Question about Frigidaire FWTBB30DS Front Load Washer
Frigidaire FWTr445rfs1 front loader - door closed but buzzes during washing
My Frigidaire front loader's door sometimes buzzes while washing. I have cleaned the area where the door locks into the washer; sometimes if I push on the door slightly to make a tighter connection the buzzing stops. It seems minor and I'd hate to pay $$$ for a service call if it's something simple. Any help would be appreciated Thanks
  • Anonymous Mar 16, 2014
    Front loader
    Genius:
  • 1,554 Answers
By the way it too fixya over 14 hrs to relay that message
Posted on Apr 16, 2008
My frigidaire washing machine door hinge snapped
Hello - Contact the manufacturer to see if they have any updated or alternate door hinges that you can install yourself. The weight of some front loader doors, and how they are closed/slammed, can wear over time.
Nov 03, 2012 | Frigidaire ATF6000ES Front Load Washer
How do I runa diagnostic on a Frigidaire Model 41744152400
most front loader washers will wash fine all the time, however there is a pin switch on the front that the door strikes when closed make sure the door is closed and locked .
Sep 27, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader door, will not latch securely. Can prop a broom against it and it works.
Sounds like could be broken Door hook/******..........Sometimes the small metal bar that holds the spring jumps out of its seating you can tell this if the door hook looks kinda funny not operating properly...Remove the door trim and refit the bar this allows the spring to operate and puts pressure onto door hook thuss allowing it to close ........
Nov 23, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a front loader washer...it was in the middle of the cycle and starting beeping. The dr (door) signal is flashing. Cloths are wet and i can't get any cycle to go now. Any suggestions?
Unplug your machine.
Open the top of the machine.
Open door
Remove the door lock assembly
Check contacts of the door switch.
Replace if faulty or try to clean with electronics cleaning solvent.
Jun 23, 2010 | Frigidaire Affinity ATF6000F Front Load...
Door lock buzzing
sounds as if your door lock is broken and needs to be replaced.
Feb 06, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have a two-year old Frigidaire GLTF2940FSO front loader washer that has stopped in the middle of a load leaving water in the drum and will produce a buzzing sound no matter what cycle you put it on. We...
did you try unplugging it and plugging it back in to see if you can get it to reset? Would it buzz when you try to drain it? Does the door latch lock when it goes into the wash cycle? Usually the door latch locks when it goes into the wash cycle and stays locked. So it filled up, the door latch should lock, then should go into wash cycle. Then you said few minutes later it stops. How did you get the door open? reason i ask is Usually i would see the clothes get stuck inside the washer because the door latch is still locked when it stops. Was the door unlocked when it stoped. If so maybe something going on with the communication from the board to the door latch maybe. Did you try operatin the drain?
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire FWTBB30DS Front Load Washer Logo
925 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
