Question about Dewalt 1/2 Hammer Drill DW511
Dewalt dw511 won't go in hammer mode
Brand new out of box , does exactly same rotational drilling on both settings
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Replaceing chuck on a Dewalt Dw511 1/2" hammer drill.
Open the chuck jaws and you will see a screw in the center of chuck, it is left hand thread. remove it and use a large bent handle allen wrench putting the short portion in the jaws and tightening. Shift the drill to the low position and have the clutch in the drill only position. place the handle of the wrench at about a 30 degree angle to strike it counterclockwise. put the chuck on a block of wood or workbench and hit it, this might take a couple times but it will come off. Let me know if you still need help
Posted on Mar 09, 2009
  • 142 Answers
SOURCE: dewalt dw567
if i'm confused i'm sorry, but don't confuse and impact driver with a hammer drill
2 different tools altogether
Posted on Feb 27, 2010
  • 67 Answers
SOURCE: my dewalt slips bad in the drill mode whiile i am ...
Check the speed selector switch. if it is not fully engaged (usually because of dirt) the gears will slip. cycle the switch a few times.
Posted on Sep 16, 2010
emissionwiz
  • 75066 Answers
SOURCE: Dewalt dw511 hammer drill won't hammer, only
The hammer inside the drill head are most likely damaged ans/or broken, it is likely the best thing to do is just replace the tool.
Posted on Feb 16, 2012
How do I put a Dewalt DC988 hammer/drill in hammer mode?
turn the selector lever from hammer / drill to hammer
it is a second lever close to the gear box of the drill
Sep 17, 2016 | Dewalt Drills
How do I connect the chuck key to the chuck key holder on the DW235G drill?
Easiest is to tape the chuck on the cord about 18" away from the plug, this way-for safety reasons, you should disconnect it before making adjustments (with the chuck in hand and you accidentally pull the trigger and bad things can happen.)
Aug 27, 2013 | Dewalt 1/2 Hammer Drill DW511
My dewalt drill won't switch to hammer
I had the same problem. You need to manipulate either the speed or the torgue. In some cases both. Sometimes the drill/hammer feature gets stuck in between the two an this is the only way to fix it unless taking it apart but I wouldn't do that yourself. Best to take it back to the dealer or service shop
Feb 28, 2013 | Dewalt DC223KA Heavy Duty 24 Volt 7/8 Inch...
Dcd985 reverse switch won't work
The switch (PN: N089938) for your drill costs between $75 & $80, so:
If by "brand new, just out of the box" you mean you just bought it, bring it back to where you got it and exchange it or get your money back.
If by "brand new, just out of the box" you mean you bought it, it sat somewhere for some time and you're just now using it, check to see if it's still under warranty so you can get it fixed through that.
If it's out of warranty, you'll have to buy a switch to fix it. They're available on sites like www.ereplacementparts.com.
Feb 21, 2013 | Dewalt DC925 Cordless Drill
I have the chance of a cheap D25303K dewalt 230 volt drill. does it have a chisel rotation stop (percussion only) feature ?
Go to the Dewalt service website at http://servicenet.dewalt.com, put the model number in the parts search box and you'll be able to view or download the parts breakdown and owner's manual. By the manual that model does have three modes; a hammer only, drill only and hammer/drill.
May 28, 2012 | Dewalt D25303K Electric rotary hammers
Jaws won't tighten or loosen to hold a bit
Hmmm some times the counterclockwise screw that attaches the chuck to the drill come forward and that is how then it stucks the 3 parts that fix a drill to a chuck. Check if this screw come forward. If yes then destroy it and replace it... We destroy it by using a drill smaller than it (usually it is 5mm so we use 4mm bit and of course a CARBIDE one because even cobalt ones can not drill a hardened bolt)
Mar 26, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Feb 15, 2012 | Dewalt Drills
Will it go back and forth as well as rotate?
depends on the drill. give me the brand and model number and I will try and help. Some hammers have a selector on the side to go from hammer drill to hammer and then drill only. Let me know and I will try and help
Jan 08, 2012 | Dewalt Drills
I have a Dewalt DCD770KL 18v LiOn drill/hammerdrill. I did not use it much for drilling into concrete before, but recently, I needed to mount something to the ground. I used the hammerdrill setting and...
Please visit a qualified technician. Because it's also my personal experienced with hammer drill that inside a small ball bearing with tiny spring as a tosser for shifting always been stocked up by sticky or hardening grease which you need to loosen. If not kindly check it up for something that is blocking the shift. Thanks for asking.
Jun 13, 2011 | DeWalt DCD770KL 18Volt Cordless 12Inch...
Dewalt 1/2 Hammer Drill DW511 Logo
32 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
