Question about Sanyo DS24205 24" TV
TV screen is frozen
Cannot change screen from a blue field with VIDEO in upper right hand corner. Menu screen can only be switched between the Auto/Manual/game line and the Language line. Help, please!!
  • carolgn Dec 31, 2008
    I have the identical problem, There is no input button on the TV to change between TY and video and the remote no longer works with the TV in this condition. Is it possible that something has broken?
  • pappu3070 Apr 15, 2009
    i have the same problem the blue screen
  • 41 Answers
Look for a button on the remote or front of the set that is labeled input (could be tv/video) this switches between video inputs and the tuner.
Posted on Dec 21, 2008
Need a code for a hyundai television serial number 6011604481
HYUNDAI HU-TV2121 processor N403 KALORA HHEN16MD01.Videoprotsesor LA76810A - the very bottom hidden button (right of the circuit), click once highlighted FACTORY. More P + and P-switching options.
HYUNDAI C2910, C2519, C2988
1. Set the volume -0
2. Press the remote button "MUTE"
3. While holding "MUTE", press "MENU" on the front of the TV.
4. On the top right corner will light up the letter "D", and in the left corner shows an adjustable parameter and its value.
5. Pages menu change button "CAL"
Switching parameters conducted green and red buttons on a blue field panel. Change made a yellow and blue buttons on a blue field.
HYUNDAI H-LCD2000
To enter service mode simultaneously press "MENU" and "STANDBY".
Press "MENU" again.
HYUNDAI, ITT 29M03 C2131 chassis CPU M37160M8-064FP
In the main menu code 6, 4, 8, 3.
Tools submenu contains the switch to the next of which is done by putting 6, 4, 8, 3.
HYUNDAI 359, 387, 8FHIFI, CB5373Z, 6578F processor CCU SEL04 / SEL07A
Mode 1: Close contact in the hole near the keyboard and just press "S"
Mode 2: Close contact in the hole near the keyboard and just press "S" again and click on contact. Exodus - LOAD.
HYUNDAI processor SAA1293-03-03 SAA1293A
With remote control TV "Horizon" graphics without clicking "SERVICE", the indicator shows a CH, a paz-click on 'appears OP, then choose the volume of registers numbers "1-4" and numbers "1-9" change bits. Then click on "Memory" (you can also lock the pins 15 and 23 in the control circuit SAA1250). Exodus - POWER OFF.
HYUNDAI
chassis CCU11 - "•?" (C) (H)
Chassis CCU12 - close contact in the hole near the keyboard and just press "S". Exodus - LOAD.
HYUNDAI chassis M1, ITT, NOKIA, SALORA 6390, 7190, MV4000, PL14 24 101 852 SAT SOLI, 882 SAT SOLI, 885 SAT SOLI processor CCU-SALO-07 (CCU20XX)
entrance "C"> "*"> "O / V"> "#"> "M". Exodus - "power".
HYUNDAI chassis EUROSTEREO-1. DIGIVISION 1963 .. 2, 1971 .. 2, 2 .. N6 processor NES3-... NES2-..
Log "-/--" "MENU" "TV" - for a second. Exodus - POWER OFF.
HYUNDAI chassis STEREO PLUS. 5575SFN, 28T7 processor ST92T93
Entrance - "i" "M" "P +", output - TV.
HYUNDAI 3875EX DIGIVISION
Gun "AV7 universal" fully fit.
Sign in service "1-/11. (Button with painted upper corner). TV must be turned on and display a feed.
Recommended initial value: V.AMP-027. V.LIN-038. S.COR-020. V.POS-023. H.POS-041.H.AMP-022. P.TILT-013. P.AMP-024. P.CORN-007. GREEN-032. RED-032. BLUE-032. V.BRE-005. LUM.DEL-000. AUDIO-032.OPBYT1-002. OPBYT2-064. OPBYT3-000. PRLOSK-000. RESERVE-000. Writing in memory - click "E".
Memory 24c08 can put a clean, turn on TV it propyshe processor itself.
from electronics-planet .blogspot
Jun 12, 2011 | Hyundai Televison & Video
Experiencing convergance problems in upper left hand corner on Samsung PCL541R mostly red shifted to right and down Bottom right half of screen is clear Do I need to replacer convergance chips?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | Samsung PCL541R 54" Rear Projection...
Blank Blue square on left hand corner of the screen ??
It might not be the same issue, but we had a blue square in the upper left hand corner of our hanspree. To fix it, either press the button headed 'pip' or go into menu, down to calibration and then uncheck the box titled 'pip' there. I hope this sorta yours as it did ours.
Nov 10, 2010 | Hannspree XV37 HDTV 37 in. LCD TV
Problem with JVC CRT TV (slim) with screen to have red color at the lower left (facing the TV) corner and a green color on the upper right corner of the screen. Sometimes while watching TV shows, the upper...
There is strong magnetic field around the TV. This may be due to the tower speakers or any portable radio kept close by.
Re orient the TV try switching OFF / ON at the intervals of 30 minutes. The built in auto de-gauser will correct the problem. In cable TV program if the picture is OK, nothing wrong in the TV.
Check with a different CD.
May 19, 2010 | JVC AV-21QMG3 21" TV
A lock icon has appeared on the screen in the upper right hand corner and i can't watch tv. the lock is a red thing on the blue screen.
it could be the child lock, accidenty activated from remote or tv buttons,...goto steup mode and switch off the child loc, or any lock that your tv indicates is active...if the problem continues, might be the gate ic, inside your tv needs repaced or reprogrammed...the number on that ic is in somthing 240co8......8 legged small ic..change it....or refer to qualified tech..
Oct 25, 2009 | Televison & Video
The picture on my LTV-19w3 WH tv just shows a blue, black, or green screen with about a 4" sq. plaid patch in the upper right hand corner. Sometimes the sounds works other times it does not. Can anyone...
While the TV is on do the following:
1. Press the "Right Arrow" button on the remote.
2. Press the "Left Arrow" button on the remote
3. press the number keys in order, 1-9
I believe you are in the TV's service menu and the Blue/Green/Black are just test patters. If so, pressing these keys will eventually change the pattern..
Get to the main page of the service menu and press the [power] button on the remote.
Jun 16, 2009 | Westinghouse LTV-19W3 19 in. LCD...
Blue screen on my tv; lock on screen how do i remove it
Go to menu and look for lock function and turn off. blue screen. tv is muting video bucause it is not getting any input signal .
Apr 24, 2009 | Televison & Video
Word "video" on screen
I tried menu again, scrolled to channel set and automatically reset the channels.
Apr 05, 2008 | Sylvania Televison & Video
Screen problem blue area in the corner
remove any big speakers that are close to the tv
Dec 17, 2007 | Televison & Video
Green blur bot-R and up-L corner and no audio
If a standard TV has color splotches in 1 or 2 corners of the screen, it is possible that a large magnet, such as a large speaker, is or was near the set and has magnetized the picture tube. The set has a built-in degaussing coil but it is small and will only demagnetize small magnetic fields. Make sure there are no magnets near the set and if the colors are still off, have the picture tube demagnetized with a strong portable demagnetizer. As for the audio, when there are audio output jacks on the back of the set then there is usually an option to turn the speakers off. Some sets have a switch somewhere and some sets have a setting in the audio page of the on-screen menu. Look for a switch or go into the menu, navigate to the audio page and look for a speaker setting (ON / OFF) and make sure the speakers are set to ON.
Aug 28, 2007 | Konka K2386U 23" TV
Sanyo DS24205 24" TV Logo
298 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
