Question about GE DSXH43EAWW Electric Dryer
Ge dsxh43 squealing
Squeals during drying cycles
wayneard
  • 1901 Answers
SOURCE: ge dryer
It is probably the belt tensioner roller. They are not that hard to replace and not that expensive either. If you have it replaced consider replacing the belt while you're at it.
Posted on Oct 11, 2008
localwonder
  • 6784 Answers
SOURCE: It squeals while its running
HI, there are two possible issues here concerning this noise. it is possible that the belt is worn or, a bit loose on the spinning pulley. i recommend inspection the drive assembly. check the belt for possible ware. replace if necessary.
The second problem spot will be a set of damaged drum roller bearings. you will need to totally disassemble the unit to replace these parts.
***most common issue will be bad roller bearings
Posted on Jul 08, 2009
hunter19_46m
  • 7482 Answers
SOURCE: when drying it squeals
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Posted on Oct 15, 2009
heatman101
  • 43501 Answers
SOURCE: dryer squeals
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 29, 2010
heatman101
  • 43501 Answers
SOURCE: dryer squeals and squeaks with full load to be
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 08, 2010
Squeals during wash cycle
Take off the front to see where the noise is from. Nothing can happen until it is pinpointed.
Sep 23, 2010 | GE WHRE5260E Top Load Washer
Dryer squeals
heatman101
Jan 17, 2010 | GE DWSR463GGWW Dryer
The washer squeals as the water is filling the tub and continues through most of the cycles. As the machine agitates quickly, the squealing stops. However, it squeals at the end of the cycle.
Sounds like the pump.  When it first fills the pump recirculates the water, then it comes on at the end of each cycle to drain the water.  The pump is on the bottom of the machine, on the right side.
Dec 19, 2009 | Fisher Paykel EcoSmart GWL15
Jul 08, 2009 | GE Dryers
Washer squeals during wash & rinse cycles.
It sounds like you're brake stator & rotor is worn and merit replacement, it would also be prudent to replace the thrust bearing as well since you'll be in the same area for the repair. The way to verify is to place the unit in spin & allow it to reach speed then open the lid. If it squeals then the repair would need to performed, if it does not then further troubleshooting would be needed. Hope this helps... Bill
May 29, 2009 | Maytag PAV2300 Top Load Washer
Washer squeals in rinse or spin
When the washer is in the final spin cycle and starts to sqeal, just pour a little water through the drawer about half of a glass full usually does the trick. What apparantly happens is that the connection/seal between the big grey rubber seal and the stainless steel drum has dried out due to the centrifugal effect of the spin cycle and it needs to be wetted to keep the sealed area lubricated and cool. The squealing is a result of the dry rubbing of these parts during the spin cycle.
Apr 17, 2009 | Washing Machines
Dryer squeals off on during the cycle
The rear drum support must be replaced.
Part number 5303281153
Nov 29, 2008 | Frigidaire GLGH1642DS Front Load Stacked...
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
GE DSXH43EAWW Electric Dryer Logo
27 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
