Question about Canon PIXMA MX330 Multifunction InkJet Color Printer
I am trying to send a fax on a cannon mx330 but it is not sending properly?
I would add the fax number and put all the neccessary information and try to send it but it would come back as incomplete transmission or line busy
SOURCE: Canon Pixma MX700
I had the same problem. Solution? I will sound stupid, but it worked for me. Check every phone cable. Unplug and replug it. I solved my problem by making my connections simpler. I think, one of my splitter was faulty.
I still not understand why. I tried to fax without any phones plug-on and it was not working neither.
I'm with "videotron.ca" for my phone line and I unplugged the line from the modem too, then replug it. Maybe it was just that!
A lot of people seem to have this problem. I called Canon twice and they made me change some setting in my printer but their solutions was not working. I put all the setting back to what they was and it still working now.
Posted on Nov 20, 2008
SOURCE: Can't fax from Canon Pixma MX310
I spoke to BT, they sugest to put filters on anything which you vconnect, i know that it doesnt make any sense but they said that once youve got broadband connected to your line, all you connect next has to have a separate filters. try it out as i dnt c any other methods. It worked for him by the way!
Posted on Nov 23, 2008
FixinFax
  • 3085 Answers
SOURCE: Incompleter transmission causes? Result NG?
It means No Good. 5 possibilities:
Receiving machine unplugged
Not a fax number
Wrong fax number
Busy signal
Digital Phone Line
Posted on Jul 17, 2009
komguy
  • 2306 Answers
SOURCE: No fax transmission
Plug the phone line into the plug marked L on the back, make sure you are dialing the full number, The fax won't work in an office with digital phone service, you need an analog phone line like at home. In fax setup you need the type of dialing set properly, tone or pulse dialing, check also with Canon support, 1-800-828-4040
Posted on Feb 01, 2010
SOURCE: I have a Cannon MX860 all in one machine.
its not the printer but magicjack. I have the mx860 its great but magicjack stopped supporting fax after an update came out. mine used to work great, but then just stopped after no change on my end
Posted on Jun 22, 2010
Testimonial: "Thanks. I will be getting a land line when my business picks up a little more."
My fax machine MX532 won't let me send a fax though the machine
This is probably an issue for the receiving fax. Try this:
1. Find a piece of paper and write fairly large:
Call me if you get this
Your name
Your phone number
2. Send this to a different fax machine at a different company and location. If it works, then attempt to send it to the same fax you initially attempted.
- If it works then your document may be too large and you will have to send it over a couple pages (or less at a time).
- If it doesn't work then there is a compatibility issue with either your or the receiving end fax machine. You will have to find an alternative fax number to a different model fax machine. Don't expect the company on the other end to just change out their fax machine but they may have another model at a different phone number.
Another alternative - you can attempt to scan your documents and send them by email but check with your and the receiving destination security departments.
Best wishes,
Joe
Aug 25, 2016 | Canon PIXMA MX532 Wireless All-in-One...
How to fax on the cannon mx300
Step 1:
Put the document you want to fax on the glass scanner.
Step 2:
Adjust quality and contrast to your liking.
Step 3:
Dial the recipients number
Step 4:
Press the "Color" or "Black" button.
After scanning the document press "Ok" to send the fax.
To do this you must first set up the Cannon mx300 for faxing.
More information can be found in its manual here:
http://www.copiercatalog.com/catalogfiles/PIXMA_MX_300_service.pdf
Aug 21, 2011 | Office Equipment & Supplies
How To Enable DTMF Digits on AR_M_280N Fax machine??
have you tried adding * 's they add a pause between numbers. You may have to add several, but that will put a slight delay in the dialing.
Jul 23, 2010 | Sharp AR-M280N Copier
I can't get my new Canon Pixma MX330 to send faxes! No matter what number I try to fax to I get a "line busy" message. This is my new home office fax! Please help!
Better check the connection at the back of your printer. This is the most common problem encounter when faxing...wrong connection.
1. when using the printer as fax, the line input should be connected properly to the "L" input at the back of the printer
2. The rj11 connector of the phone should be connected at the back of the printer with telephone label in it
I hope that helps.
Jun 21, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
My fax (pixma mx330)says memory in use and shows
Hi, you must reset the machine in the factory setting mode.
Oct 09, 2009 | Canon Office Equipment & Supplies
Hello im trying to get my MX330 to print postage labels through microsoft word 2007. But before it prints it come up with a send fax screen. When i try to cancel this it cancels the print. Ive spoke to...
It sounds like the MX330 Fax driver is set up as the default printer in Word 2007. Before using the label option, which doesn't allow you to select a printer, check and see which driver is selected when you just go to print from Word 2007. If it shows MX330 Fax, change it to MX330 Printer.
Sep 09, 2009 | Canon MX300 Office All-In-One Printer
I have a lexmark x4270. Having problem sending fax. Sending local number, it's OK, but sending a different area code, it uses the local area code then the first 7 number of that number. Because someone...
Hi zoaj,
More then likely you have the fax set up to USE A DIALING PREFIX.
Therefore it is automatically doing this, regardless of what you input.
Follow the proceedure below ( which comes directly from the users manual for your printer type ) to change this. Delete the " USE A DIALING PREFIX " information.
once that is done, it will no longer automatically add the prefix for you. :)
I have BOLDED the relevant information below that pertains to this.
Please take a moment to evaluate my solution. Your appropriate rating of my solution would be greatly appreciated.
Thank you,
Using the Fax Setup Utility Use this utility to adjust the fax send and receive settings. When you save these settings, they apply to every fax you send or receive. You can also use this utility to create and edit your speed dial list.
  • Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Fax Setup Utility.
  • From Lexmark All-In-One Center All-In-One Main Page, click Fax Setup Utility.
The following table describes the Fax Setup Utility tabs:
On this tab:
You can:
Send
  • Enter your name and fax number.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Choose whether to use error correction.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report.
Receive
  • Choose whether you want to print a footer (date, time, and page number) on each page.
  • Automatically reduce an incoming fax to fit to the paper size loaded or print it on two sheets of paper.
  • Select whether you want to forward a fax or print it, and then forward it.
Connection/Dialing
  • Select the number of times you want the machine to redial and the time between those attempts if the fax cannot be sent on the first try.
  • Select the phone line format you want to use (Pulse, Touch-tone, Behind a PBX).
  • Enter a dialing prefix.
  • Choose how (manually, if fax tones are detected, or after a certain amount of rings) you want to answer incoming calls.
  • Select a distinctive ring.
Speed Dial
Add to, create, or edit the speed dial list.
Group Speed Dial
Create a group number and name, and then add phone numbers to the group.
Oct 11, 2008 | Lexmark Office Equipment & Supplies
Hello sir
put fax to send in top, type in fax number press Start/Send button
Nov 01, 2007 | Canon FAX-B820 Plain Paper Bubblejet
How to send fax
you put the paper face up, type the number and then press start, the phone line needs to be in the line connection and the other side in the wall plug, you need to see if you are using a direct phone line or if it is going through something on the way, other than that it is a very easy fax to use
Canon PIXMA MX330 Multifunction InkJet Color Printer Logo
old marine
old marine
