Question about Kenmore Dryers
Kenmore dryer model number 110.60712990 wont heat
110.60712990 model number. Dryer just doesnt heat up
SOURCE: Need schematic for Sears Kenmore Dryer model number 11063032102
Thanks, I will try that.
Posted on Mar 28, 2008
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
jumptrout51
  • 3361 Answers
SOURCE: KENMORE DRYER MODEL NUMBER 66912690 WONT HEAT
Check the voltage at the terminal block where the cord hooks up for 220 volts.
Remove the rear panel and check the thermal fuse located on the upper portion of the heat canister.
Check the Hi-limit thermostat on the bottom portion of the heat canister.
Check all the wires for a burned or loose wire.
Check continuity of the heating element.
Posted on Mar 08, 2009
  • 31 Answers
SOURCE: No heat on dryer
heating coils burnt out
Posted on May 15, 2009
  • 35 Answers
SOURCE: kenmore dryer model#110/62622100 will not atsrt
check to make sure you dont have a blown fuse or a triped breaker if they are fine if you have a volt meter take the back panel off on the control are or if it is the other kind losen up the two screws in the back of the control area and when you get it lifted up make sure unpluged then put the volt meter on the beep mode when probes touch then put it on the two spots on the swicth and push the button if it beeps it is good if it dont it is bad and that part dont cost too much another thing you should check before you do all that check make sure you have 220 volts on that plug if the switch is good and you have 220 volts it probably the motor or the timer they both or expensive
Posted on Jun 07, 2009
On my kenmore dryer 970-c82062-00 I can get all 3 timers to start but the heated automatic dry portion does not time out.
that model number doesn't come up,you sure that isn't the serial number?also does the dryer have heat,when you run it on time dry the timer just counts down like a clock,when on auto or more or less the heat comes on until the dryer heats to temp. the heat shuts off and the timer will advance,when the heat comes back on the timer stops moving,it will do this until the clothes are dry,if you do have heat you could have a bad sensor or a bad cycling thermostat but you'll have to check it with a meter.send the model number and i can help you better.
Feb 16, 2014 | Dryers
Dryer not heating
Hello there and welcome to fixya
Here are the most common things that will need to be checked with a meter to ensure there is continuity on these parts no continuity means that the part is bad and needs replacement ok?
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric solenoids which open the valve to let the gas flow into the burner assembly. If the dryer doesn't heat one or more of the solenoids may be defective. If the igniter glows for 90 seconds but the burner flame doesn't light, replace these coils as a set.
Dryer Igniter
If the dryer doesn't heat, the igniter might be burned out. Check the igniter for continuity with an ohm meter. Dryer igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can burn out over time. If the dryer doesn't heat, the element should be checked for continuity. The heating element cannot be repaired and must be replaced if defective.
Heating Element Assembly
The heating element assembly on an electric dryer can burn out over time. If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the heat given off by the flame. If the dryer doesn't heat, the flame sensor might be defective. Check the flame sensor for continuity. This is not as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at fault when the dryer doesn't heat. Check all of the other components in this troubleshooting guide before replacing the main control board. The main control board cannot be tested easily and must be replaced if it is defective.
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer
Oct 14, 2013 | Amana Dryers
Hi this is Erik, my problem is that my dryer wont heat up it works but it doesnt heat up throws cold air
Your/The heating element needs to be replaced. You can repair it yourself...copy serial number and model type down and order element. Sears, Lowes, and Home Depot carry appliance parts for many names. You will have to order it. Relatively simple job...30-60 min job.
Apr 27, 2011 | Frigidaire GLEQ2152ES Electric Dryer
If i press the power button the dryer goes on but once i stop pushing the button it stops. I tried to keep the button pushed but the dryer doesnt heat up inside.
what kind of dryer is it and send the model number,if it's a whirlpool/ kenmore and it has even heat you have a bad even heat board...copy and paste and read this,it should help you out...............http://fixitnow.com/wp/2003/12/20/mailbag-dryer-stops-when-the-start-button-is-released/
Apr 25, 2011 | Dryers
Doesnt heat thermostat was replaced and fuse replaced still doesnt heat
What is the model number of the dryer? I did not see where you checked the "heating element" on the dryer. Check the element for continuity.
Dec 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
I hava Kenmore Dryer model 417 and it spins fine. But the heating element doesnt work at all. This just happened after I jhad To replace my washer. These units were stacked. So maybe something is looose?...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 03, 2010 | Dryers
Kenmore series 80 Gas dryer doesn't heat
Look for extreme fluff buildup inside and outside causing air restrictions. check your fusea5500f3.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 17, 2010 | Kenmore 64742 Electric Dryer
Kenmore gas dryer model #76812690 will not heat.
does the dryer heat initially when you first turn on the dryer Or no heat at all?
the first thing i would check is tthe thermal fuse thats located on the back of the unit. test it with a multimeter and see if it has continuity, if it doesnt then replace that and your operating thermostat. the check to be sure you venting to the outside of your house is not clogged
Apr 29, 2009 | Kenmore Dryers
Kenmore dryer doesnt heat
You may also need to change your thermal fuse and the thermostat. On some models the thermal fuse operates the heating element only and others the whole dryer
Mar 19, 2009 | Dryers
Nothing you did wrong! Probably needs a new heating element. Prices vary by model. Call Sears/Kenmore parts center nearest you. Tell 'em you need a heat element for your dryer. Be sure to provide your dryer's model number.
Unplug your appliance first before attempting repairs! Safety first and always!
Dec 19, 2008 | Kenmore Dryers
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
