Question about Philips Televison & Video
Philips lcd model 37pfl5322d/37 wiring diagram
SOURCE: replacement of fuses on Philips 37PF7320A 37 in. HDTV-Ready LCD
it is a 5amp fuse but it's a time lag fuse, i.e it wont blow when you hive a minor power spike so you might find that a normal replacemnt fuse kepps blowing
Posted on Mar 06, 2008
  • 8457 Answers
SOURCE: has sound but no picture
Replaced the LCD inverter board,to get picture back.
Posted on Dec 17, 2009
mace1mace
  • 1138 Answers
SOURCE: my philips lcd tv has sound but no picture what is
change the backlight (cold cathode light) on your monitor.. If you are able to open the back of your lcd monitor carefully, the backlights are located at the upper and the lower part of the edge .. replace it with conventional cold cathode lights(protective tube was removed)... there are also instances that backlight was good but the ballast transformer is burnt. Replace the ballast. Its very cheap to replace that.
Posted on May 18, 2010
  • 5063 Answers
SOURCE: cant find audio out jacks
This TV has a headphone jack on the side (above the Side AV input), a digital audio output (SPDIF) in the main input/output panel (bottom facing down) and two pairs of +/- terminals for right and left speakers. The terminals are to the left of the power cord. The SPDIF port is between the PC in and the AV3 in.
The terminals are used for directly wired speakers. Usually these have a pair of flat wire cables and the ends may have different color insulation (red, black, white, white/black striped).
If the speaker bar uses RCA inputs then get a 3.5 mm (M) to RCA (2 female) adapter for use with an RCA audio cable or an audio cable with 3.5 mm M on one end and 2 RCA plugs on the other. Plug the 3.5 mm end into the headphone jack of the TV. If you use the headphone jack, the TV speakers will probably turn off automatically. For the other audio options, you will need to enter the menus to adjust the settings. Press Menu and then go to Sound for speakers attached to the terminals. Digital Audio is adjusted from the Installation Menu then go to the Source Menu.
If the sound bar has a digital audio input, you should use that SPDIF cable (not usually included with the sound bar or the TV).
For details and a picture of the jacks, see http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=37PFL5322D/37&slg=en&scy=US for the User's manual or the leaflet (both include diagram). The User's manual has the picture on 3 (Section 2:2).
I hope this helps.
Posted on Dec 11, 2010
  • 298 Answers
SOURCE: hi i have a philips
Try the composite cables red white ye llow
Posted on Feb 25, 2011
Philips TV model 37PFL5322D/37 Colors just became oversaturated and I need help diagnosing the problem?
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 25, 2016 | Philips Televison & Video
Model 37PFL5322D/37 phillips tv has a chirping sound, no picture
Your TV is exhibiting a symptom of power supply trouble but repair is not a casual task.
Dec 20, 2013 | Philips 37PFL5332D 37 in. LCD Television
No sound on my philips 37pfl5322d/37
Check and replace damaged components at its audio output stage circuit. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Nov 22, 2013 | Philips 37PFL5332D 37 in. LCD Television
Philips 37PFL5322D
Your remote control need cleaning. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now.
Pull up older posts there. have all details about how to clean a remote control.
Sep 12, 2012 | Philips new universal remote control...
Model 37PFL5322D/37 phillips tv has a fast clicking sound in the power supply, what will cause this.
possible the main relay in the power supply board may need soldring or you could have a stickey relay
Jul 13, 2012 | Philips 37PFL5332D 37 in. LCD Television
Phillips model 37PFL5322D/37 was watching unit and just shut off--no click or pop, just shut off....unplugged power for 1 minute and tried to power up--nothing--will not power on...checked power...
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 16, 2011 | Philips 37PFL5332D 37 in. LCD Television
My 37PFL5322D 37" LCD has no picture and no
If the set is responding to the remote or set-top buttons, this means only that the always-on low voltage supply for the remote section is working and that the main power supply has probably died. You might try pulling the AC plug overnight to see if there is simply a 'lockup' of an IC causing the non-response. Our modern sets are very complex and it isn't uncommon for them to have a glitch while operating.
Mar 08, 2011 | Philips 37PFL5332D 37 in. LCD Television
Philips 37pfl5322d will not power up. Have tried unplugging for 10 minutes and pluggin back in. Still no power.
IT SOUNDS LIKE YOUR POWER SUPPLY BOARD MIGHT HAVE SOME BLOWN CAPACITORS (CAPS). IF YOUR NOT FAMILIAR WITH ELECTRONICS I WOULD HAVE A TECH LOOK AT IT. ONLY BECAUSE IF YOU ACCIDENTLY TOUCH ONE OF THE CAPS INCORRECTLY YOU WILL END UP IN THE EMERGENCY ROOM.
Feb 20, 2010 | Philips 37PFL5332D 37 in. LCD Television
No sound from Phillips 37 LCD
The audio output IC is probably faulty this cost only a few dollars if you replace it your self.Let me know if you need further assistance or more information.
Mar 30, 2008 | Televison & Video
Televison & Video Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
