Question about Dryers
Creda condensing tumble dryer(tcr2)
My tumble dryer is working and sucking water out, however the drum is not rotating round, we have opened it up to find that the belt is slack we have tried to reattach where we think its goes however the spool that we think the belt runs over is very wobbly and when we moved the dryer we found black dust under the dryer.
can you help??
many thanks
Joy Heslop
5 Suggested Answers
  • 1462 Answers
SOURCE: creda tumble dryer repair
with great difficulty - these belts are so tight!there is a special tool for doing it but there are other ways
one way i have used is to make a spanish windlass from belt to bottom of machine. when belt is level with motor spindle, push belt on and release spanish windlass. could also try levering belt on with a screwdriver
another method is to get a short piece of tubing that will fit over motor spindle. put belt over tube, lever down and slip belt on. this is the best way
Posted on Jul 20, 2008
SOURCE: CREDA TCR2 TUMBLE DRYER
put it in the bin
Posted on Sep 12, 2008
barkencoa
  • 3463 Answers
SOURCE: I need to fit a new belt to a Creda Tumble Dryer
Hi.
On some models it is possible to fit the belt on the tensioning pulley or pulleys , the wrong way.
Assuming you have the correct belt, then I suggest you try the belt on the pulley a different way.
Hope this helps.
Posted on Nov 29, 2008
rylee_smith
  • 8619 Answers
SOURCE: Not heating up
Hi
If your dryer doesn't heat, check these:
Power from the house -- Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element -- Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse -- On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring -- A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 07, 2009
hunter19_46m
  • 7482 Answers
SOURCE: can you supply an instruction manual for a creda
Try this website, maybe you will find out what you need.
I hope this helps
Clothes Dryer how-to instructions. Clothes Dryer help.
laundry.manualsonline.com/manuals/device/clothes_dryer.html
Posted on Oct 03, 2009
My creda mode tcr2 isnt drying my clothes anymore
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 30, 2011 | Dryers
Tumble dryer is very noisy
i had the same problem.it ended up being the bearing that holds the drum in place.it had worn that bad that the drum was rubbing the bottom of the dryer.the bearing is located on the back of the dryer if the bearing is worn there will be like black dust around the area.this does stain so be carefull
Feb 19, 2010 | Miele Dryers
Creda T622CW condenser tumble dryer drum wont turn
You need to check if the belt is o/k.
Remove top cover, and grasp belt, it should be firmly wrapped around drum.
If o/k, then could be a motor problem, or programmer fault
Once you have got the drum turning again, it is possible the filter light will go off,if not, then you have another fault
Hope this helps.
Dec 16, 2009 | Dryers
Can you supply an instruction manual for a creda simplicity condenser dryer TCR2
I hope this helps
Oct 03, 2009 | Dryers
Tumble dryer drum only starts when i start it first by hand
starter capacitor went bad on motor... replace
Mar 12, 2009 | Dryers
How to fit a belt to a creda tumble dryer
open case
loop belt around bits
close case
more particularly
Unplug dryer
pull dryer away from wall
remove 1 screw each side at back of top plate
slide top plate backwards and lift off
undo 1 screw each side of front kickplate
tlit front panel up
unplug door switch
set front panel aside
careful of control panel its V.fragile
(I lay the dryer on its back)
pull out old belt and bits of belt
loop new belt round drum at wear marks
pull tensioner to end of travel against spring
loop belt round motor pulley & both tensioner wheels(most creda) 1 wheel (old)
relax tensioner
rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
creda uses hotpoint parts
Oct 30, 2008 | Dryers
put it in the bin
Sep 12, 2008 | Dryers
Tumble dryer wont dry
hi do you have any blockages in the vent system (lint) can you hear the fan running and are the filters clean.did you put it back together correctly.hope this helps.
Mar 05, 2008 | Dryers
Drum wont turn on my creda t622cw tumble dryer
my tumble dryer drum wont go round
Nov 15, 2007 | Dryers
Dryers Logo
59 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
