Question about Drills
Projecta workshop hdbc 1800 battery charger 12v/24v
Circut breaker fail
5 Suggested Answers
emissionwiz
  • 76164 Answers
SOURCE: Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Posted on Nov 07, 2008
radar001
  • 1051 Answers
SOURCE: My new Black Max 24v drill charger will not charge the battery
You indicate that the drill is new. I'd suggest you return it for a replacement. Seems to be a defective or wrong charger. If you have problems and If you paid by credit card call the card company and have them stop payment on that charge.
Posted on Feb 21, 2010
Battery charger for electric drill Agojama 240v- 50HZ
22v_ 400mA 14.OVA
Posted on Jun 05, 2013
  • 6 Answers
Cordless Drill Charger for Dewalt 7.2V 9.6V 12V 14.4V 18V Battery
Drill Charger for DEWALT 7 2V to 24V Ni Cd Ni MH Li ion Battery UK
Posted on Mar 18, 2015
How do I diagnose my aprillia city enjoy that the motor doesn't work anymore
You can download the workshop manual from a few websites, including this one APRILIA Enjoy City Workshop Manual
I would start by checking and cleaning the battery contacts where they connect the battery to the frame wiring harness near the seat post. The controller requires both 24V and 12V to activate the motor. If the battery gauge is indicating a full battery then it may be that the controller is not getting the 12V feed.
I had to replace the controller in my Aprilia because it had a fault. There is a lot of information on the Aprilia Enjoy models here. Endless sphere com
Mar 07, 2015 | Electric Bicycle Motor, Bike,electric...
One red light flashes. I know the batteries are charged 17v. I've checked all connections. apmeter reads zero. What else should i check?
17 volts is a sign of one battery bad, or both. How old are the batteries? Check each battery separately for at least 12v. Check at the batteries themselves. If you don't get the 12 or greater reading replace the batteries. If you don't have insurance check at batterysharks.com.
Jan 20, 2015 | Pride Jazzy 1103 Ultra Standard Power...
Will dc24sa charg a 14.4 battery
I have a 12v an 18v Dewalt I can charge them both from the same charger
Mar 07, 2014 | Makita 6932FDWDE 14.4V Impact Driver
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
Iv tried to charge my 24v battery but the charger is flashing very quickly and its not charging the battery
Either indicates the battery is bad or that the temperature is too hi or low to charge. Let battery reach room temp apart from the charger then try charging again.
Feb 27, 2010 | Saws
Battery won't charge, 24v charger doesn't light up
Original battery is 130$+, or you can buy replacement for cheapest price (work the same). So, depends from the wallet, choose one... I found them on amazon, take a look:
1. cheapest one (about 30-40$): Amazon com 12N9 4B1 battery
2. Original one (130$+): Finally charging for our multi device world
I hope this was helpful. cheers
Apr 25, 2009 | Garden
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Drills Logo
239 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
