Question about HP Pavilion a1330n (EL466AA) PC Desktop
Cd drive My cd writer will not open, how can i fix this?
  • 183 Answers
1.If the keyboard has a CD/DVD Eject key, press it. The Eject key is usually placed by the volume knob and is marked by a triangle pointing up with a line underneath.
2.Double-click My Computer .
3.Right-click the icon for the CD, CDRW, or DVD drive that is stuck, and then click Eject.
4.If the CD or DVD drive door button is a long clear plastic bar on the front of the PC, press firmly on the right side of bar. Some models have a button on the front panel of the PC to the right of the hinged door. Press the button to eject the drive.
5.If the drive door button is part of the PC case and is covering the actual drive door, open the door that is part of the PC case and press the Eject button on the faceplate of the drive.
6.Restart the PC and press the Eject button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD driver. Try shutting down or configuring any software programs that create discs or monitor the CD or DVD drive.
7. If the door still does not open, do the following:
1.Close all programs and shut down the PC.
2.Unplug the power cord from the power outlet.
3.Look for the small hole on the faceplate of the CD or DVD drive. This is the manual release. The location of the manual release hole will vary (see Figures below for possible locations).
NOTE: On some models it may be necessary to remove the front panel to expose the manual release hole. Check the documentation that came with your PC for information about removing the front panel.
NOTE: On some models the release hole and the drive activity LED look similar and are about the same size. Do not force the paperclip into the hole if it does not go in. Make sure that the hole is not actually the LED.
Figure 1: Possible location of manual release hole
Picture showing possible location of manual release hole
4.Straighten the paperclip and insert it into the manual release hole until resistance is felt.
5.Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
6.Remove the paper clip and gently pull out the drawer until the disc is accessible.
7.Remove the CD and turn on the PC.
8.If the tray still does not open, do the following steps to check the power cable for the drive. Work on a hard flat surface over a non-carpeted floor:
WARNING: The edges of metal panels can cut skin. Be careful not to slide skin along any edge of the computer's interior metal.
CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface (like the metal frame of the PC).
1.Turn off the PC.
2.Unplug all power cords from the back of the PC.
3.Press and release the Power button on the front of the computer.
4.Remove the side panel.
5.locate the power cord that connects to the back of the CD or DVD tray that is having the problem.
6.Unplug the power cable and wait five seconds.
7. Find a different power cable that is not being used, plug the different power cable into the back of the drive, making sure that it fits firmly into the socket. If a different power cable is not available, replug the original power cable into the back of the drive, making sure that it fits firmly into the socket.
8.Replace the side panel and plug in the power cord.
9.Turn on the PC and press the eject button on the front of the drive.
If the optical drive does not have the manual eject feature and the CD tray will not open by using the steps in this document or if a disc has shattered inside the drive, the CD, CDRW, DVD drive may need to be replaced.
Posted on Oct 25, 2008
Posted on Nov 06, 2008
How DO i Fix DVD Writer Works As CD ROM Only. Not Detecting any DVD.
There are 2 assemblies inside it.
One works to read/write CD media.
One works to read/write DVD media.
So, your device is "half-broken".
Replace it.
Apr 02, 2015 | Computers & Internet
Not reading all kinds of disc sony and benq cdrw
If your CD/DVD writer is not reading disks at all then there is problem in your drive's lens.
To fix it you have to open the writer and clean the lens .
If you don't want to clean the lens manually then there is a disk called "CD lens cleaner" available in the market , buy it and insert the disk into your drive.
This will automatically clean the lens
But if you want to do it yourself then please follow the below steps.
First of all take out the CD/DVD writer out and remove all the screws and slide the cover to open it.
As you see the lens don't touch it with your finger but clean it with cotton cloth. After cleaning it place the cover and close it.
Now try any disk in it. If it works then you are done.
But if it is not reading the disks then you have to change it.
Hope the above information is helpful to you.
Thanks for using fixya
Nov 30, 2010 | LG GH22LS50 DVD-RAM Burner
My LG writer only opens with the manual open by inserting paperclip in the pin hole...doesnt eject thru MyComputer too...
Hi, the problem is tape cable inside the writer , replace the tape which in LG Writer. (better to take to service center)
Apr 17, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
LG CD-ROM not ejecting the tray
you need a a small object...
do you see the small hole in the front of the cd rom??/you need to hit it so that it will open...
try it first...
hope i've help you.. rate me,..
Feb 06, 2010 | Computers & Internet
I purchased a plextor px-870a dvd/cd writer to replace the cd writer in our computor it is a dell with a dvd player in the top slot and a cd writer in the next slot down but the cd writer stoped working so...
On the back of a CD-writer or a DVD-writer is a small grid (2 rows) of gold pins.
Each vertical set of pins is labelled: MA(ster), SL(ave), and C(able)S(elect).
Be sure that one drive has a small jumper between the MA pins,
and the other drive has a small jumper between the SL pins.
Was there any software on CD-ROM that came with the DVD-writer,
e.g., software to play DVDs, and software to write CDs and DVDs?
To "play" a DVD, you'll need that software.
To "play" a music CD, Windows Media Player will suffice.
Nov 23, 2009 | Computers & Internet
CD is not recognised by the CD Drive
your dvd writer lens needs to be cleaned by a lens cleaner...
May 28, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
Can not get my cd dvd writer to open on my hp pavilion a810n
If no lights shown on drive, Check if power conncetor is rightly & securely connected to drive. try with other connector.
If still the problem persists, change the drive
Jun 27, 2008 | Computers & Internet
Lg dvd writer
First try to clean the drive (dvd drive cleaner cd).
If the problem continues then replace the drive with new one.
May 06, 2008 | LG Electronics GSA-H42LK LightScribe 18X...
How do I move pictures from computer to put on disk??
Do you mean to put pictures from computer to CD?
You need a CD writer in your computer, and a software to burn the CD. Usually the software is already there if you have CD writer in your computer.
Then, of course you need a CD blank.
I assume you have CD writer in your computer. The procedure would depend on the software you have, but ...
Try this simplest procedure, open the folder of the pictures you want to copy. Then highlight it, right click mouse --> copy.
After put your CD blank in the drive, click my computer --> click CDRW drive (the drive of the CD or DVD writer). Right click --> paste. You will see the blurred files there. Then right click and choose "burn these file in CD". Just follow the instruction.
Let me know if you have problem.
Apr 03, 2008 | Cameras
Samsung 52x cd writer
use memorex brand cdr they are the most compatable (readable media ) to many cd& dvd writers .
the reason the cd writer dosent open often is because its usually trying to read poor quality media use good quality memorex cdr you will see a big difference in performance.
Jan 09, 2008 | Ritek (R80JS52RDCB100) 100 Pack 52x CD-R...
HP Pavilion a1330n (EL466AA) PC Desktop Logo
307 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
