Question about Frigidaire Affinity ATF7000E Front Load Washer
Can not enter diagnostic mode affinity washer
Getting e41 code. replaced door latch and still getting E41. no other codes, do not know how to enter diagnostic mode.
5 Suggested Answers
  • 85 Answers
SOURCE: frigidaire affinity atf7000es1 E41 code
check to see if the door stike is not broken on door if good and you have changed door lock asm you have a bad control board
Posted on Dec 14, 2008
Krazytech
  • 725 Answers
SOURCE: My washer is stuck in pause mode and when I
E41 Control board thinks the door switch is open. Remove the door lock assembly and measure the resistance of the PTC. Shortedor open.Defective door lock assembly. Around 1500 Ohms. Defective control board.
Posted on Sep 19, 2009
KevinWhite
  • 1902 Answers
SOURCE: I have an Frigidaire Affinity
Hello & Welcome to FixYa
E41 error indicates that the problem is with door lock assembly, it is displayed when the control board thinks that the door switch is open. To solve this problem you have to remove the door lock assembly and measure the resistance of the PTC. If it reads open then the door lock assembly needs replacement however, if the reading is around 1500 ohms then replacing the control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Aug 01, 2011
Jahn27
  • 1554 Answers
SOURCE: Frigidaire Affinity washer (LAFW3511KW0) with
Install the door lock/switch assembly with the door switch harness disconnected but "jumped". Jump a wire between the wire harness terminals and if the error code (E41) stops appearing when the machine is started, the door lock/switch assembly is indeed faulty and needs to be replaced.
Check the continuity of the door switch harness connecting the switch and terminal J2 of of the control board if the error code (E41) still appears every time the machine is started after putting a jumper wire between the door switch harness terminals.
Make sure the connectors are clean and snugly connected to both. Replace the wire harness if you are skeptical about its condition. Disconnecting the door switch wire harness (J2) from the control board and putting a jumper wire between the leads of terminal J2 on the control board will directly confirm the condition of the wire harness and the board itself. The wire harness is the problem and must be replaced if the error code E41 stops appearing. On the other hand, consider replacing the control board if the error code still flashes even when the leads of terminal J2 on the board is shorted ("jumped").
Posted on Aug 21, 2011
What is code E41 on a Frigidaire Affinity ATF800FS. THE DOOR IS LOCK BUT THE DOOR LOCK INDICATOR WONT LIGHT UP & THE WASHER WONT SPIN
I appreciate your post, Trent!
Based off the information you have provided your Frigidaire washer is displaying an error code of E41 and the door is locked and will not open. An E41 error code means that your main control board thinks the door is open. I would recommend performing a reset on your washer and you can do that by disconnecting power from your washer for at least ten minutes. If that does not help correct your issue it could be a possible problem with your door lock assembly, control panel, or wiring harness. You may need to seek assistance from a professional technician to avoid unnecessary part purchases. I hope this is helpful to you. -Matt
Aug 03, 2015 | Frigidaire Washing Machines
I have a Frigidaire front load washer #ATF6000SF1 and need to reset the PAU and E41 error code. I cannot get the unit into diagnostic mode to accomplish this. How can I reset this code?
I appreciate your post, Josh Orenstein!
From my understanding your Frigidaire washer is displaying "PAU" and "E41". "PAU" normally displays when there is an interruption to the cycle and "E41" means the main control board thinks the door switch is open. Either code can display due to a faulty door latch assembly, door strike, or main control board. You can attempt to perform a factory reset by holding down the Start/Pause button and Select button until a signal sounds. Also review the door latch and strike to see if there is any visible damage that could cause a short within the components. If there is no visible damage you may want to consult with a technician for proper diagnosis and repair of your washer. Hope this information is helpful to some degree. -Matt
Dec 07, 2014 | Frigidaire Washing Machines
My Frigidaire Affinity washer stopped working in middle of cycle and shows E41 code.
Hello Shawn Smith - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Mar 03, 2013 | Frigidaire Affinity ATF7000E Front Load...
Fridgidaire upright washer E41
Hello Marcee Peterson - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
E41
Control board thinks the door switch is open. You may need a new door switch.
Dec 23, 2012 | Frigidaire Affinity ATF7000E Front Load...
E41 is displayed
Hello mev1985 - Error code E41 indicates that the main control board thinks the door switch is open. Contact a professional to check the continuity between the pins in the plug and door strike. The unit either has a defective door switch assembly or main control board.
Oct 05, 2012 | Frigidaire Affinity ATF6000F Front Load...
Error code e41
Hello phrainer3 - Error code E41 indicates that the main control board thinks the door switch is open. Contact a professional to check the continuity between the pins in the plug and door strike. The unit either has a defective door switch assembly or main control board.
Oct 01, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity washer (LAFW3511KW0) with an E41 error. I have unplugged to reset (no change), checked the stricker (fine), removed outer seal and disconnected and reattached (I also received an E41...
Aug 21, 2011 | Frigidaire Affinity ATF7000E Front Load...
PAU error code comes on when iI test it it shows e41 door lock
Hello, welcome to FixYa
Based on the info you provided, specifically the E41 error, It sounds like the unit is detecting an unlocked door, loose wire, or the control itself is bad. (E41= Shorted or open. Defective door lock assembly.Around 1500Ohms. Defective control board.)
The PAU simply indicates the control thinks it has been paused...that may be just a side affect of the door lock assembly.
Here's how to check...
**Unplug the unit from the wall first...safety first**
Remove the door lock assembly and measure the resistance of the PTC. Should get a reading of around 1500ohms.
Attached here is a great tutorial for accessing the assembly for testing and replacing.
http://www.repairclinic.com/PartDetail/Door-Switch-Assembly/131763202/1531974
Let me know if you need further assistance going forward or if anything is not clear.
Thank's again for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Jun 16, 2011 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire affinity atf7000es1 E41 code
Dec 11, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
130 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
