Question about GE Spacemaker JVM1640SJ Microwave Oven
Does not cook no heat
GE JVM1640CJ space saver over the range microwave
only 18 months old
  • redronie Jan 02, 2009
    You were absolutely right! GE replaced the magnetron at no charge -BUT - since we didn't have a service contract - they charged us $200 to install it! Only cost $375 newly installed. Was it worth it? Don't know?
    Thank you for your help.
Here's your parts breakdown.
http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00016500/00016579.p01.pdf
More than likerly a bad magnetron. That's #73 on your parts diagram. One quick check before replacing - There is a bi-metal snap thermal switch bolted to that bad boy, (Normally Closed). Check for continuity there and if it's good take it off because you'll need it for the new magnetron. They don't come with one. If it's open that's your problem. If you do replace the magnetron don't throw the old one away without taking out the magnets. The thing just pries apart and there are two 1/2" thick 3" diametermags, they are just too cool to toss away.
What is the best way to discharge the capacitor? Holding a screw driver by the handle and not touching the shaft lay it across the contacts and it will discharge. You may need two screwdrivers with a clip lead between them to get at the capacitor contacts.
Call GE Answer Center 800 626 2000 and dig through the phone menus to get parts. That Magnetron may have a 10 year warranty! They'll send one out to ya no charge.
Posted on Oct 27, 2008
Runs but does not heat the food.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
Allow the circuitry to dry out by avoiding stovetop cooking for a few days. .... it to microwave, but its just not warming up myfood at all, any idea on how i can .... Everything works except themicrowave- it wont heat anything up.
Microwave Diagnostic - Has Power Not Heating - GE ...
? 2:34
https://www.youtube.com/watch?v=E_iUYIV8wD0
Aug 9, 2013 - Uploaded by ApplianceVideo.com
Microwave Diagnostic - Has Power Not Heating - GE, General ....internals of a similar GE Microwave unit that would not heat food.... Sometimes it turns on, sometimes it doesn't. .... My GE microwave space saver does not heat but it comes on. ... What's Inside A Microwave Oven (Teardown / Taken Apart) ...
Nov 18, 2015 | Microwave Ovens
We have a GE JVM1540 space saver microwave. It is less than a year old. Will not heat and immediately starts smelling like burning plastic. Any ideas as to what is causing that?
CHECK THE MICROWAVE MANUAL LOOK FOR FACTORY WARRANTY ,MUST BE A BAD COMPONENT ,IF YOU MICROWAVE IS UNDER 1 YEAR WARRANTY THE FACTORY WILL REPAIR IT AT NOT COST TO YOU..CONTACT GE FACTORY.
Feb 18, 2011 | GE Spacemaker JVM1540 Microwave Oven
Microwave will not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
l'l'l'l'l'l'l'l'l'l'l'l'
Aug 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave is not heating, and the table is not turning.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
76t
Oct 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE space saver Microwave not heating
heatman101
Jun 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
F3 Message given from my GE jvm1650wb008 Microwave!
WATTAGE AND CU.FT IS UP TO YOU. JUST MAKE SURE WHAT YOU GET FITS LIKE THE OLD ONE DID DIMENSIONS WISE. THE HIGHER THE WATTAGE THE FASTER THEY COOK AND HEAT FOOD UP.
Apr 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Mar 25, 2009 | GE Profile Spacemaker Over-the-Range...
Not heating properly
I have a GE over the range space saver microwave that was only 18 mos. old when it stopped heating. GE replaced the magnetron for us at no charge but since we did not have a service contract - they charged us $200 to install it. It only cost $375 new installed. Your choice.
Nov 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
53 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
