Question about Home
Shutting off timer in Warnock Hersey jacuzzi bathtub
I have a jacuzzi tub and the jacuzzi starts working at the same time every night. Somehow a time got set and I cannot figure out how to cancel the setting. The red light is always flashing and no matter how many times I press the button it won't go off or stop timer setting. Please advise.
  • 23 Answers
SOURCE: Sony SXRD Projection TV
This is a fan issue, most likely the large fan in the rear, lower left (from the back)...
Here's the fix, I promise, it's EASY........
Ok, I think I have the answer for the BIG FAN failure. I recently did a similar fix on the spindle of an xbox 360 and it is identical. Ok, this is an EXTREMELY EASY FIX...
Open the back of the tv, locate the large fan (on the lower left on the back of the set.) unscrew the screen and remove the fan.
Once the fan is removed, you will see the side with the model number and the other side is totally open.
On the open side, pull...
The fan will come off, into your hand, it is only held by magnets...
You will notice a spindle on the fan and the other side has the magnets and the hole where the spindle came from (this is the fan motor).
Clean both the spindle and the hole (motor) with a q-tip. The hole is smaller than the q-tip, but do the best you can to remove the old lubricant.
Get a bit of WD40 and lubricate the spindle and spray a touch in the hole.
Put them together, reconnect your fan, test it on startup and thank me...lol...
HOPE THIS HELPS!!!! IT WORKS, TRUST ME...
Posted on Oct 01, 2008
frcs68
  • 1605 Answers
SOURCE: Bathtub jacuzzi (motor turns on but nothing comes out of jets)
open the the repiar panel and see if the pump is working. you may hear the motor running but not the pump.
Posted on Dec 04, 2008
  • 68 Answers
SOURCE: Bathtub jacuzzi (motor turns runs but nothing coming from jets)
Each Jet will have an adjustment many times right on the jet nozzle. Carefully try to rotate them counter clockwise to open up the jet. This assumes you can here the motor running.
Phil
Posted on Dec 09, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Program light and 12:00 are flashing, no buttons work
Press program set once, then switch to clock mode to set time.
Posted on Dec 17, 2008
  • 3 Answers
SOURCE: Power Button Flashing Red
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Posted on Jan 05, 2009
Warnock hersey wh-q11778 parts
The Warnock Hersey (WH-ETL) Mark is North America's leading product safety and performance mark for building and construction products.
It is NOT a brand, it's a test. You'll have to look again for BRAND, MODEL, NUMBER!
Nov 28, 2016 | Miscellaneous
Does anyone have any information on the Pine Ridge 500 wood stove? I'd like to know who the manufacturer is and what the EPA specs are.
PDF]installation and operation manual - Wood Pellet Stoves ...
www.pelletking.com/...stove-manuals/whitfield-advantage-iit-pellet-stove...
Services) and the listing mark is Warnock Hersey. Testing: In accordance ... The assembled pellet stove model Advantage II-T C FS and. Advantage II-T C INS ...
[PDF]INSTRUCTION MANUAL - Ignite Dealer Portal - Regency ...
manuals.regency-fire.com/getattachment/.../R12-R14-R16-Manual.aspx
Tested by Warnock Hersey ... LISTED FACTORY BUILT FIREPLACE ACCESSORY HEARTH STOVE ... it is important that you read this manual throughout.
Nov 01, 2015 | Home
I was given a warnock hersey hot tub model 1060 aruba with no manual. im looking for info on that tub and where i can get a manual.
After i fill the hot tub it keeps drain the water from the bottom, how i can keep it filled.
Jul 02, 2011 | Pool & Spa
My Jacuzzi H522 will not turn off sometime without shutting the breaker off. It has even turn itself on a few times so we leave the power off
sounds like you need a new temp sensor on your tub. if it is not heating and running all the time even though it is calling for heat - then the sensor is bad.
you can find a sensor here Bath Parts Plus
Jan 22, 2011 | Jacuzzi Mito, 6 Whirlpool Bath - H522
Need to know how to drain a warnock hersey hot tub
Only way to drain that spa is siphon out the water and then use a shop-vac to get the rest out, sorry that tub is kind of a pain.
Nov 22, 2010 | Pool & Spa
The timer for the Jacuzzi is working, but the motor is not. It is a bathtub, Harvest Gold color, so must be from the 1980's. The last time I tried it, it was fine, but that was over a year ago. We tried...
There may be a ringer volume switch on the side that got set to the off position inadvertently. If there is a "menu" button press it and see if there is a ringer control option.
Apr 17, 2010 | Jacuzzi - Bathtub - Alcove - Navona -...
We have a new Jacuzzi tub and went to turn it on
check to make sure the pumps on and that its wired correctly and that all valves are open.
Feb 22, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have a floor leval hot tub,with jets but i cannot start it. it has a plate on the wall with a time and start button
make sure there is power to the motor. also check the timer, they do break down. the start button i am not sure of - that may be bad if that button is used to start the timer.
Feb 10, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My Jacuzzi jetted tub has stopped working. During the last 3 or 4 times used, it initially wouldn't work when I turned the timer dial switch on, however, after a few minutes it started working. It also...
other than your switch , it could only be the moter or connection to it. always make sure you have enough water in the tub before turning it on or you'll ruin it.
Sep 17, 2009 | Home
Home Logo
180 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
