Question about Whirlpool LSR5132PQ Top Load Washer
Whirlpool washer - what are symptoms of bad timer
Fills, does not agitate, does not empty, timer just runs on and on
  • 641 Answers
SOURCE: Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sound like a belt issue. Open machine's cover and check that belt is not broken. Good luck!
Posted on Aug 04, 2007
aborcass
  • 2651 Answers
SOURCE: whirlpool washer wtw5200sq0 fills with water and
instead of timer soinds like a faulty lid switch, the unit not recognizing the door is closed so will only fill with water
Posted on Feb 23, 2009
  • 136 Answers
SOURCE: does not spin or empty
it might be jammed or there might be dirt or some sort of a clog. I would suggest you clean it out.
Posted on May 29, 2009
  • 4044 Answers
SOURCE: whirlpool commercial washer stopped running mid
If the timer and lid switches are funtional and the machine is filling and shutting off correctly that only leaves the motor. Have the motor tested or replace it. Even though the timer is running it is possible that it is still at fault. If you have access to another timer try switching them to make sure it isn't the timer. This does sound like a faulty motor and I would start with that assumption.
Posted on Oct 30, 2009
  • 401 Answers
SOURCE: Washer fills and empties,but agitator does not
If it will not spin either, but the motor does run, the motor coupler has failed. It is also possible the transmission has a problem, but the motor coupler is more than likely the problem. This model does not use a belt, it uses the coupler instead.
Posted on Jan 06, 2010
Agitator doesn't run
The problem could be transmission failure
May 23, 2013 | GE WWSE5240D Top Load Washer
If it fills with water but won't wash, is it the timer
hi mary,i just wrote and asked you for the model number,if this is a regular top load washer it could be the timer as long as you don't hear the motor running,if you do hear the motor running you could have a broken motor coupling because the drain pump is on the motor shaft so it will drain,
http://www.youtube.com/watch?v=9K1KHEogf3c
if you don't hear the motor it could be the timer,when it should agitate try tapping on the timer and see if it works,it has points in it and they can get stuck together or burn out and have no contact like you're saying but it's just a guess without seeing it but if the timer is advancing through with no agitation it could be the timer,did you try any other cycles
Apr 02, 2013 | Washing Machines
My Hoover500MB washing machine sometimes doesnt agitate or spin but will empty and fill
99% of those problems are with the lid switch. Check make sure it is functioning properly.
Oct 03, 2012 | Washing Machines
We have a whirlpool LSR7233EZO. When I set the dial where it should fill with water no water runs in but the agitator runs. This happens on any of the load choices. From what I've been able to find out I...
Your problem sounds like a faulty water level switch,not your fill valve. With the machine empty at the beginning of your cycles, the switch should internally be in the "empty" position to energize your fill valve solenoid(s), then when the machine completes the filling to the level selected on your water level knob, the level switch repositions to the "full" position to energize your timer to advance the cycle. If the switch is stuck in the "full" position all the time, as soon as you pull your timer knob out to start any cycle, the machine already thinks it has filled to the desired level, and immediately energizes your timer to advance to the wash step and begin agitation, even though the tub is dry. I will refer you to the following link for a video showing you the fill/switch replacement procedure: http://www.youtube.com/watch?v=bIs9gX0YjxI&feature=related
I hope I've addressed your problem as described
kcomp1863
Jan 20, 2011 | Whirlpool Washing Machines
It wont complete cycle and empty the water just hums for a while and then turns its self off
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
My washing machine is stuck on agitate. It filled and agitated then stopped. I can set it to spin only and it will spin and empty the tub, but for a regular wash cycle it starts on agitate and stops...
You may have broken teeth on the gears in the timer assembly. Do you have a habit of "whipping" the timer around? In other words, turning the timer fast.
Dec 14, 2009 | GE Washing Machines
Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore mod 110 agitator turns while water fills tub
Check your pump and drain for a blockage.
You also could have a timer connection issue. Remove the timer wire connectors and reattach them.The timer simply has a quick connection block, sometimes they get a little loose and all you gotta do is push it all the way back in. Check for a loose lid hinge and safety switch also.
Feb 09, 2009 | Kenmore 24032\24036 Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
372 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
