Question about Hitachi 65S700 65" Rear Projection HDTV
I have sound but no picture - cannot change channel, input, ant etc. the only buttons that work are the the power and volume buttons. This includes the remote AND the buttons on the set itself. This thing is stuck on the #&$% cooking channel, i cant even listen to espn! help would be appreciated.
  • 58 Answers
First thing is unplug the set from the wall for 10 min.
Check also carefully to see if one of the buttons on the tv is stuck in the on position.
or if cleanig solution was used on the screen and it ran down onto the switches. if so spray WD40 on them.it will not harm your tv.
Last option is a bad EEPROM.
Thanks Guy9
Posted on Jul 08, 2008
I have started setup for hd cable. Am connected to hdmi and have picture and sound but am unable to change channels. What do I need to do.
With the HDTV set for an HDMI Input that matches the HDMI Jack that you've connected to the cable HD STB (set-top-box or "converter"), use the cable STB remote to change channels on the STB - not the TV.
You can not change channels of the STB with your TV remote. You may however, be able to program your STB remote to operate your TV. Most will allow you to power the TV on / off; volume up / down / mute; change input (HDMI1 / HDMI2 / ANT / Composite / etc.) and even some of the more complex functions as well. Contact your cable company for more details.
Feb 25, 2016 | Sylvania Televison & Video
Sound robotic on samsung ln22a450c1d
change the sound volume in channels settings /avc and try
Jan 01, 2014 | Samsung LN32A330 32 in. LCD TV
NO PICTURE
Refer to the manual (free download here). Generally, a blue screen indicates a very low or non-existent signal. This can happen when the antenna is unable to gather enough of a signal from a particular broadcaster, or if an A/V input is selected, but the A/V device is not on or providing a signal. Since you are not seeing channel information when tuning, I suspect that the television is set to display an A/V input instead of the internal tuner.
With a working remote, locate the TV/AV button on the lower left (manual page 3 - item 8). When this button is pressed, you can choose to display signals on the ANT, VIDEO1, VIDEO2 or COMPONENT jacks. The ANT selection chooses the input on the RF jack such as an antenna or cable TV (with or without converter box). If using a cable box, the TV tuner should be set to Ch3 or Ch4 as determined by your cable box. Otherwise, select the VIDEO1, VIDEO2 or COMPONENT input that has the source signals you wish to watch from a cable box, DVD player, etc. that is connected to the rear input jacks. Page 7 of the manual details the connection and remote operation.
I hope this helps!
Apr 16, 2012 | Insignia NS- 27" TV27 TV
The remote doesnt work with the tv at all. and when i try to change the channel manually with the button it says no input availiable. but the volume button works just the channel button that doesnt. I...
UNPLUG THE SET FOR A WHILE AND PLUG IT BACK IN TO SEE IF IT WILL REBOOT-sounds like a microprocessor problem and could have been caused by a power outage etc.
Apr 01, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
No video on any of the inputs
check the user manual also can be misconfigured or check the voltages at the video ic if they are getting the data and clock
Sep 09, 2009 | Toshiba TP43H95 43" Rear Projection...
Ant A and ant B
There should be 2 buttons labeled Input, in between Volume and Channel. Press up on Input. If you are using a remote different from the one that came with the TV, then look for a button labeled 'Input' 'Int' or 'Mode' somewhere along the top.
Mar 29, 2008 | Mitsubishi CS-35405 TV
Ds31590
njdb,
Look on the remote for keys that are labled tv/vcr or source or input... In fact, if you go to the front of the unit - that's a Sanyo right - find the grouping of buttons that change the channel, volume etc.. There should be a button marked source or input there.. Press it as many times as it takes to get back to the input source your cable is on...
If you have any problems let me know...
Bill
Nov 24, 2007 | Televison & Video
No Picture, sound is all static
Make sure the ant. input switch didnt change and check the ant. connections If that dosent work sounds like a defective tuner.
Mar 30, 2006 | Philips Magnavox 27MS343S 27" TV
Hitachi 65S700 65" Rear Projection HDTV Logo
121 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
