needed to do was unscrew the 2 screws holding the lock assembly and it released it!! I screwed it back in and set the oven to self clean and it worked!!
Unless , F9 refers to slave micro not working. A condition in which you might need to replace control board.
Thanks.
Jun 04, 2009 | Amana ACS3350 Gas Kitchen Range
Stove door locked and continues to beep and flash code F9
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
Mar 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door lock lites keeps flashing but the door is not locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door locks and F9 fault codes
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Oven door won't unlock
I asked for help with an Amana F9 code problem earlier today .I had set self clean oven on and then after 2 hours cancelled it. After 1/2 hr it began to beep and displaideda F9 code and I couldn't get it to unlock. Tried manual tip to turn off circuit breaker for 3 minuetes then turn back on. Did this 3 times to no avail.Tried 20 minutes also zip.Contacted Amana and all they would tell was to call a service rep. I gave her apiece of my mind that I wouln't do that because I wasn't going be paying for such an issue.
Your site was my salvation.( STP685) Suggested I push bake and once I did the oven started to heat and unlocked itself.! Thank you,thank you,thank you.
Jul 18, 2008 | Amana ACS3350 Gas Kitchen Range
Self cleaning oven
Turn off the power to your stove and then back on. It ought to clear it.
Mar 07, 2008 | Ovens
F9 code
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
Nov 22, 2006 | Amana AOCS3040 Electric Single Oven
Kitchen Ranges Logo
1,047 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
