I have hardware error 03130031-2f25 on my a1 plotter. how can i fix the error?
Error code 03130031 2618 print
The hardware error code indicates that a print head failure has been detected. Other possible causes of this error are a faulty cable connection to either one of the PCB's.
First try replacing the Print Heads and if the problem persist, re-seat the cabling to the Relay PCB and the Carriage Unit PCB.
Since you are unable to access service mode, you will need to ignore the normal print head replacement procedure and replace the printheads whilst the plotter is turned off.
The plotter will need to be disassembled to access the print head.
See the following service manual for a detailed guide:
http://mail.davin.be:8888/CANON/BOOK%20IPF/IPF750/ipf750_755-sm.pdf
Nov 06, 2013 | Canon imagePROGRAF iPF8000 Printer
Hardware error
hello, can you specify what error number is?...i have a service manual for this ipf710 plotter and i can tell u what is wrong with it or you can download the service manual from the below link:
http://goo.gl/daFE3c
good luck
Sep 11, 2013 | Canon imagePROGRAF IPF710 Printer
When printing a file from Microsoft Project, it prints out halfway and then displays "Hardware error"??
Probably your project file is partially corrupted, apply fix ms project file
http://www.project2003.fixprojecttool.com automatically converts corrupted information from damaged MPP files in use into clean Microsoft Project files of corresponding format
Feb 18, 2013 | Canon imagePROGRAF iPF710 InkJet Plotter...
Canon ipf750 error 03130031-2618
Hardware error. 03130031-2618
Turn off printer, wait, then turn on again.
03130031-2618 VH voltage error
Check the power supply unit.
Mar 01, 2012 | Canon imagePROGRAF Office Equipment &...
Hardware Error 03130031-2E23 Turn off printer, wait, then turn on again I done this twice and it does not fix the problem, it just repeats the same message. Any ideas what the problem is?
This error on the Canon iPF-605 wide format printer means that there is a problem with the paper cutting knife. The knife (black block) should be at the left front side in it's rest position.
Powered the printer down and moved the knife block from right to left, powered on and voila: problem solved ! Thanks Canon support!
May 19, 2011 | Canon Office Equipment & Supplies
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
Cant do EEROM setup coz severe error:0x4010008 occured
restart the plotter in service mode using following method
1 power off the plotter
2 press Up Arrow + Enter Button ( green buton) and while pressing both buttons switch on the plotter
3 when u see service test /Service utilities release keys & select service utilities & then perform eerom setup there , put the actual model number ( c7780b/c ) and it wil resole the issue
Mar 30, 2009 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
450c Plotter apparently dead
Check the cable connections, and the cable connector inside the plotter. Make sure your cables are good.
Dec 29, 2007 | HP DesignJet 450c InkJet Printer
Event ID 11 error
Wonderign if you tried to install this on the RAID controller....big nono and cause this very issue...try a different SCSI controller...hopefully you ahve one onboard NOT raid. hope that helps
Aug 17, 2007 | Sony AIT Library LIB 152E/A1 (LIB-152E/A1)...
377 people viewed this question
k24674
jasbo
jasbo
