My screen apears to be in 3D - Televison & Video
  • dubb420 Oct 25, 2008
    my tv screen apears to be in 3D and I can't seem to change it
    Sergeant:
  • 291 Answers
Your 'guns' are out of alignment.There should be a menu that takes you to a program that shows a single DOT in the center of the screen or multi DOTS on the screen that you should see yellow, green,blue off the side of each other. You must bring the three (3) color splashes into the center to make the DOT white. your 3D will go away.
If you can't do that, get a tech to help.
If you can send me a copy of your manual, to [dmsr3@juno.com] I'll try to guide you or you can contact one of these fine techs on fixYa.com
Posted on Oct 25, 2008
Blank screen when windows logo apear
motherboard problem. contact laptop technician
Dec 03, 2012 | Computers & Internet
Acer aspire 4935G lap automatically getting restart and apears blue screen
Hello download or renew the missing drivers here at acer:
http://support.acer.com/product/default.aspx?modelId=35
Please select your windows system.
Unzip the file before you install the driver.
Reboot after the install is done.
Try to renew the screen card driver.
Blue screen of death is always a faulty driver.
Good luck
Nov 07, 2012 | Acer Aspire 4710 4920 4935 4930G 4930...
View 3D on wd-y65
Ur tv does nt support 3D. U can still see 3D if connected to PC. With power DVD 11 u can able to watch anaglyph 3D.
Dnt get confused any standard screen (e.g. CRT (big boxes with curved screen)) can view anglyphic 3D content.
Jan 08, 2012 | Mitsubishi WD-Y65 65" HDTV
The color is not showing correctly there apears to be to much red and green and not enough blue
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 26, 2011 | Philips 60P8342 60" Rear Projection...
Volume meter apears on screen but not responding
download the correct drivers for the sound card should fix the problem
Oct 16, 2009 | HP Pavilion dv6000z Notebook
Jvc av-48wp30
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 20, 2008 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
Electro Med Services...
