Question about Dell Latitude E5420 Computer (blmcj3b) PC Notebook
Dell Latitude E5420 shuts down unexpectedly. I have done hardware diagnostics with no errors, and system restore. Not sure what is wrong with it. Any ideas?
  • 35 Answers
SOURCE: Dell Latitude D600
It is the Hard drive on the system. Hard Drive is failing. Another Error code for the Hard Drive is Error Code 7. Check BIOS setup if the system still detects the Hard Drive as well. You may want to consider changing the Hard Drive on the system.
Posted on Nov 10, 2008
LaptopExpert
  • 458 Answers
SOURCE: Dell Latitude D620 locks up when moved
Is this when the ac adapter is plugged in?? Or on Battery??
Posted on Feb 06, 2009
jcoady
  • 79 Answers
SOURCE: CANT RESTORE MY DELL 40 LATITUDE
Contact Dell and request Dell Reinstallation Recovery CDs directly from Dell Technical Support. Contact them @ 1-800- 624-9896. Explain your situation. You will be asked for your service tag number of your system. As I recall they charge little more than shipping and handling to get it to you.
Good Luck!
Posted on Jun 01, 2009
  • 31 Answers
SOURCE: stop c00002la {Fatal system Error} The windows
Call up Dell or go to the web site and talk or chat with technical support. They can look up the error code and pin point the problem. Your laptop might still be under warranty so don't wait until it runs out you better act now.
Good Luck
Proteus
Posted on Nov 19, 2009
micromend
  • 748 Answers
SOURCE: when i turn on my dell latitude D505 the backlight
Either the video cable has been damaged or unplugged or the video processor is malfunctioning. Check this by connecting an external monitor. If the video is all there then press the Fn(function) and F4 key. This should switch the video from the external monitor to the internal screen. If this doesn't happen or if the external monitor shows no video then the laptop needs to see a reputable repair perso or check my website www.micromendllc.com
Posted on Feb 25, 2010
How to run fifa 13 on my dellLatitude E5420
Hi Navin,
I understand that you are unable to install the FIFA 13 in your Dell Latitude E5420.
Please provide me the following information
1. Operating System
2. Bit Version
3. Do you have any other computer?
4. Error message that you get with screenshot if possible.
5. Are you able to run the same DVD FIFA 13 in other computer?
This will help me to isolate the issue and try to fix the issue.
Nov 09, 2013 | Dell Latitude E5420 Laptop Computer
Webcam driver
Drivers for Dell Latitude E5420 is located here:
http://www.dell.com/support/drivers/us/en/04/Product/latitude-e5420
Choose your OS type then choose the approriate category for Webcam
Sep 16, 2013 | Dell Latitude E5420 Laptop Computer
Factory reset
restart the computer HOLD the CTRL OR FN +f2 or ESC depend of your model , mark, and go to BIOS setup select to the restore factory default, and ready.
God bless you
Jul 30, 2013 | Dell Latitude E5420 Notebook
Dell e5420 wont start up at all
Make sure no accessories are plugged into your laptop. First remove the battery and try a bootup. If does not bootup, remove the hard drive if you can and try again. If still no full boot, you can try the DVD drive and then the memory. Replace what you have found to be the problem. If none solves the bootup problem, it is either the power supply itself or a mainboard problem, which would required service from an authorized service center from Dell. Verify the center with Dell. The parts I have indicated to try are normally easily removed from the bottom of the laptop, by removing a few small screws.
Mar 15, 2013 | Dell Latitude E5420 Laptop Computer
Dell e5420 close lid power problem
What is the problem? Open Control Panel, Power settings, Advanced power settings, set to High Preformance, Set Sleep and Hibernate to Never , Set Lid close to Shut Down, adjust setting to your preference, Always shut down your Laptop, unplug when not in use. Remove battery if you use on AC most of the time, your laptop will last longer and a boot everyday resets the computer.
Jan 11, 2013 | Dell Latitude E5420 Laptop Computer
Sm bus controller
use the windows 7 'chipset' drivers make sure you choose the right one 32 or 64-bit. You can find out by right clicking on 'computer' then selecting properties, it will be in the middle of the window.
SM bus controller is for the USB.
Dec 18, 2012 | Dell Latitude E5420 Notebook
Need the bios unlocked on Dell latitude e5420
go to www.biosremoval.com they can sell you the bios password for 88.00 if you need hard drive password is 65.00 salt price but their solution work.
take care !
Apr 22, 2012 | Dell Latitude E5420 Notebook
Dell Latitude E5420 unexpected shut-down issue
I had the same problem. Check your cable from power/volume board to motherboard. One end of my cable connector was damaged.
Dec 27, 2011 | Dell Latitude E5420 Notebook
I have Dell latitude E5420. There is an unknown device in my Device Manager, please guide how may I find what device it is and then its drivers.
hi
make sure your operating system is updated thoroughly (go to START, WINDOWS UPDATE)
once you have done this go to this link below, download the AUDIO drivers & BIOS driver
once this has been done, go back to the link and download all applicable drivers dated for 2010 or 2011. Once you go through all these drivers, it should resolve UNKNOWN device issue.
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cabsdt1&l=en&s=bsd&ServiceTag=&SystemID=LAT_E5420&os=WLH&osl=en&catid=&impid=
download and save all drivers, then execute them one at a time.
hope this helps you ! if so , please send me 4 thumbs up
Aug 01, 2011 | Dell Latitude E5420 Laptop Computer
Dell Latitude E5420 Computer (blmcj3b) PC Notebook Logo
180 people viewed this question
Alun Cox
