Question about Sony Audio Players & Recorders
CanI connect an external eq to a sony str-de698 receiver?
cancerags
  • 36 Answers
SOURCE: connecting sony str/k660p to dvd recorder and tv
Hello jvirgil,
Go to http://esupport.sony.com/US/perl/model-home.pl?mdl=STRK660P&LOC=3
and under the hot topics section, click on "Hookup Recommendation Guide", select the components you want to hookup (Dvd recorder and receiver in your case. TV hass been autoselected). Click continue, select all the different inputs/outputs that your components have, click on Recommend my Hookup and... 'voila' you get your personalized connection guide. Hope this helps.
cancerags
Posted on Dec 27, 2007
welcomejee
  • 10594 Answers
SOURCE: Sony STR-DE698 7.1
in Sony receivers Protect display shows problem / fault in Amplifier output area. Qualified technician can repair the damage.
Regards,
Posted on Sep 05, 2008
  • 85 Answers
SOURCE: operating instructions for sony str-d565 receiver
this is a link just make sure to disable protected mode in internet explorer sometimes it has problems with links
http://www.docs.sony.com/release/STRD665.PDF
Posted on Feb 23, 2009
dunnbiker
  • 8546 Answers
SOURCE: HELLO HOW TO CONNECT SUBWOOFER TO SONY
It would depend a lot on what type of subwoofer you have and it wouldn't be pretty.
According to the manual I found it doesn't have a Woofer Output so it isn't designed to route Low Frequencies anywhere.
Even if you rigged an Active Subwoofer to it using the Tape Output you wouldn't have central volume control for it unless the (unnamed) Sub was driven by speaker-level outputs from the Front A or B Speaker posts on the receiver.
Your question would be better framed and answered if we knew the details of the Sub and referred to ITS manual.
Posted on Apr 10, 2010
Testimonial: "Thank you for your advice. This is exactly what I needed to know . Jerry"
  • 6771 Answers
SOURCE: sony receiver made pop noise
It sounds like the output ic's may have failed, because of the complexity of system I would have a professional come and look at the unit for an evaluation, chances are he will need to take it back to the shop for service.
Posted on Dec 30, 2010
How to connect a teac equalizer A220 to a Sony receiver str-DH540
I'm not familiar with your units. The most common set up would be use the "tape monitor loop". Eq out to receiver tape in monitor, Eq in to receiver tape out monitor, then engage receiver "tape monitor" switch on.
Mar 18, 2014 | Audio Players & Recorders
How do you connect sony str-de 698 fm receiver to television, cable box and cd player
Connect it's two audio plugs, likely to be coloured red and white, to corresponding sockets on any device that has them and select that input on the device. You should then hear your tuner.
Depending on FM signal strength where you live you may need an aerial, some is always better than none.
Sep 21, 2011 | Sony STR-DE698 Receiver
How to hook up external equalizer to Sony STR-DA 2000 ES. Equalizer is a Denon
you need a empty in/out tape slot (jacks in back of Sony, if tape deck is connected you can use "Y" connectors) connect jacks to EQ tape in & out.... (press EQ button Bypass)
Nov 13, 2010 | Sony STR-DA2000ES Receiver
How to connect kenwood GE 52 graphic equalizer to my sony str-DE345 any idea , please help me.thanks.I tried many combination but didnt work.
An EQ usually plugged between a preamp and an amplifier. You have a receiver. There's no connections that will let you do that. The only thing you can do is between a source(ie: CD) and the receiver. The CD will go in the eq and out of eq to cd input on the receiver
Sep 03, 2010 | Audio Players & Recorders
Protect Mode
need replaced power ouptup .assy
Apr 28, 2010 | Sony STR-DE698 Receiver
HOW CAN I HOOK UP CAVILIER 200A POWER AMP TO A sony str av 770x f
You can pull the Left and Right stereo program from either MD/Tape or Video 2 Audio OUTputs. Run a pair of RCA cables to the Active EQ's Line IN; then the EQ's Line OUT to the Cavalier's Line IN.
If the Tape output you're borrowing the program from is already connected to something, use RCA-cable splitters.
Remember to NEVER activate the monitor for that Tape function during playback of any digital audio source - it disables the digital input; or if the 901's are being used - it will remove the signal to the Cavalier.
Now if you wanted to use the 901's in your movie listening this will work with two limitations
Your receiver doesn't have preamp outputs for Front Left and Right out so you'd be extracting only the mixed-down 2-channel version of whatever the Sony is processing.
You'll have to manually control the Cavalier's volume because the pre-out you're using is BEFORE the Sony's volume control.
It might still be an improvement over what you have now.
Mar 21, 2010 | Sony STR-DE675 Receiver
Looking to hook up an older model fisher EQ (EQ-961) to a newer Sony amplifier (STR-697).
Typically you would place an EQ or any processor2_bing.gif in a Tape Loop:
MD/Tape (or Video1) Rec/Out to EQ In; EQ Out to MD/Tape Play (or Video1) /In on the amp. Select MD/Tape (or Video1) on the receiver to place the EQ in-line with whatever source you're playing. Use it's ability to modify the sound sparingly.
Be advised, use of an external processor will only work for analog stereo sources and will likely DISable anything digital as soon as you activate the switch that puts it in the signal path.
Feb 23, 2010 | Audio Players & Recorders
Cant get equalizer to work with my receiver
This might work fish76, The EQ needs a in & out source to operate correctly? If you have audio device connected to an aux input disconnect that & connect the EQ to that audio device & then plug the EQ to the Sony receiver AUX input. The tape monitor is the most important source for hooking up an EQ device, so you are very limited on a total receiver or amp tonal connection source. The bottom line is you can only use the EQ if another audio source to plug into it & the EQ plugs to your pre-amp input on the back of your rec or amp
Feb 03, 2009 | Sony Audio Players & Recorders
Help connecting up amplifier and surround sound.
Ok here`s what you have to do first turn off all three applinces you will need 3 (rca) jacks then on your tv should have a yellow colour input jack its like a hole place one end of the jack into the video or yellow hole and the other jack into the video or yellow hole to the back of your dvd .then behind your dvd they are other inputs for audio take the the colours should be red and white one jack will be (L) left the other side will be right (R) place the other two jacks into it .Then behind the amplifer Look for the two red and white inputs place the jackes from dvd into it make sure on the amplifer you place the jacks in the aux input or line in input .then switch on all the applinces and on the amp using the remote or on the front panel press the aux or line in button then play somthing to hear if it works
Any problems Please send me a request
And please to rate me Thank you
Jonathon3680
Jan 13, 2009 | Sony STR-DE698 Receiver
Sony STR-DE698 7.1
Regards,
Sep 04, 2008 | Sony STR-DE698 Receiver
32 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
